Old 4th April 2009, 13:04   #1
Harrie's Avatar
Thanked: 20 Times
Thumbs up Restoration of 1982 Ambassador
The whole thing started off when a close friend of my dad's wanted his car painted. He wanted a basic blue-black paint that you find on many ambassadors here. And the car came in, this is what it was like
On closer inspection we found that the car has been getting a overcoat every year for the past 10 years and the paint and putty thickness were almost a CM!
So decided to do a full fledged painting - strip, rework and paint job. Because the car is more than 20 years old was expecting some rust too.
The paint was sanded off completely. A little bit of tinkering here and there. A lot of panels were redone in corrosion resistant alloy steel sheets. These sheets have hardly any cohesion with putty or paint, so a coat of sealer ( not sure which one ) was done. Then the panels were beat into place whereever possible and putty work was restricted to the minimum.
But still there was some putty amount of putty work involved as this car had lots of this alloy sheet work and it was not possible to beat into the factory specs.
The dry sanding work is going on now. The plan is to give a really good paint job. The paint will be black base coat with blue & violet pearl tinted clear. This will give the car the blue black look what my dad's friend wanted. And also look eye candy
BTW this car has covered more than 4.5L kms to date and is currently running on its 3rd diesel engine. Its got a power steering conversion also recently. Some nice hand stitched leather will go in to give it some class. The car finally will be rested from its active duty and will be run inside town for school duty.
Will keep this thread updated as work progresses. Dry sanding should take another 3 weeks I guess. After which the primer and paint will go in.
Harrie is offline   Reply With Quote
Old 4th April 2009, 14:00   #2
siedo's Avatar
Thanked: 11 Times
Amby is a car which can be restored n number of time and it will still give you the same feel
siedo is offline   Reply With Quote
Old 4th April 2009, 18:21   #3
Harrie's Avatar
Thanked: 20 Times
Stage 1 dry sanding on the right side is over. A guide coat has been applied. Whenever working on a old car, its always better to dry sand and apply a guid coat to gauge the surface prep levels. This reduces the amount of putty applied and also time taken.
Monday the guide coat will be sanded off and more putty work to fill up the small dents.
Attaching a pic to show the end result of 1 month of body prep. My camera skills are not great so this might not show the true state of the paintjob. BTW the car in the pic WAS a battered ikon which was silver in color.
Old 5th April 2009, 21:47   #4
SuperSelect's Avatar
Thanked: 221 Times
Wow Harrie, this is a unique resto ! The paint is thicker than the sheetmetal . Do a super job on her, and she'll come out looking like new. Do try and get as many original fittings back, as possible especially the door handles wheels, etc. An Ambassador's fittings are what give the car it's character. Cheers !
SuperSelect is offline   Reply With Quote
Old 7th April 2009, 01:48   #5
Thanked: 21 Times
Harrie,
Nice write up and pictures. Please keep the thread updated as it looks interesting plus we are planning to buy a used Ambassador and then undertake a similar job to yours next year.
Also can you post some pictures of the Scorpio (its in the background of one of your pictures) when it has the wheel fitted to the rear door. It will be interesting to see how it spruces up the bland rear of the Scorpio.
bigman is offline   Reply With Quote
Old 7th April 2009, 03:19   #6
abhi1309's Avatar
Thanked: 25 Times
Wow that is a mean looking Amby for sure all because of the big rims.
abhi1309 is offline   Reply With Quote
Old 7th April 2009, 04:27   #7
Roy.S's Avatar
Thanked: 93 Times
I think that these 'labour of love' type of restoration jobs are fantastic. Wish I had the patience to pull off one of these. Hope some engine mods are in the pipeline too.
Most of my childhood journeys were in ambassadors (always white). I learned how to drive on a Mark 2 (I think) amby. At one point of time we had 2 parked in our driveway and I used to sit on the boot lid with a cushion against the rear windscreen and read Hardy boys mysteries.
I will be following this thread closely. Please keep updating.
Roy.S is offline   Reply With Quote
Old 7th April 2009, 04:33   #8
YamahaBoy's Avatar
Real Cool looking Amby with the wheels. Only True Enthusiasts go for an Amby Refurbishment with this kind of passion. So keep it up & keep it coming
Cheers!!!
YamahaBoy is offline   Reply With Quote
Old 7th April 2009, 20:56   #9
muneemmk's Avatar
Thanked: 17 Times
Are those wheels going to be retained after the body and paint job ? what size are those tyres ? What paint is going to be used ? what body fillers ? what kind of anti rust coatings ? am i asking too many questions ?
muneemmk is offline   Reply With Quote
Old 7th April 2009, 21:43   #10
rajivanoj's Avatar
Thanked: 45 Times
Default @ harrie
I have seen this car, is it from kovaipudur? I am seeing this from 1995 . Only change is colour, and once there was apple mac logo in rear, but now it has shell.
by the way, where is your garage? i mean paint shop. Do you deal only painting or even mechanicals?
rajivanoj is offline   Reply With Quote
Old 8th April 2009, 23:09   #11
anjan_c2007's Avatar
Thanked: 4,699 Times
Quite a challenging project if you want to make the car very original. Its not tough as mechanics and body repair work experts still know how and what is to be done with an Ambassador. Especially the wheel arches, the wheel drums and other original touches look the best in the original design. So would suggest you to stick to that design as such modifications do not look aesthetic and appealing.
anjan_c2007 is online now   Reply With Quote
Old 12th April 2009, 19:11   #12
Rudra Sen's Avatar
Thanked: 4,092 Times
Harrie, what's your anticipation about the total cost?
Old 18th June 2009, 14:38   #13
muneemmk's Avatar
Thanked: 17 Times
Bump
Yennagaa Saar,Anything happening there ? would like to see some updated pics of the car.
Old 17th July 2009, 18:06   #14
nevertouchme's Avatar
Thanked: 57 Times
Harrie- any updates yet? Looking forward for more pics on the progress. BTW: Is the engine also being worked on?
Cheers,
Jai
nevertouchme is offline   Reply With Quote
Old 10th March 2011, 17:38   #15
Default Re: Restoration of 1982 Ambassador
How about these examples of a colour scheme for your Amby?
sidvar is offline   Reply With Quote
Ambassador Mark II 1970 - Restoration jeepster09 Post-War 153 26th July 2015 07:27
Life with a 1982 Mercedes W123 300D. EDIT: Car sold! tazmaan Super-Cars & Imports in India 91 23rd April 2014 11:40
My 1982 Mercedes W123 : Completely restored g1_gold Post-War 33 17th June 2012 15:34
Ambassador 61' restoration sunilgee Post-War 45 18th May 2011 12:04
1982 Porsche 924 ajmat Shifting gears 5 3rd July 2004 22:29
