| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here! |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Aug 2006 Location: Hyderabad
| Hi everybody. I just purchased Fiat 137D 1995 model 15 days back. It was previously column shift gearbox. Previous owner has changed to floor shift using the kit availabe in the market. But the gear lever is not working properly, mainly in First and Reverse gear. I gave the car for engine overhule. So at this time i want to change the gerbox. I like 118Ne gearbox. So i need suggestion from everybody. Is is direct bolt on fit ? or i have to do some modification. I am also attaching photos of my gearbox. Thanks S. Das |
| | #3 (permalink) |
| Team-BHP Support ![]() | Shouldn't be too difficult as Premier themselves sold the Padmini 137D with a 118 gearbox in later years. The two were also paired in the 138D (diesel 118NE). Do look up this thread (Fiat a.k.a Premier Padmini 137D) for more information on the 137D.
__________________ GTO Work backward from your imagination, not forward from the past!
| | #5 (permalink) |
| BHPian | Hi Mituadas, The starter motor is positioned on the right side of the engine where as in yours its in the left. I am not sure about my second observation, Need to check if the bellhousing could be separated from the gearbox so that you have the option of making an adapter plate in between the 118NE gearbox and the 137D bell housing. |
| | #6 (permalink) |
| Team-BHP Support ![]() Join Date: Feb 2004 Location: Bombay
| As Salil_pawar mentioned, do PM DHABHAR.BEHRAM, as he will be able to provide some useful information. Also, heres a related thread (though im not sure if it has any info on the 137D) : http://www.team-bhp.com/forum/post-1...on-thread.html (The FIAT 1100/Premier Padmini Technical Information thread.) cya R
__________________ The memory of you will ride by our side forever. |
| | #8 (permalink) |
| Senior - BHPian | Congratulations Mitua Das on buying the Premier 137D. there are hardly any discussions on this car now a days. I had almost forgotten it existed. Our memories are so short. I had almost ended up buying a white 1996, 137D in 2002 as my second car. The asking price was Rs 45 K, a quite reasonable price then.But the rusting below the mat and the lower part of the doors made me change my decision. Though I liked the torquey,but noisy engine of the car. Its a very economical car to use. Please post pictures and keep us informed about your car.
__________________ Better drive Safe, Better be Late, Better Adopt Defensive Driving-ROAD RAGE IS BEST LEFT TO APES AND MONKEYS! |
| | #10 (permalink) | |
| BHPian | Quote:
Regards, Adheesh Parelkar
__________________ There is only one way to do any job perfectly and that is the ONLY correct way. | |
| | #11 (permalink) |
| For purchasing gearbox i went with my mechanic. He told him for 118NE gearbox. But the shop owner showns us 2/3 type of different gearbox of 118NE . My mechanic check all these with a 137D engine which was laying there and finally he choose this one. Mechanic told i do not have to chage plate also. Only thing i have to change is Flywheel clutch plate. Anyhow from that shop i got the 118Ne fly wheel. So i have not confirmed it is from 137D or 138D gearbax. Any way others suggestions are most welcome. S. Das |
| | #12 (permalink) |
| I have changed the gearbox. Total works done is engine complete overhule,gearbox swaped and front suspension. Now i am loving to drive my 137d rather than my M800 and Santo. I am getting lots of black smoke while pressing acceleter pedal. My mechanic told to do a service of injection pump. Should i go for it or any other way to reduce the smoke. S. Das |
| | #13 (permalink) |
| Newbie Join Date: Jan 2009 Location: Thirunelveli
| Please go for the pump service, but do it with the genuine (authorized) service people. Wish you good luck.
__________________ GASOLINE You must be the change that you wish to see in the world. - Mahatma Gandhi |
| Thread Tools | |
Similar Threads | ||||
| Fiat a.k.a Premier Padmini 137D | ramzsys | Long-Term Ownership Reviews | 34 | 11th September 2009 20:00 |
| Premier Padmini 2007 - Engine Swap | eatdust | Modifications & Accessories | 73 | 17th June 2009 16:30 |
| Used Maruti800, premier padmini , premier 118ne ? | sakharamcool | Hatchbacks | 8 | 27th May 2008 12:17 |
| Need a Premier Padmini S1 | kavesh55 | Shifting gears | 0 | 27th December 2007 14:48 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608
