Old 7th April 2009, 15:04   #1
Thanked: 13 Times
Default Maruti Alto 2005- Engine Upgrade
Hi All. I am planning to have a WagonR 1.1L engine plonked in my alto. I am hoping that mounting the same would not be a difficult job as the mountings should nearly be the same. Please advise if it is a feasible thought. This might be an engine from some car sold as total loss in mayapuri
Also please recommend if I could put in Power Steering assembly in Alto Lx, may be an after market one or may be from some old car. Can a WagonR EPS be fitted on to Alto?
Also whats the sort of cash outflow I should be looking at for these upgrades?
Note from Team-BHP Support : Thread MERGED. Please use the search feature before creating a new thread on a topic that might already exist. Please continue your discussion in an existing thread. This will keep all the relevant information in one place and make it easier for readers in the future.
Last edited by Jaggu : 7th April 2009 at 15:08. Reason: Take a minute, use search for your doubts, then open a new thread. Thanks
tajender is offline   Reply With Quote
Old 7th April 2009, 17:27   #2
predatorwheelz's Avatar
Thanked: 1,103 Times
Tajender,
My replies in Bold
Yes, its a very feasible thought. The Wagon R engine is nothing but the Alto 3 cylinder engine with one extra cylinder! The Alto engine essentially comprises 3 cylinders of approx 265.3cc each (hence 796cc). The Wagon R engine was made by adding one extra cylinder to the same block, hence the 1061cc capacity.
The Alto's engine bay is big enough to accomodate the larger engine. In fact when the Alto was first launched in India, the VX model did come with the 1061cc, which Maruti later discontinued.
There are no major mechanical modifications required, as long as the engine you are fitting is in sound condition.
Fitting power steering is an easy modification which you can get done at any MASS. However, this might prove expensive.
This is anybody's guess. Depends on how well you bargain with the Mayapuri dealer! The EPS system should be around 30K.
predatorwheelz is offline   (1) Thanks Reply With Quote
Old 7th April 2009, 17:32   #3
Psycho's Avatar
Thanked: 95 Times
I am not too sure if the mount points are the same.(May be wrong though)
Old 7th April 2009, 17:47   #4
vikram18's Avatar
Thanked: 19 Times
Wouldn't it be a lot easier just buying a used Alto 1.1 VXi ? You'll get the power steering too!
vikram18 is offline   Reply With Quote
Old 7th April 2009, 17:54   #5
Default Price dice
Hehehe! Yes, an alternative but practical viewpoint. Considering the VXi (with 1.1 ltr engine) was discontinued 5 years ago, you might as well just buy a second hand VXi with the money you would otherwise pay to modify the LX!
predatorwheelz is offline   Reply With Quote
Old 17th April 2009, 13:56   #6
Thanked: 13 Times
The thing is that I already have an Alto LX and am in no mood of disposing that off. I checked with someone in Mayapuri and I could settle the deal till 12 grands for a 14K Kms old WagonR engine. It was coming from a vehicle which was shown in for a total loss. He was also offerring the EPS assembly for 18 grands however I didnt show much of interest in EPS as I doubted the functionality, however am still much inclined on the WagonR engine. If the mountings for the engine are not an issue, then I can definitely pick that one up and have it plonked in my car. The engine that I found was really in gem of state and he was ready to sell the gearbox off for another 6 grands. Pretty decent deal if it is of some worth.
Old 27th May 2009, 01:50   #7
YC.BALENO.CHD's Avatar
Thanked: 89 Times
Well, I think that the 1.1 should be a straight fit for the alto. However, if anyone here has any idea about it, I would like to know if the engine bay of the 800 is large enough to accomodate a 1.1 litre engine with the 5 speed transmission. I had been thinking about going ahead with such project since sometime and was even getting a wagonr's motor with around 32K clocked, but due to the denial of all local mechanics I contacted had to drop the idea. The mechanics were not sure, as they had done nothing like this job before, couple of them had plonked g13s in the zen and diesel units in the gypsy but never have they done a swap for the M800.
Awaiting replies.
Regards.
YC.BALENO.CHD is offline   Reply With Quote
Old 27th May 2009, 16:09   #8
Thanked: 41 Times
he was ready to sell the gearbox off for another 6 grands. .
isn't the gear box on Alto 0.8 and Alto 1.1 same?
monty9991 is offline   Reply With Quote
Old 27th May 2009, 18:16   #9
im_srini's Avatar
Thanked: 368 Times
Infractions: 0/1 (5)
Smile
If the engine has really run for only 14K Kms, its a very good deal. Ensure that the engine runs good & that you get everything with the engine required to run it.
