Old 1st May 2009, 11:47   #1
akshay_b's Avatar
Default Fog lamp wiring and switching-Help needed.
Hello people,
I'm planning to get fog lamps fitted on my santro xing and I'm not willing to spend 8k on original ones, So i went to a near by car accessory shop and got a quote of 1.5k for LUMAX branded fog lamp for santro + 300Rs for labor and wiring.
The accessory dealer uses a regular on/off switch but my santro comes with a slot which can accommodate a fog lamp switch which i bought from a hyundai dealer.
The switch has 4+1 connector, and an LED indicator in the front which goes on when the fog lamps are turned on, I just need help in telling the mechanic to do proper wiring so that even the LED comes on when the fog lamps are turned on,
All you electrical experts pls help out.
akshay_b is offline   Reply With Quote
Old 23rd June 2011, 23:49   #2
abk
abk's Avatar
Thanked: 9 Times
Default Re: Fog lamp wiring and switching-Help needed.
Bumping this thread up as I have a relevant question.
I need to install fog lamps for my Santro Xing. However, i couldn't locate a slot where I could fit the switch in. From the pictures posted by you, akshay_b I couldn't quite guess where that switch fits in. If you could advise will be very useful. I will not prefer drilling hole through the dash & fit a antiquated push-pull type switch.
abk is offline   Reply With Quote
Old 24th June 2011, 13:34   #3
akshay_b's Avatar
The fog lamp switch goes into the center slot, Check out the pic.
P.S- That is not my car!
akshay_b is offline   (1) Thanks Reply With Quote
Zen MPFI wiring manual/wiring diagram IndrojitSircar Technical Stuff 1 27th February 2012 00:21
Punto music system (not stock) not switching off after switching off engine!! praz Technical Stuff 17 9th March 2011 09:55
FOG lamp suggestion for ZEN shapath Modifications & Accessories 4 24th November 2007 06:45
Paint-Plastic-Xenon Fog Lamp Ageing Issues with my Lancer wolfinstein Modifications & Accessories 2 25th October 2006 11:12
Need Info: Sunfilm/SeatCover/Power Window/Fog Lamp souravbasu Modifications & Accessories 3 3rd April 2006 10:53
