Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 29th May 2005, 13:05   #1 (permalink)
Sankar's Avatar
Default Blow-thru turbo on a carb engine:How do you do it?
How do you turbo a carb engine? As far as i know one of the biggest problem in a blowthrough carb engine is the jetting. If you don't equalize the pressure i've read that jetting could never be set right. Those who have turboed their carb cars how did you do it, Did you build a pressure box to enclose the carb? Those who don't have a pressure box how do they equalize the boost and carb pressures?
Another method i've heard is equalizing only the carb float bowl pressure with the boost pressure, boxing is not done. This is done by connecting the float bowl with the turbo boost, am i right? How effective is this?
I had a turbo project in my mind. But after reading and hearing about the jetting issues and additional hardware needed to control fuelflow in a blow-through turbo system i'm getting double thoughts on it. Right now i'm considering a draw-through turbo system. I know it's a bit inefficient, it's neanderthal, i can't use intercooler or run higher boost and a bov would waste fuel if vented to the atmosphere. But on the plus side it's less expensive so i can easily afford and is okay to run mild boost.
This is an idea i have in mind, the would be turbo victim is an 800. I need suggestions & ideas on this one from our turbo experts on this forum.
Old 29th May 2005, 13:43   #2 (permalink)
iceman91's Avatar
psycho is the best person. has done it already and trust me it works!!!
__________________
...91 is back !!!!
iceman91 is online now   Reply With Quote
Old 30th May 2005, 12:46   #3 (permalink)
Psycho's Avatar
Well these questions plagued me too for a while till I decided to take a plunge. I happen to be running a blow through with a max boost of 8 PSI, have compensated for the fuel pressure by adding an additional fuel pump, as for the BOV I havent even bothered to put in one have just left a leak in the plumbing and no intercooler either just use the fuel filter box as a plenum to expand the air before it goes into the carb. The setup is working beautifully (not as a performance vehicle as it happens to be a petrol contessa.) and by the way my jetting hasnt been changed from Naturally aspirated settings, however the carb (I wasnt using the conti carb anyway) I am using does have a pressure equaliser line for atmospheric pressure and this works for the boost too.
__________________
Learning is a continuos job that keeps me busy.
Old 30th May 2005, 23:34   #4 (permalink)
Sankar's Avatar
What carb are you using? If the carb doesn't already have a pressure equaliser then can one be added, like giving a line to the float chamber. If you're using an additional fuel pump (which is supposedly pumping at a higher pressure) then how does your carb float & needle hold up, woun't you get overflow and isn't a fuel pressure regulator needed? These things are worrying me and if these can be solved then blow through is the way to go.
Old 31st May 2005, 00:07   #5 (permalink)
Psycho's Avatar
Well you are welcome to come over and see the goodies yourself call me at 98440 69863
__________________
Old 31st May 2005, 01:39   #6 (permalink)
Sankar's Avatar
Of course, thank you I'll be in Bangalore after 19th of this month and i'm paying you a visit.
Thread Tools
Blow Off Valve For Turbo Mugen_Power Technical Stuff 9 21st July 2008 00:37
Turbo? NOS? Engine Swap? High CR NA build? How would you modify your engine? mclaren1885 Modifications & Accessories 50 26th March 2008 10:55
Carb/MPFI - Which is having longer engine life ? mithun Technical Stuff 47 10th October 2007 01:58
Performance Mods for M-800 Carb Engine sumeethaldankar Modifications & Accessories 3 15th May 2007 00:07
Carb Zen: How much engine power required by the AC? mtnrajdeep Technical Stuff 8 16th April 2006 20:41
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
