Old 18th June 2009, 17:17   #16
greenhorn's Avatar
Thanked: 1,518 Times
Originally Posted by Technocrat View Post
Btw would the LEDs be much brighter than stock light or only marginally?
not so sure about the build ones, but the 3x3 LED's i use in my indica are already brighter than the stock bulb. I'm planning to try 3x5 now :P
Old 18th June 2009, 17:38   #17
arpandiv's Avatar
Thanked: 27 Times
@techno. Check the car acessory store at JM road (bafna ? )
Am sure there are places in aundh too which stock these things.
Yes much brighter then stock bulb.
I use a 3x3 on the alto and have a 5x3 for the SX4.
arpandiv is offline   Reply With Quote
Old 18th June 2009, 17:43   #18
Technocrat's Avatar
Thanked: 2,589 Times
Whats a 3x3 & 3x5? (I guess the later is number of LEDs but whats the former number for?)
@bblost- wow thanks for the pic never knew there was on in Wagon R
Old 18th June 2009, 18:05   #19
greenhorn's Avatar
I use an array of LED's , so it stands for rows and colums. Right now am running 9 in the front, 12 in the hatcback, and 6 each for my two numberplate lights
Old 19th June 2009, 01:18   #20
ghpk's Avatar
Thanked: 193 Times
and do not attempt to just replace the stock type filament bulb with a higher watt bulk, you'll end up with a Melted Dome Light Cover.
L.E.D. are Best and coolest option, I've 28 White D.I.Y. L.E.D. Light in the dome.
Old 19th June 2009, 08:52   #21
Thanked: 25 Times
Infractions: 0/2 (9)
Originally Posted by ramki067 View Post
Thanks greenhorn for pointing to this thread. So, after reading the whole thread, i'm confused
I would like to have a 9 LED setup for the dome light. Whats the setup diagram should i make?(sorry as i'm 0% on these stuff). How many resistors and what resister values should i buy?
Thanks,
Ramki
Can anybody plz answer this query. thanks in advance.
Ramki.
ramki067 is offline   Reply With Quote
Old 19th June 2009, 10:52   #22
greenhorn's Avatar
@ ramki, can you solder/know someone who does?
same circuit, three columns instead of 2, use 100 ohm resistors if you are using white LED's
Old 19th June 2009, 11:18   #23
benbsb29's Avatar
Thanked: 4,277 Times
Ramki.
Ramki, on the thread to which Greenhorn has sent the link, you can find circuit diagrams for various combinations of LED setups for the cabin light/boot light/numberplate light etc.
Old 19th June 2009, 11:51   #24
Thanked: 25 Times
Thanks very much guys. Another Q though i had, should i use 5 mm LEDs only or 10 mm one also holds good?
Thanks,
Ramki
Old 19th June 2009, 11:56   #25
benbsb29's Avatar
Thanks,
Ramki
You could very well use 10mm LEDs, but i suppose the resistance ratings would change. Greenhorn should be provide you with a better answer i suppose.
Just a suggestion : If we are going to discuss on the technicalities of using LED setups, it would make sense to switch over the discussion to the other thread, as it would provide a consolidated source of info for others seeking the same information in future.
Old 19th June 2009, 12:39   #26
greenhorn's Avatar
in my experience, 5m is optimum. the resistors you need to use with 10mm are not THAT different, since a 10mm LED doesnt take 2x current or give out 2x more light, but a lot less. I'd use a greater number of smaller LED's (provided you dont mind doing the extra work)
Back interior light for WagonR Lxi. ramki067 Modifications & Accessories 11 8th November 2010 20:14
DIY - Swift Interior Light Change from stock to White LED sonirohit DIY - Do it yourself 26 27th March 2010 16:16
headlight and fog light bulb specs (Skoda Laura 1.8 TSI) hvishwanathan Technical Stuff 0 15th January 2010 11:08
Hyundai Accent - Auto Dimming Interior Light thedreamcatcher Modifications & Accessories 16 17th July 2009 20:41
getz odometer bulb replacement filcord Technical Stuff 11 5th June 2009 20:00
