Old 18th June 2009, 00:34   #1
Question Need suggestions on full body repainting (possibly color change) of Mondeo
I own a Mondeo that I bought almost a year back although many TBHPians advised me against it. It is a Dec’ 2002 model and had 48k kms on the odo. The car is fantastic and I don’t have to say anything about its handling prowess. It’s an absolute delight to drive. It is so good that my 4 years old fully pimped Corolla started gathering dust. I finally ended up selling it to my friend for peanuts.
But my Mondeo started showing its age even though it ran without any major issues, the only exception to this is the rear suspension. Sorting it out was really a frustrating experience and this frustration is mainly due to incompetent dealers. It is a long story and it needs a separate thread in Long-term ownership reviews section. So I decided to take things into my own hands and completely refurbish the car and get it back to the showroom condition to the extent possible.
After spending lot of time and money, refurbishing is almost over. I replaced all worn out parts. Also, as a precaution, replaced all parts that showed some sings of wear and parts that may have possibly failed in future. I have till now spent 4 lakhs to restore the car. Some of the parts that were replaced are Flywheel (DMF), Clutch assembly, Clutch cylinders, Fuel pump, Water pump, Engine and Gearbox mounts, Thermostat, Coil pack, Spark plugs with leads, Idler Pully, Tensioner, Brake discs and pads, Shocks absorbers, Coil Springs, Lower Arms at front, Trailing and lower arms at rear, Rear Subframe bushes, Antiroll bars and bushes, Rollbar drop links, left drive shaft, Tie-rod ends, Headlight Xenon bulbs and lot of other small bits and pieces. Please note that not all the above parts have failed, most of them were replaced just to get that feel of a new car.
After all the changes it indeed runs like new. But the exterior is showing its age and the paint coat lost the sheen. Also there are lots of scratches all around but no major dents. I plan to give it a full body repaint and possibly change the color. The original color is Stardust silver. Mondeo looks good in Black but I am inclined to some lighter shade of Red (shade that is on Innova).
So now coming to the topic,
1) What would be cost for a full body repaint?
2) Is it advisable to change the color, any adverse effects?
3) What would be cost for the change of color?
4) What color would you suggest?
5) Any recommended places in Bangalore for full body repaint? Should I only go to garages with dedicated paint booths?
I would really appreciate any suggestions in this regard.
Thanks,
Novice
novice is offline   Reply With Quote
Old 18th June 2009, 01:26   #2
McLaren Rulez's Avatar
Thanked: 474 Times
http://www.team-bhp.com/forum/techni...detailing.html (Car Detailing?)
Maybe you want to do that instead of a full body repaint?
McLaren Rulez is offline   Reply With Quote
Old 18th June 2009, 08:18   #3
muralisk's Avatar
Thanked: 9 Times
2. In case you change to a different color that what it was during the registration, then you need to get the same updated. Also, check if you need to inform the RTO about the same.
4) Black.
5) I would recommend Bangalore Motor Work on Hosur Road, near Adugudi. This workshop is right in front of IBP gas station and you can check with Santosh. He owns the place.
muralisk is offline   Reply With Quote
Old 18th June 2009, 08:36   #4
crazydiablo's Avatar
Thanked: 21 Times
Can you post some pics? You should give detailing a try before the full body repaint unless u are keen to change the colour.
crazydiablo is offline   Reply With Quote
Old 18th June 2009, 09:55   #5
Thanked: 2,460 Times
35 - 40 K for any color, Paint being dupont / 2k
Zero adverse effect, No troubles with RTO also.
Refer your question 1
Let me know if you need help
Thanks,
Novice
Hey you dont seem to be a Novice after taking care of you car so lovingly.
My replies in Bold.
Old 18th June 2009, 21:48   #6
Thanks for the suggestions.
Detailing may not be enough. In many places especially around edges bare metal is visible. It looks like the previous owner had done polishing quite often.
Do you have his contact number? Any first hand experience with this workshop.
I was actually a novice when I joined this forum. But thanks to TBHP and incompetent Ford dealers I now know a lot more about cars.
I would be grateful for any help from you this regard.
Posting few pics of Mondeo in OE Black and Red color. Could you guys tell me which one looks better. Also is it possible to attain the OE paint finish?
