Old 1st July 2009, 19:18   #1
Default Can indicator/wiper levers be swapped in Skoda?
This was a friend asking me whether he can get this done - he is planning on buying a second hand skoda, but he simply hates the switched controls.
Any opinions??
silverbyte is offline   Reply With Quote
Old 1st July 2009, 19:50   #2
Thanked: 149 Times
Ask him to go through this forum. It is likely that he ends up hating other parts too.
Old 1st July 2009, 20:55   #3
heh there is no accounting for taste.
but the question still stands - can it be done ?
Old 1st July 2009, 21:54   #4
Jaggu's Avatar
Thanked: 8,685 Times
Do you mean swap them from LT to RT? Not going to be an easy task since the self cancellation unit for indicator and all will be integrated and i dont know of any RT drive skoda configurations available. Swapping from other cars will be a tricky task and since its a skoda, if its in good running condition, please avoid fiddling with it.
Search for skoda in this forum and you will know why's in detail
Old 2nd July 2009, 01:50   #5
ghostrider's Avatar
Thanked: 307 Times
Any opinions??
Nope. Uh uh.
Even if it was possible, you'd have to change the steering column and get brand new stalks which fit the way you want them to (indicators on the right, wipers on the left). I'm not even sure Skoda makes these parts.
ghostrider is offline   Reply With Quote
Old 2nd July 2009, 09:04   #6
dkamath's Avatar
Thanked: 119 Times
Thinking that it's good to leave things the way they are. Swapping the stalks from left hand to right hand side is not possible, as your friend would be more confused. He'll have to push the stalk down while taking a left turn, and upwards while taking a right turn. Not sure if the switch inside too can be put the other way round. Wipers would be manageable i guess.
dkamath is offline   Reply With Quote
Ignition Coil swapped with faulty ones at Hallmark Honda Ragin_Ice Indian Car Dealerships 7 10th July 2015 10:27
Finally swapped out my Vette for the GT-R 1Day The International Automotive Scene 30 6th October 2009 09:55
Gear levers - Shifting pattern, positioning ashwanth Technical Stuff 4 8th August 2008 12:29
Why indicator/wiper on different sides in some cars? sbasak Technical Stuff 10 18th April 2007 01:08
