Old 18th June 2009, 11:06   #1
Thanked: 25 Times
Infractions: 0/2 (9)
Default Replacement of Interior light bulb in WagonR.
Hi all,
The interior light(stock one near the rear view mirror) in my WagonR Lxi is very dim and would like to replace with a brighter light bulb. Please suggest me a good white light bulb which would hold good. Also i would like to add a dicky light, any suggestions where i can install it?
Thanks,
Ramki
ramki067 is offline   Reply With Quote
Old 18th June 2009, 11:33   #2
arpandiv's Avatar
Thanked: 27 Times
Hey you get a ready made LED bar which has a connection to fit inside the stock holder of the interior light. Check with an car accessory shop
arpandiv is offline   Reply With Quote
Old 18th June 2009, 13:39   #3
greenhorn's Avatar
Thanked: 1,516 Times
http://www.team-bhp.com/forum/modifi...leds-ikon.html
Old 18th June 2009, 15:16   #4
Thanked: 25 Times
Thanks greenhorn for pointing to this thread. So, after reading the whole thread, i'm confused
I would like to have a 9 LED setup for the dome light. Whats the setup diagram should i make?(sorry as i'm 0% on these stuff). How many resistors and what resister values should i buy?
Thanks,
Ramki
Old 18th June 2009, 15:34   #5
arpandiv's Avatar
Thanked: 27 Times
Why not buy it instead ? Might not be cheaper but will surely save you time.
Old 18th June 2009, 15:52   #6
gpa
gpa's Avatar
Thanked: 282 Times
Don't all MUL vehicles come with a higher wattage bulb? I think it is 8W not where as the older models had 5W bulbs.
Old 18th June 2009, 15:57   #7
Technocrat's Avatar
Thanked: 2,589 Times
Arpan, does such a thing exist for Alto too?
Old 18th June 2009, 16:26   #8
benbsb29's Avatar
Thanked: 4,276 Times
Techno, the readymade LED setups would be generic, i suppose. It should cost you in teh range of Rs.300/- or so, of not more. Do ask around some of the car accessory shops in your area.
Needless to say, the DIY part of it makes it a whole new experience of seeing the light.
Old 18th June 2009, 16:34   #9
Technocrat's Avatar
Thanks Benny, but I am really not the DIY types (except for washing the car & waxing it sometimes).
Btw would the LEDs be much brighter than stock light or only marginally? Anyways the light in front row is fine its the rear row where I find the light inadequate, may be a 2nd light at back?
Old 18th June 2009, 16:40   #10
benbsb29's Avatar
Techno, for the rear, you can get these LED light setups which run off a battery, and which are activated by a click button. Use double sided tape on them, and they can be stuck at any position in the car - the roof, C pillar, etc. That should cover the lack of light at the rear. I believe Vidyut got himself two of those.
Here in Bangalore, they are available at Home Town stores.
Old 18th June 2009, 16:42   #11
gpa
gpa's Avatar
Thanked: 282 Times
The lighting is woefully inadequate for the Alto in the back. Just like Techno, I don't mind getting an extra set of lights for the back row.
This may be OT, but I recently bought a small LED light with 3 bulbs from Spar, use it as a light inside my glovebox. Lights up the small area brilliantly and looks cool. Once at a traffic jam a guy in a Fabia who was busy looking at my co passenger rummage thru the glovebox for some gum asked if the bright light was standard fitment for an Alto
Old 18th June 2009, 16:42   #12
bblost's Avatar
Thanked: 6,971 Times
The Wagon R Vxi has a light in the rear as well.
At least my 2004 Model does.
Why not something like
Hella Reading Lamps from BuyAutoTruckAccessories.com - Lowest Price Guarantee
Google for: Hella Reading Lamps
Old 18th June 2009, 16:43   #13
gpa
gpa's Avatar
Thanked: 282 Times
We posted within seconds of each other. Are we both referring to the same thing?
Old 18th June 2009, 16:46   #14
Technocrat's Avatar
Yeah I have seen the ones at Home Town Stores & now that you have mentioned, I may pick one of those
@bblost- Where is this 2nd light located? I know about reading lamps but thats not what I am looking for.
Old 18th June 2009, 16:51   #15
bblost's Avatar
Right in the middle of the rear door.
Back interior light for WagonR Lxi. ramki067 Modifications & Accessories 11 8th November 2010 20:14
DIY - Swift Interior Light Change from stock to White LED sonirohit DIY - Do it yourself 26 27th March 2010 16:16
headlight and fog light bulb specs (Skoda Laura 1.8 TSI) hvishwanathan Technical Stuff 0 15th January 2010 11:08
Hyundai Accent - Auto Dimming Interior Light thedreamcatcher Modifications & Accessories 16 17th July 2009 20:41
getz odometer bulb replacement filcord Technical Stuff 11 5th June 2009 20:00
