Old 19th February 2010, 01:36   #121
Thanked: 152 Times
@Pranav, Would you like to get your car Dynoed anytime soon? I could help.
Cyrus43 is offline   Reply With Quote
Old 20th February 2010, 21:45   #122
pranavt's Avatar
Thanked: 274 Times
Yes, that's the plan. I've been too busy to sort out a few unrelated things with my car, so it should happen once it's all done.
Old 20th February 2010, 22:39   #123
KSM-Vtec's Avatar
Thanked: 440 Times
ya dude you should do the dyno run soon, will be very interesting to see the results.
KSM-Vtec is offline   Reply With Quote
Old 20th February 2010, 22:57   #124
Thanked: 36 Times
What is "FFE'd". Sorry, I am a noob here.
abhipuru16 is offline   Reply With Quote
Old 20th February 2010, 22:58   #125
pranavt's Avatar
Thanked: 274 Times
Got a freeflow exhaust. That was quite a few full moons ago though.
Old 4th March 2010, 22:47   #126
pranavt's Avatar
Thanked: 274 Times
So yeah, first of a few videos. Expect a few more in a few days
pranavt is offline   (1) Thanks Reply With Quote
Old 5th March 2010, 00:41   #127
Car sounds great and looks quick. There seems to be some sound just before you start accelerating after changing gear or retarding. Is the engine running rich fuel mix?
427Cubes is offline   Reply With Quote
Old 5th March 2010, 01:31   #128
pranavt's Avatar
Thanked: 274 Times
Yes, the engine is running rich right now, though that's only because I'm tuning it and it's in open-loop. The ECU will automatically decrease injector pulses once I put it into closed-loop. As for the sound, that's because I recorded it using my cellphone camera and it didn't seem to pick up sounds properly. There are quite a few things which seem to be recorded at a different level altogether. In reality, the car sounds a lot meatier than this, and dare I say it, almost like a B16/B18. There's still a lot to be extracted from the current configuration. Today was just a shakedown run for an hour or so, and the meat of the fuel/ign tuning and various other things like battery offsets and fuel/ign corrections are still to be done. Time, sadly, is a scarcity and that's what keeps delaying everything, though I aim to get done with this in the next week or so.
Old 5th March 2010, 01:42   #129
Akshay1234's Avatar
Thanked: 7,242 Times
lol can you get a better horn?
Old 5th March 2010, 01:43   #130
pranavt's Avatar
Thanked: 274 Times
Refer to previous post, it sounds different. Even I am embarrassed by the end result
Old 9th March 2010, 20:11   #131
pranavt's Avatar
Thanked: 274 Times
So I'm opening up my engine for head work and putting in the Y8 cam that I have lying around. I'm planning to go for an aftermarket head gasket, preferably a Fel-pro. Would anyone know if they're sold in India? Any other brand apart from OEM and cheap Chinese knock-offs? And if not, would anyone be willing to use their connections to get a HG shipped to me via one of their friends/etc? Thanks in advance.
Old 9th March 2010, 21:05   #132
pranavt's Avatar
Thanked: 274 Times
Meh, nevermind. People know more about seat covers and power horns these days. Decided to go with OEM gasket as per ROCAM's suggestion. Thanks though.
Old 17th March 2010, 18:21   #133
pranavt's Avatar
Thanked: 274 Times
Time for the next stage of my DIY job. Putting in my new cam with adjustable pulley, probably bumping up compression a bit, porting and polishing, 3 angle + backcut valve job and valve seat work. Should be fun
Old 19th March 2010, 16:35   #134
pranavt's Avatar
Thanked: 274 Times
Another update. After 2 days spent stripping and cleaning the head, here is where I stand.
One of the intake ports before the porting work.
One of the exhaust ports before the porting and polishing work
The combustion chamber before the cleaning and valve seat work.
Aaand just as I was making this post...
Right on time
Old 19th March 2010, 17:12   #135
kutlee's Avatar
Thanked: 202 Times
looks like a good DIY startup. waiting for updates!!
kutlee is offline   Reply With Quote
Race Dynamics' Baleno Build-up: ITBs/Turbocharged - Re-dynoed @ 256 WHP! binz Modifications & Accessories 173 13th February 2017 22:56
Ohc 1.5 Vs Ohc Vtec narayan Technical Stuff 137 24th January 2015 12:15
Wanted: OHC VTEC or OHC 1.5 adit1329 Shifting gears 5 22nd June 2012 17:00
Lowered the steering wheel tilt of my Maruti A-Star! Sankar Modifications & Accessories 15 7th February 2012 18:50
