Old 4th June 2009, 17:47   #1
mxx
Thanked: 104 Times
Default suspension mods
I am planning to buy a used sedan to do some performance mods, probably civic or magnum.
One thing I feel is a big problem in sedans is the GC which is way too low for the roads in my city. It is almost impossible to clear a bump, unless the car comes almost to a standstill.
So, my question is, can I increase the ground clearance when I install performance suspension like Koni? Cos I might anyway install these, so if I can increase the height a little bit, it will be an added advantage.
mxx is offline   Reply With Quote
Old 4th June 2009, 17:54   #2
rjstyles69's Avatar
Thanked: 795 Times
Koni's doesn't increase the cars GC AFAIK. Coil-overs will be the way you need to tread if you are looking at increasing the height and these aint cheap. However wait till the experts confirm.
Old 4th June 2009, 21:35   #3
crazydiablo's Avatar
Thanked: 21 Times
There are a few civics running around with lowered suspension in Bangalore.
Now coming back to your question, you can get adjustable suspension and stiffen the suspension so that the car does not bottom out on speed breakers. Combine this with a tyre/alloy combo which gives a few mm of ride height will be the ideal solution.
Raising the ride height has a negative impact IMHO. Incase you decide you need to get coilovers with ride adjustability to do that.
crazydiablo is offline   Reply With Quote
Old 5th June 2009, 10:30   #4
iceman91's Avatar
Thanked: 22 Times
Get Pneumatic with Height adjustable control in dash.
p.s. I have a baleno with stock GC yet to bottom on any bangalore bump. yes modded suspension.
iceman91 is offline   Reply With Quote
Old 5th June 2009, 10:51   #5
theMAG's Avatar
Thanked: 1,573 Times
OT - but if you have to chose between the Magnum and Civic - go for the Magnum diesel. You'll be anyway addressing its only current flaw with your suspension upgrade- soft suspension; and it'll fly like no other car around it - with a diesel tuning box.
Old 5th June 2009, 18:41   #6
Rehaan's Avatar
Thanked: 25,042 Times
MXX,
Go to the SEARCH TEAM-BHP box on the top right of the page,
Type increasing ground clearance
You should get atleast 10 related threads, as well as one that focuses on the civic.
cya
R
Old 5th June 2009, 20:59   #7
Thanked: 21 Times
Pneumatic with indash height is gonna cost a bomb.
Old 8th June 2009, 11:39   #8
iceman91's Avatar
Thanked: 22 Times
he dint mention any budget
Simple / Effective Suspension Mods in M800 Trust_In_Thrust Modifications & Accessories 3 22nd November 2013 08:07
Suspension Mods for Gypsy MexXxentric Modifications & Accessories 9 28th March 2010 20:17
NHC Suspension at 62,000KM - Want a better alternative to the OEM Honda suspension anandpadhye Technical Stuff 15 13th September 2008 18:56
Suspension and engine Mods for Alto LX! speedzak Modifications & Accessories 128 18th July 2008 15:46
Suspension mods for Innova - doable ? Hatari Technical Stuff 6 30th April 2008 14:10