Not a good price, if I remember correct, a new unit itself costs around 20K.
The F10D was offered in the Vxi, so you will not have an issue in swapping it for your F8D. You'll need to get the engine mounts for the Vxi though (they aren't that expensive).
Very nice price, I'd buy it just to have a spare gearbox to fool around with
Tajender, nice endeavor, if you ask me Maruti should never have dropped the F10D from the Alto. Anyway, my advice is to do your research & draw up the complete list of parts required for this swap - the more prepared you are, the less surprises you'll face later.
I think so too, but the ratios have to be different (will confirm this from the parts catalog & service manual).
im_srini is offline   Reply With Quote
Old 27th May 2009, 19:26   #10
badboyscad's Avatar
Thanked: 154 Times
Few questions that have been in my mind for long:
Can the 1.3L esteem engine be plonked into a 2007 alto?
If yes, then what are all the other parts(like gearbox,ECU,brakes, etc) that needs to be changed?
Will it require any modification to the firewall?
How much will the entire conversion cost approximately(approx break up cost would help a lot tough)?
Can the conversion be done in chennai, if yes, then where in chennai?
badboyscad is online now   Reply With Quote
Old 28th May 2009, 09:25   #11
im_srini's Avatar
Thanked: 368 Times
Smile
Hi Monty, you are correct, the transmissions on both the Lx & Vx are identical (even the ratios) ! To compensate for the smaller F8D however, the differential gear (final-drive) is different
Old 28th May 2009, 10:19   #12
amit_mechengg's Avatar
Thanked: 1,540 Times
what all components will be needed to swap the entire engine and make it work in alto 0.8?
i think the wire harness, ecu etc will also be needed?
Old 28th May 2009, 10:40   #13
im_srini's Avatar
Thanked: 368 Times
I think this would be an "interesting" endeavor, or at the least, a nice thought experiment. The Alto parts-catalog should be able to help with this list.
Amit, surprisingly I don't remember seeing different part numbers for the Lx & Vx PCMs (ECU). Anyway, will go through the catalog & put up a comprehensive list of parts needed for this swap...
Old 28th May 2009, 11:06   #14
ilangop's Avatar
Thanked: 578 Times
Hi all,
A garage fellow in our neighbourhood just scrapped an Maruti 1000, but had retained the engine and gearbox with him. I am planning to experiment if the 5 speed could be plonked into the Maruti 800 (carburetted) of my colleague's. Has anyone already tried this out? or at least studied the feasibility. If so please pour your experience so that we learn before burning our fingers.
-Ilango
ilangop is offline   Reply With Quote
Old 28th May 2009, 11:27   #15
Ramsagar's Avatar
Thanked: 38 Times
@badboyscad: Alto 0.8 can't accommodate 1.3ltr eng.the max it can only have 1.1ltr.
@Tajender: 12 grands for a 14K Kms old WagonR engine is a steal but
a) Find a reliable person who has done such kind of jobs in dehli.
b) Get the list of spare to be procured from the WagonR. (Its good if the person visits the place & takes a look @ the engine.)
c) Calculate the price of the original spares against the parts of wagonR. If there is a marginal difference in the new price,better to go for new ones,as these may not be reliable when dealing with accident vehicle.
d) if you get a nice deal Better to purchase the whole machinery (apart from the body) from the wagonR instead dealing part by part, where you can benifit,else you end paying more like the EPS.
@ilangop:i'm not sure if you can do it for carburetted,but can be done for MPFI.
Ramsagar is offline   Reply With Quote
Maruti Suzuki Alto : Tyre & wheel upgrade thread abhibh Tyre & Alloy wheel Section 361 24th October 2017 10:36
Maruti Alto 800: Wheel & Tyre upgrade ariendj Tyre & Alloy wheel Section 7 24th July 2017 10:45
Maruti Suzuki Alto 800 and Alto K10 get optional driver's airbag on all trims Rajeevraj The Indian Car Scene 18 18th August 2016 21:33
ICE upgrade : Maruti Alto Heman In-Car Entertainment 7 11th October 2011 22:55
SPOTTED :2 mini motos , 1 Kawasaki Vulkan , 2005 CBR 1000RR n 2005 ZX10R varun_patra Super-Cars & Imports in India 1 31st October 2005 12:45
