Old 23rd April 2009, 14:32   #16
the_maassk's Avatar
Took a half day off from work this morning to go and look at the progress. Most of the patching work on the car is complete. Will take another day for minor surface soldering tasks. There was indeed a lot of body work that needed to be done. Selected the paint shade this morning. The painter would start the 'surfacing' today evening.
The following items have been sourced:
1. Tail lamp assembly (from an old SS80)
2. Headlamp assembly (same as above)
3. Metal strips that seal the window gaps (the guys call it Harness kit)
4. Channel kit for all windows.
The rubber linings are all good. No signs of aging. The following items need to be sourced:
1. Internal Roof lining (are available locally)
2. Inner door board panels (are available locally) - Am pretty impressed by what Edmund used for his (chequered metal sheets)
Some pics below:
the_maassk is offline   Reply With Quote
Old 2nd May 2009, 12:18   #17
devrajman's Avatar
Thanked: 116 Times
hey, no updates on restoration work? Whats happening, we all are curious!!
devrajman is offline   Reply With Quote
Old 4th May 2009, 09:27   #18
the_maassk's Avatar
Sorry guys, could not do any updates for the last week. Was too busy at work. Anyways - here are some pics from Friday.
Progress so far:
1. Body work all complete, except for rear right side wheel well (the welder overlooked it)
2. Paint job completed. Matt black on the bumpers and other trims, Murray red on the body, Silver on the rims.
3. Whatever was stripped off, has been reassembled.
4. Bonnet hinges were broken. New ones installed (did this one myself).
5. Petrol tank cover redone, painted and installed.
6. Various rubber strips replaced.
7. Electricals partly checked.
The following things are yet to be done (good that I am posting, so that I will have a reference):
1. Seats to be refurbished. The padding on the driver seat is gone completely.
2. Garness strips to be installed.
3. Roof lining to be redone.
4. Electricals to be checked. Flasher to be replaced (damaged). Some bulbs to be replaced.
5. Left side headlamp reflector to be replaced. (Have found one at a junkyard). We had a trip to the city junkyard yesterday and boy, it was an eyeopener!
6. Petrol tank inner cap to be sourced (someone stole the original when the car was parked at Desouza's garage.
7. Tail-light assemblies to be replaced.
8. Internal door panels to be fixed.
9. Polishing the dash, putting on a steering wheel cover etc.
10. Boot glass lock to be fixed.
11. Rear number plate to be fixed.
Other than that, the car rocks! Drove it around a few roads and people were drooling over it
Last edited by the_maassk : 4th May 2009 at 09:28. Reason: Missed out on something.
Old 6th May 2009, 17:38   #19
tantragna's Avatar
Thanked: 23 Times
Hey, that looks good. Make sure the re-done tinkered parts wont rust any further. That would be the most annoying part at a later date, when the corrosion starts to show up. I have been into restoring one of my closest friend's SS80 from quite a period from now. Well I am working on it with my personal interest & efforts. I know it would be a tough time to maintain without any such undesirable results.
Wish you best of luck & great drive ahead!
tantragna is online now   Reply With Quote
Old 6th May 2009, 18:08   #20
tantragna's Avatar
Thanked: 23 Times
One more thing the tail lights should be available in the market under 'Neolite' brand.
Check this link. Automotive Headlamps Manufacturer,Auto Head Lamps,Automotive Head Lamps,Auto Headlamps Manufacturer,Car Head Lamps,Automotive Headlamp Exporters
Old 7th May 2009, 09:11   #21
the_maassk's Avatar
Thanks for the link! I'll go out and hunt for it in the local market. If not, will get in touch with Neolite.
Old 11th May 2009, 09:14   #22
the_maassk's Avatar
Quick update:
The following have been accomplished -
4. Electricals checked. Flasher replaced. Some bulbs replaced.
5. Left side headlamp reflector replaced.
6. Petrol tank inner cap sourced
7. Tail-light assemblies replaced.
11. Rear number plate fixed.
12. Engine mounts replaced.
13. Coolant hose was leaking - replaced.
Old 11th May 2009, 11:08   #23
hillram's Avatar
Thanked: 982 Times
Nice Restoration.Did you manage to find all the original Japanese parts,coz the first 800 ss came with every part made in japan.
hillram is offline   Reply With Quote
Old 11th May 2009, 11:23   #24
the_maassk's Avatar
Am trying to get as much orignials as possible. The tail light assembly however is not a genuine spare. Tried sourcing it but could not find it. The one I got is not bad at all though!
Old 25th May 2009, 14:14   #25
tantragna's Avatar
Thanked: 23 Times
Any updates maassk ? Really getting curious!
Old 20th September 2009, 02:42   #26
ideasingh's Avatar
Following your updates since a while - but no updates for long ? All fine with ur project ?
ideasingh is offline   Reply With Quote
Old 21st September 2009, 09:17   #27
the_maassk's Avatar
@all - The car has been fully restored except for the boot lock and some minor cosmetics! Its running well since the last couple of months. Sorry did not update the thread. Will see if I can get everything together with some pics for an update.
Old 22nd September 2009, 22:31   #28
ideasingh's Avatar
Smile
MASK BHAI -put some pictures - me too getting the adrenalin right - I Have an eye on an old 800 since long - if u & Edmund can do it then i can also try - wanna see your final product in a good photoshoot :-)
Old 1st December 2011, 11:43   #29
Thanked: 120 Times
Default Re: Restoration project - Maruti 800 (SS80) 1984 model
any updates on this one?
fx45 is offline   Reply With Quote
Old 8th May 2013, 03:31   #30
rockporiom's Avatar
Thanked: 761 Times
Hey no updates on this thread from two years?
rockporiom is offline   Reply With Quote
Restoring Maruti 800 SS80 (1985 model) beetle_boy Modifications & Accessories 32 27th December 2017 20:49
Need a good car restoration guy for my Maruti Suzuki 800 (1984 model) ashishc100 Modifications & Accessories 10 12th October 2011 18:36
Buying Suzuki SS80 1984 model anarchist Hatchbacks 32 1st September 2009 06:34
Wanted 1984/1985 Maruti Suzuki SS80 DX ajay99 Shifting gears 4 27th January 2008 11:48
