Old 8th July 2009, 22:27   #16
nitrous's Avatar
Thanked: 282 Times
Originally Posted by crazydiablo View Post
Just what I needed. they are supposed to be std height springs. I will settle for these as these are for street use.
Like I said earlier, check if you'd be happy with the spring rate before you take the plunge.
Im sure there are lots of cars in Bangalore with pedders setup.
Old 9th July 2009, 01:21   #17
v1p3r's Avatar
Thanked: 26 Times
No the DMS Gold Tarmac go down like crazy. I did a 4 inch drop, measured on the strut body itself. Initial height was about as much as a stock car, could be off a few mm at most.
crazydiablo, never used the Kings. Got the DMS at the same time, so there was obviously no comparison.
kutlee, that car was totally different. I could drive at 100 kmph all day and not worry about busting anything. The Baleno doesn't bottom anywhere except the rear bend on the tailpipe before the endcan, and somehow that was never an issue on my car when lowered.
Old 9th July 2009, 08:31   #18
crazydiablo's Avatar
Thanked: 21 Times
Nitrous I am only looking for something a little better for the street, nothing radical so I guess its ok.
crazydiablo is offline   Reply With Quote
H&R Lowering springs from Germany for my Maruti AStar! Sankar Modifications & Accessories 34 7th August 2014 11:08
Lowering the OHC and other suspension queries manveet Modifications & Accessories 38 8th April 2011 13:16
SKODA VRS lowering springs any problems Frank Zappa Technical Stuff 1 25th June 2010 16:32
lowering coilovers & suspension kit dharmana Modifications & Accessories 2 29th November 2009 14:37
Lowering suspension(ground clearance or ride height) for the SX4 dharmana Modifications & Accessories 27 29th April 2008 22:34
