| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here! |
| | Thread Tools |
| | #1 (permalink) |
| Distinguished - BHPian ![]() Join Date: Feb 2005 Location: Mumbai-India
| Hi Guys Did anybody have installed fuel pressure regulator in an ikon1.6 I belive the stock regulator is integrated in to the fuel rail which is made of Plastic, To install F.P.r we will need to change the fuel Rail also, Any idea how it can be done? |
| | #3 (permalink) |
| No Plans for Turbo, Basic mods intake/exhaust+Head Ported Polished 3 angle valve job and stage 2 Cam 285 deg 4m piper U.K , Got installed Air/Fuel Ratio meter, The Engine runs lean after 3500 RPM when throttled and takes some time to get rich mixture when observed on A/F ratio meter. have spoken to some reputed tuners in mumbai they said you cannot installed F.P.R in an ikon! Plus lots of things in pipeline, which will be step by step Last edited by Ford Rocam : 19th May 2005 at 23:25. |
| | #4 (permalink) |
| Senior - BHPian | dont need to change the fuel rail...need to run the fpr after the stock andsince the pressure is higher the stock becomes a dummy. works perfrectly fine. @mpower...the fpr is not necessarily for a turbo car. helps in NA too.
__________________ ...91 is back !!!! |
| | #5 (permalink) |
| BHPian | The pressure will have to be adjusted when you drive and where it is getting a good amount of pressure.. Usually start at 32 idle and 35~40 or more at acceleration. Adjustment wil have to be done on trial and error.. Depends on what kind of modifications you have done to your car. z |
| | #6 (permalink) |
| Senior - BHPian Join Date: Mar 2004 Location: bangalore
| yeah... install the FPR on the return line after the stock regulator, and you can control the pressure from the new regulator.. will work totally fine.. will also function as a failsafe. Cheers Dom
__________________ Dom@Team-Bhp.Com |
| | #7 (permalink) |
| BHPian Join Date: Jan 2005 Location: mumbai
| sure u can install fpr on a ikon..... on a mpfi its always on the outlet of the line.. so leaving the stock where it is... put in the fpr after the fuel rail ie: on the return line... then adjust it as per requirement.... have already done it on a 1.6 ikon.... works grt...
__________________ nitrous dried but i am still turbo charged |
| | #8 (permalink) | |
| Team-BHP Moderator ![]() | Quote:
Dont mean to complicate you problem, but you mentioned that its lean initially but becomes rich after a while.........thats telling me that there 'is' enough fuel flow once you reach steady state and the leaning is at transient conditions. Seems like a mapping issue to me.....need more 'tip-in enrichment'. (same as what an acclerator pump in a carb does) Have you checked what the AFM shows at full throttle & max rpm at steady state? If its lean even after holding for a while then definetly fuel starvation....which means one of the three need to be changed first................... injectors, FPR or the fuel-pump. You need to figure which is your weak link and change that first. Not sure about this but components from the 1.6 Zetec Fusion may be retrofittable with the Rocam. Another good check is the injector pulse width at max load but you need the appropriate software to do this. Are you using a different intake ? If so, what is the runner length. Did Piper give you a runner length/dia recomendation for the cam. Iceman......thanks for the tip.
__________________ The difference between the men and the boys....................is the speed of their toys. | |
| | #9 (permalink) |
| Hi Mpower and Other Bhpians Thanks for your reply, mm is not for lift it is "from piper - 4m piper" Yes its runs steady rich once pressure is achieved, the 1.6 Ford Fusion is All Alluminium Duratec Engine 16V Twin Cam (whish Ford had given this engine to an ikon!) Since the engine is new here not sure about parts retofittable in an ikon, There was no recommendation from Piper regarding the intake,The intake pipe is slightly bigger but the length is same, Hey ZenGt can u install FPr for me, ? How much time and what costing are involved P.M me pls |
| | #10 (permalink) |
| Hey Guys, At last i got installed Fuel pressure regulator in an ikon , the installation was simple and straight forward , the result was very noticiable i am regretting why i havent installed it earlier, it has compensated a lot in the low end torque which i had lost due to high lift cam, it has helped me a lot in driving in city traffic and i tell u guys u have to ride it to belive it the surge in power i get after 4000 rpm , i just cant describe it will post the pics soon |
| | #11 (permalink) | |
| BHPian | Quote:
__________________ Kishore | |
| Thread Tools | |
Similar Threads | ||||
| Tyre pressure vs fuel economy | sbasak | Technical Stuff | 15 | 27th February 2006 22:31 |
| Electronic Fuel Pressure guage | Ford Rocam | Shifting gears | 6 | 14th January 2006 16:36 |
| Air pressure guages at Fuel Pumps. Do you trust them??? | Shan2nu | Technical Stuff | 12 | 20th November 2005 20:48 |
| Fuel Pump Pressure valve | cheatingdeath | Technical Stuff | 1 | 27th November 2004 11:05 |
| Accords Fuel pump pressure regulatory valve | cheatingdeath | Technical Stuff | 2 | 8th June 2004 11:13 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
