Old 12th May 2009, 16:40   #61
crazydiablo's Avatar
Thanked: 21 Times
Those seats are lovely, very tight fit yet comfortable. Very well made obviously. The foam was pretty good and excellent thigh support.
crazydiablo is offline   Reply With Quote
Old 12th May 2009, 16:56   #62
narayan's Avatar
Thanked: 1,356 Times
question to Rd and all other mod gurus
how much difference did it make to start this project with the VTEC engine rather than a stock 1.5 ?
i have the latter and would like to know whether the stock 1.5 can be brought up to speed in the same manner despite lacking that famed VTEC head ?
narayan is offline   Reply With Quote
Old 12th May 2009, 17:21   #63
nitrous's Avatar
Thanked: 285 Times
Well, you can get a racing cam. Something like a 300 profile one.
But, don't think about having it as a daily driver,then. You won't have any bottom end torque.
Old 12th May 2009, 19:57   #64
rdkarthik's Avatar
Thanked: 11 Times
For all out power it would be almost identical, provided the right parts are available.
rdkarthik is offline   Reply With Quote
Old 13th May 2009, 00:46   #65
iceman91's Avatar
Thanked: 22 Times
would cost factor be the same too karthik?
or would one be cheaper ??
iceman91 is offline   Reply With Quote
Old 13th May 2009, 01:23   #66
The Wolf's Avatar
Thanked: 58 Times
The modification costs we reckon would remain fairly in the same region...however the running cost of a non VTEC would be more if driven daily without plucking the performance cam out.
The Wolf is offline   (1) Thanks Reply With Quote
Old 13th May 2009, 09:09   #67
iceman91's Avatar
Thanked: 22 Times
why, won't both have cams changed? So vtec can be driven daily with the cam?
Old 13th May 2009, 11:02   #68
Torque350's Avatar
All I can say is WOW!!!! I'm mind blown and speechless. That is a fantastic job. Never seen anything like that so far. Hats off to you guys, great job
Well I'n not very sure but I think the VTec has two cams. When in lower RPMs there is one cam working, at higher RPMs the other higher powered cams replaces the lower ones. So when changing cams the lower stock cams remain the same but only the higher rpm cam is replaced. In the normal 1.5 there is only one cam. This makes the VTec a little cheaper for daily runs.
Correct me if I'm wrong.
Torque350 is offline   Reply With Quote
Old 13th May 2009, 11:13   #69
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
The Vtec here is also a SOHC (single over head cam) only. It is just the cam profile that changes.
Like Amit said, I wonder why the running costs of the 1.5 would be higher. Wolf, what all conversions need to be made if one was to replace the 1.5's cam with a 300 deg + Vtec aftermarket cam? I am guessing one should begin with the ECU to handle the Vtec. Then...
Old 13th May 2009, 11:20   #70
Shan2nu's Avatar
Thanked: 89 Times
Well if you include the cost of buying the car, i think the 1.5 would be a cheaper build.
VTEC has only 1 cam but 2 cam profiles (only for the intake valves). The benefit of moding a VTEC is that you can have a very aggressive profile for higher rpms without sacrificing low end driveability and FE.
Shan2nu
Shan2nu is offline   (1) Thanks Reply With Quote
Old 13th May 2009, 11:36   #71
doomsday's Avatar
Post
Add to that the VTEC solenoid which controls the activation/deactivation of the VTEC lobe, and associated paraphernalia. But I still doubt if it can be done since the VTEC involves an extra center rocker arm which allows the valves to be opened by two different cam profiles. Instead, plonking a VTEC head on the 1.5 with ECU and harness to match would be a better call.
Compared to a VTEC head, a non-VTEC will only lose out of the daily usability and driveability aspect since there is only a single cam profile which will be in use at all times, whether you are negotiating peak traffic at 1000-2000rpm or WOT @8000. Assuming one has some 300+ profile non-VTEC cam, it will translate to a lopey idle and rough operation at lower revs where all that high-lift and duration isn't really needed. VTEC is like having two cams with different characterstics- one with less agressive characterstics for puttering around town and the other high, agressive profile for WOT performance. This combination of mild and wild makes up the VTEC magic.
However, as Karthik said- on an all out power-build with no compromises, the non-VTEC can be at par with VTEC- when driveability and daily usability isn't a criteria. In fact, the quickest single-cam Honda in the world is a non-VTEC.
doomsday is offline   Reply With Quote
Old 13th May 2009, 11:43   #72
Shan2nu's Avatar
Thanked: 89 Times
Same goes for the Honda F1 engine. They never bothered using VTEC bcoz it wasn't really needed.
Shan2nu
Old 13th May 2009, 12:08   #73
Thanked: 35 Times
Rishi, I know how the Vtec works. But when you go for an aftermarket cam for eg a 300 deg+ on the secondary profile, how low can the primary cam profile be setup for? I am assuming that as the secondary profile gets more wilder and wilder, accordingly the primary profile would also see a change while the cam is being built? Or do cam manufac's keep the primary stock and just change the VTEC profile? Since I have no hands on experience ordering VTEC cams I am just curious to know.
Old 13th May 2009, 12:14   #74
iceman91's Avatar
Thanked: 22 Times
The primary also changes to an extent, hence my question.
Old 13th May 2009, 12:21   #75
Thanked: 35 Times
Exactly my point. But since I have never dealt with ordering cams or custom grinds for Honda's I am curious to know to what extent is the primary profile kept close or near to stock. Or what percentage of difference would the primary have (in terms of a wilder profile) as the secondary profile changes to race spec.
Help-Petes box or Race Dynamics piggyback ECU for Optra Magnum dockap Modifications & Accessories 66 9th December 2017 12:22
Turbocharged Honda City VTEC story A Race Concepts build! speedfreak Modifications & Accessories 8 12th December 2014 03:01
Race Dynamics : The tech review Psycho Technical Stuff 123 3rd October 2013 00:29