Need suggestions on full body repainting (possibly color change) of Mondeo-1235772766meg6.jpg
Need suggestions on full body repainting (possibly color change) of Mondeo-pb191284.jpg
Need suggestions on full body repainting (possibly color change) of Mondeo-pb191283.jpg
Need suggestions on full body repainting (possibly color change) of Mondeo-1235772725meg1.jpg
Old 18th June 2009, 21:59   #7
simply_sunny001's Avatar
Thanked: 15 Times
Red one with those wheels looks super hot, black is no way near just too subtle.
So my vote goes for the Red one
simply_sunny001 is offline   Reply With Quote
Old 18th June 2009, 22:13   #8
audiophile's Avatar
Thanked: 23 Times
@novice, the pics above look good, black is a common color for the Mondeo, its like just another mondeo, since you are painting the entire car I would suggest a nice color as the sunset copper in the pic above or red.
Here's a pic I dug up from my laptop...liked it in red.
audiophile is offline   Reply With Quote
Old 19th June 2009, 11:13   #9
sushrutha's Avatar
Thanked: 324 Times
@novice
Red colour looks good.
If y0u stay in south Bangalore, Checkout with SAI Colorium at JP Nagar, It's is in Sarakki Rd, They do a neat job.
Old 19th June 2009, 12:12   #10
d_payne's Avatar
The red looks darn good, though you might want to be very specific on the exact shade of red. The Formula Red, Manchester Red and Corrida Red in the Palio Sports, Cedia and Octavia RS respectively are some of the best flaming reds in the country.
Another option to confuse you: Blue. More electric blue with a lot of metallic shine, like the Aquarius Fiesta 1.6s, it might suit the car and it would stand out unlike any other Mondeo!
Black is too subtle for a repaint IMO. I've only seen 2 colors of Mondeos - Silver and Black.
Cheers!
Payne
d_payne is offline   Reply With Quote
Old 20th June 2009, 11:07   #11
Thanked: 1,271 Times
Agree to an earlier post. All we come across are Black and Silver Mondeos, so +1 to the red color . Will go with the persona of the car, and will contribute a lot to the road presence of an already impressive vehicle.
Further, I am closely watching this thread because I plan to buy a used Ford Fusion sometime soon and I had related queries. I do not intend to hijack the original thread, but some related questions
1. Will a full repainting (with color change) give the same effect as OEM paint? Most cases I have come across, the color is great at the start but loses its sheen/gloss pretty soon. Also most pics I have come across related to repainting have a matte finish, unlike the glossy feel of OEM paints. Is it just me?
2. I read elsewhere on this forum, that for a color change you would need to strip off the original paint. This would cause a loss of the electrostatic primer and would leave your vehicle more vulnerable to rusting . Any thoughts on this?
3. Will a change of color drastically reduce resale value? My mechanic seems to think so .
sachinayak is offline   Reply With Quote
Old 20th June 2009, 18:37   #12
Thanks for the suggestion on the color choice. I too prefer Red over Black. Eagerly waiting to know answers to the queries you posted, am also worried about the quality of paint finish. But I am not worried about the resale value, anyways there wouldn't be many takers even if I give out my Mondeo for free.
Originally Posted by sushrutha View Post
@novice
Cheers!
Payne
Something like this?
Old 30th June 2009, 21:48   #13
Thanked: 181 Times
For painting options in BLR, please look @
http://www.team-bhp.com/forum/modifi...bangalore.html (Where to get a good paintjob in bangalore?)
It has many recommendations, and my experiences are also posted here.
Cheers,
lancer_rit is online now   Reply With Quote
Old 1st July 2009, 13:59   #14
Thanks for the information. Lathangi Ford quoted Rs.45K and Metro Ford Rs.1lakh for the same color repaint. Do you think the quote from Lathangi Ford reasonable based on your experience? Also I will check with Sai Colorium before making a decision.
After reading through the thread you mentioned, I am worried about the after effects of color change especially the rusting aspect. So I may drop that idea and go for the same color repaint instead.
Old 1st July 2009, 14:26   #15
muralisk's Avatar
Thanked: 9 Times
Sent you the details through PM. Please check it out.
Tyre change on Mondeo quickdraw Tyre & Alloy wheel Section 51 17th April 2013 15:50
Need help in repainting Vectra chiragh_bir Modifications & Accessories 14 8th January 2009 17:43
Ford Mondeo XR-5 Turbo & Ford Mondeo Reviewed Brosreview Test-Drives & Initial Ownership Reports 8 27th September 2008 03:02
Modded Red Ford Mondeo! + KS Motorsports Turbo/NOS Mondeo Gordon Modifications & Accessories 82 19th October 2006 21:34
