Closed Thread
Old 17th May 2005, 13:14   #46
Harrie's Avatar
Thanked: 25 Times
The Optra has light similar to the GTX i think. So for dim only one light comes up and for bright two bulbs burn. The bulbs are already 55W i think. So you'll be getting 110W output in bright which should very much be ok i think.
The free air subs as far as i know are available only in sony and pioneer. Not sure about polk audio but think they too have a free air. The sony and pioneer free airs are around 3.5k and are rated at 150w RMS approx.
Harrie is offline
Old 17th May 2005, 14:06   #47
Montoya's Avatar
Well yesterday i did drive the Optra in the night and didnot find the light adequate enough for my needs so am planing to upgrade..
Montoya is offline
Old 17th May 2005, 14:15   #48
Thanked: 9 Times
Monty..congrats on the car and yeah black looks amazing !
But whats all this with the light upgrade...is that thn all tbhp cars that blind me with lights too bright/hi-beams ?..hehe not really sure if you plan to take her rallying at night but city lights are enough I think....on empty/twisty highways its understandable though.
Abhay is offline
Old 17th May 2005, 14:19   #49
Harrie's Avatar
Thanked: 25 Times
take care dude. a very high power bulb can cause serious damage to your headlamp assembly. Maybe go for the Philips bulbs speed satya told. Dont go overboard anf fit two 110W in it!
Harrie is offline
Old 17th May 2005, 15:03   #50
tsk1979's Avatar
Thanked: 16,422 Times
You could go for the 80W ones for bulbs instead of the 50W stock. They wont need a relay I guess, but 100W will need relay and may void your warranty
tsk1979 is offline
Old 17th May 2005, 15:05   #51
tsk1979's Avatar
100W would require relay and would void warranty. 80W should be good enough. Try getting phillips Rally/ or other reputed brand
tsk1979 is offline
Old 17th May 2005, 15:12   #52
tsk1979's Avatar
Its not bright beams that blind, its the high beams. If you drive on dipper with properly aimed headlights, even very bright bulbs(130W) will not blind anybody. However on full beam even 60W can be blinding.
tsk1979 is offline
Old 17th May 2005, 17:26   #53
speedsatya's Avatar
Thanked: 712 Times
tsssk tsssk,
what about this 80 w bulb?????never heard about an 80w bulb before.why would you not require a relay for it.
speedsatya is offline
Old 17th May 2005, 19:19   #54
Montoya's Avatar
Well i went and find out option now between 130/110 and 100/90 also any one has contact number of lumar in mumbai..
Montoya is offline
Old 17th May 2005, 20:48   #55
viper's Avatar
Thanked: 9 Times
you get lumar at all accessory shops in bombay. Bhavi at Milan is the main distributor.
Viper
viper is offline
Old 18th May 2005, 10:04   #56
tsk1979's Avatar
Because it is only marginally more than the 55/60W. Only if you go to 90W+ you need a relay. Most of the circuitry and fuses have that much tolerance built in. Headlights have 15A*2 fuse which translates to 180W*2 power at 12V. With 80W you will have 160*2W. So the stock circuitry is designed to take upto 90W bulbs.
tsk1979 is offline
Old 18th May 2005, 22:01   #57
Montoya's Avatar
Thanx guys i have decided to upgrade to 130/110 for headlights and 100 for Fogs with cutout and relay.. I wanted the number of Lumar anyone has it?? How much heat does Lumar cut out since V kool cuts out 94% and Ray barrier cuts out 95%.. getting Ray barrier at Rs.14000 incl of Sun/Moon Roof and incl of everything Labour etc. Vkool was 23000 but since i already had it on my NHC i am getting it at Rs.20000 and i found Ray barrier not so dark and i want dark tints so should i put normal dark tint over Ray barrier??
Montoya is offline
Old 18th May 2005, 22:08   #58
speedsatya's Avatar
Thanked: 712 Times
[quote=Montoya]Thanx guys i have decided to upgrade to 130/110 for headlights and 100 for Fogs with cutout and relay.. I wanted the number of Lumar anyone has it?? QUOTE]
dude,
u seem to have got it all wrong.uyou cannot put the reagular 100/90 or 130/110w 2 filament bulb in your optra as its got separate headlights for high and low beams.
so u need to get separate bulbs for the high and low beam respectively.
the palio has similar headlights.
so try and talk to any palio owner who has upgraded his headlamps adn let us know.
BTW what di dthephilips guy say.???????
Old 18th May 2005, 22:19   #59
Montoya's Avatar
Talking
Ohh yah i forgot the high and low beam have different bulbs but anywayz i did check up with the person and he told me that there is a different slot type of pattern for the Optra.. and all so once i confirm with the dealer i will surely tell you..
Well will have to check what he said since havenot checked my mail
Montoya is offline
Old 18th May 2005, 22:30   #60
karthik247's Avatar
Thanked: 16 Times
nice purchase monty, the optra lukz best in black..and is ur car with the new front grill? if u want real nice light, throw in some money and go for xenons!! and isn't the sunroof kinda tinted??
karthik247 is offline
Closed Thread
Bits for Optra 1.8 BikerSG Modifications & Accessories 16 20th December 2006 16:05
Hot Chevy Optra! Revvmaster Modifications & Accessories 46 11th June 2006 08:50
K&N filter and a dented Optra Rudra Sen Modifications & Accessories 16 21st August 2005 21:34
Optra v/s Optra Design Edition GreenHex The Indian Car Scene 17 29th October 2004 02:47
