Old 4th May 2010, 16:53   #106
woman.on.top's Avatar
Does installing the box affect fuel consumption/mileage? if yes, by how much??
woman.on.top is offline   Reply With Quote
Old 5th May 2010, 12:38   #107
Thanked: 103,416 Times
If you maintain a conservative driving style (which you will NOT with that extra power / torque), I'd say marginal difference.
Note that the Pete's box that is being discussed here is only offered for diesels.
Old 5th May 2010, 14:21   #108
CPH
Thanked: 34 Times
Any piggy back system that are available for the normally aspirated petrol engines are a waste of time. They can't alter the ignition timing, which is necessary to get the most out of your engine especially when you want to add other performance items.
What you want to do to your engine is:
Properly designed induction
Replacing terrible back box by a proper performance back box
Replace cam (4x4 but could also be 176) by 866 cam.
Re-map on the rolling road.
This will see you a 25% increase through the rpm range.
CPH is offline   Reply With Quote
Old 6th May 2010, 11:20   #109
sarmarishi's Avatar
Thanked: 80 Times
Pete.. will you be coming out with a tuning box for petrol engines? The MPFi Esteem badly needs it!! Please give us something. Not fair that it is only available for Diesels.
I have already installed a K&N performance filter but I do not wish to install the FFE as I did in my previous esteem as I dont want any sound. Do help.
sarmarishi is offline   Reply With Quote
Old 6th May 2010, 13:33   #110
Thanks CPH, wow thats a lot of tech speak. But questions..
1.How is it going to get done?
2. where do I find the components/parts? Not in India, I suppose.
3. How much would it cost??
4. and most importantly, in India, who's going to do it for me???
Anyways, would like to know more so check your mail, Carl.
Old 6th May 2010, 14:59   #111
CPH
Thanked: 34 Times
I think it is best if you start a new thread about it as this one has got more to do with the Linea.
I will supply a re-map as I don't think that a tuning box for the petrol is worth any money.
FFE, when designed properly will not be any louder than standard, but will improve performance more than noticable.
Old 6th May 2010, 15:04   #112
CPH
Thanked: 34 Times
How is it going to be done?
I am planning to do it on your car.
Where do you find the components?
They will find you when I bring them along.
It depends how much you want to do, but will be cheaper than you think.
Who is going to do it for you?
Most likely me.
I checked mail, but can't find any you sent.
Old 6th May 2010, 16:28   #113
sarmarishi's Avatar
Thanked: 80 Times
Are you coming anytime soon to india? When you say "supply" you mean you will re-map the ECu or get a re-mapped ECU for it?
Old 7th May 2010, 12:59   #114
CPH
Thanked: 34 Times
I am planning to do the re-mapping your end.
Old 7th May 2010, 13:16   #115
vinaydas's Avatar
Thanked: 86 Times
well will it be done by you in a private workshop with expensive equipment (i have seen them scan my palio in the Fiat A-S-S through the OBD port for any problems in the fuel flow etc.
or
will it be done using say a hand-held device like a laptop(im not sure about this).
Sorry for sounding opportunistic but is it possible for the 1.2 palio Nv for marginal Gains?
vinaydas is offline   Reply With Quote
Old 7th May 2010, 13:23   #116
mobike008's Avatar
Thanked: 8,319 Times
+1. Been using a Pete's box on my diesel from over 1.5 years and there has been no change to FE which was 14kmpl before and even now its the same despite higher revving.
Only downside with a pete's box, the car under heavy accelaration emanates a lot of black smoke which according to me is an embarrassment.
Old 7th May 2010, 14:27   #117
sgiitk's Avatar
Thanked: 3,883 Times
For the petrolheads without turbocharged engines, CPH is correct in that an add on unit of Pete's type cannot contribute much, as it essentially 'fools' the ECU into doing what you want.
However, esp. in India there is about 10% available in almost every naturally aspirated petrol engine, which is the downgrade done by the vendor to cope with our 'poor' petrol. For example, the Civic is 140bhp globally, but is 'tweaked' to 130bhp in India. Voila a remap to the global specs will gie you 10hp more. Now with BS3 petrol being the minimum (BS3 & BS4 regular is 91RON, and Premium 95RON) from next month, there is no reason to keep this margin of safety. Only avoid the pumps with unofficial additives.
Pete's system essentially uses up about a third to half of the 20-30% margin of safety inbuilt into the engine.
Old 20th June 2010, 19:57   #118
forbhaskarm's Avatar
Thanked: 30 Times
Bump bump
So where are we? No one on T-BHP yet with a Pete'd Linea/Punto MJD?
Alright - lets hear from Swift DDIS owners who've installed Pete's box - should give us some food for thought.
forbhaskarm is offline   Reply With Quote
Old 20th June 2010, 20:19   #119
arishi1's Avatar
Thanked: 12 Times
Originally Posted by forbhaskarm View Post
Bump bump
There is atleast one Punto. Check out here
There are many outside T-bhp
arishi1 is offline   Reply With Quote
Old 20th June 2010, 22:25   #120
sandeepmdas's Avatar
Thanked: 697 Times
I am under the impression that this drawback can be eliminated by installing high-end air filters like K&N or Green Cotton? Appreciate your thoughts on this.
sandeepmdas is offline   Reply With Quote
Grande Punto Facelift: From baby Maserati to Punto Evo EDIT: Punto 'My Life' on pg.7 sushanthr77 The International Automotive Scene 167 25th November 2011 12:02
Fiat Grande Punto / Linea tuning guide? CPH Technical Stuff 15 25th March 2010 15:52
Grande Punto @ 5Lacs, Linea @ 6.5Lacs, Shock Pricing BUSA The Indian Car Scene 273 8th June 2009 13:38
Fiat to delay launch of Linea and Grande Punto ravi@64bhp The Indian Car Scene 199 24th November 2008 19:45
Everybody Needs Somebody (Linea, Grande Punto, Bravo, 500) SumitBahl The Indian Car Scene 21 17th August 2008 13:03
