Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here!
Thread Tools
Old 19th May 2009, 12:14   #76 (permalink)
ram_hyundai's Avatar
I feel the baleno would be the best choice,As v1p3r told spares Wont be that easy for the 98Model civic.So dont waste time-get hold of her soon.Can we have a clue on the color,lolz.
ram
__________________
Back home after a looong break he he he
ram_hyundai is offline   Reply With Quote
Old 19th May 2009, 14:52   #77 (permalink)
karthik247's Avatar
So will be sticking with the Baleno only.. Started looking for the parts, will be getting tires this week.
BTW are there any lowering options available for the Baleno??
__________________
Mitsubishi Cedia - Pearl White
Skoda Octavia vRS - Magic Black
karthik247 is offline   Reply With Quote
Old 19th May 2009, 15:29   #78 (permalink)
cooldude1988765's Avatar
Karthik the baleno is already pretty low. If you lower it any further you cannot drive over speed breakers anymore.
__________________
I never thought it was humanly possible, but this both sucks and blows.
- Bart Simpson
cooldude1988765 is offline   Reply With Quote
Old 19th May 2009, 15:49   #79 (permalink)
crazydiablo's Avatar
yes lowering springs are available for the baleno.
crazydiablo is offline   Reply With Quote
Old 19th May 2009, 18:08   #80 (permalink)
fieroid's Avatar
what size pistons were you guys using for the big bore build? someone here said 76mm Honda? What mods are done on the head to get better gains?
__________________
There is more to life than incresing its speed!
fieroid is offline   Reply With Quote
Old 19th May 2009, 18:16   #81 (permalink)
karthik247's Avatar
We're not doing a big bore.. would be doing a turbocharge on it.
__________________
Old 19th May 2009, 18:24   #82 (permalink)
mclaren1885's Avatar
Infractions: 0/1 (10)
Joel (I guess), I was using 76mm Honda pistons. I had a word with the man who has perfected the art of using these pistons to run big bore baleno's. He mentioned something on the lines of a complicated process of honing to be done and a lot of other parameters to be kept in mind. Since I was short on time and was marshaling the Nandi Hill Climb I could not get into a detailed conversation over it. Once he comes back, I shall find out all the details and keep you posted.
I think Amit was running 78mm pistons when running the 1.8L mill?
Old 19th May 2009, 18:40   #83 (permalink)
I can guess the man who has perfected this art. I dont think 76mm would give you 1750cc which is the big bore for baleno. Just an oversize piston is not a big bore baleno. Yes a lot of parameters should be kept in mind other wise you have n number of issues.
So we will see a turbo baleno soon. Thats nice, give us more details.
Old 19th May 2009, 18:45   #84 (permalink)
You are right, sorry I got confused between big bore and oversize. 75.5mm gives your roughly around 1611cc and 76mm I hear gives you around 164x cc.
Old 19th May 2009, 19:28   #85 (permalink)
fieroid's Avatar
There are number of things to keep in mind when taking the big-bore route. If done well, it should work as well as your stock engine, provided you're not running radically high compression and taxing the bottom more than it can take.
Ok, what about the head, stock valves? was the head flowing more for a big-bore? I dont mean porting and polishing now.
__________________
Old 19th May 2009, 19:46   #86 (permalink)
I dont think big bore will tax the bottom end. Thats not your worries, there is another fundamental design flaw in the Baleno which is not very conducive to overboring. The bore and stroke of the J18 is different.
Old 19th May 2009, 20:24   #87 (permalink)
karthik247's Avatar
Need to pick up 15" Konig wheels, so guys help me out on the following designs..
__________________
Old 19th May 2009, 20:52   #88 (permalink)
I liked all except the 2nd. 5th and last one. Last one would look good on red.
EDIT: I could pick one if i knew the colour of the car.
__________________
- Bart Simpson
Old 19th May 2009, 21:06   #89 (permalink)
IronWolf's Avatar
What is the color of the var you finalized?
I'd say the thumb rule is deeper the Lip for the rim, the better it looks.
I vote 3 > 4 > 1 in that particular order.
__________________
You'll have mud in places you didn't know you HAD.
- Sarge's take on Offroading.
IronWolf is offline   Reply With Quote
Old 19th May 2009, 21:07   #90 (permalink)
The third and sixth designs are really good . What colour are you looking for ?
Mistakenguy is offline   Reply With Quote
Thread Tools
Need help. Want a CD Player for Baleno. Budget Strictly max Rs. 6K. aaggoswami Ask the Gurus 29 3rd February 2009 08:30
7.5l budget, including mods for a diesel car. nikhilv12 Sedans 56 30th September 2007 10:51
used Accent (petrol) or used Baleno (budget 3 lacs) gopz Sedans 33 5th September 2007 12:34
Baleno Low Budget Icing hari_rama Ask the Gurus 46 7th February 2007 00:09
mods on a budget for my palio 1.2 jalsa777 Modifications & Accessories 13 27th August 2006 01:52
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
