Old 6th July 2009, 15:01   #1
crazydiablo's Avatar
Thanked: 21 Times
Default Lowering Springs for Baleno
I am looking for lowering springs which are streetable. Most of the available ones drop atleast 40mm, which I feel is a bit too much.
Anybody knows spring which drop by 1inch both front and back.
Locally available is Pedders but I dont know the drop neither is it advertised anywhere on their site.
Eibach does not have springs for the baleno.
Another questions dropping the car 40mm, how does it affect camber?
crazydiablo is offline   Reply With Quote
Old 6th July 2009, 16:25   #2
rjstyles69's Avatar
Thanked: 795 Times
Mohit call up vikram and speak to him, I remember he was running peddars on his swift sometime back.
Old 6th July 2009, 17:26   #3
pranavt's Avatar
Thanked: 274 Times
Contact Electra, the dealers for Pedders springs.
Old 6th July 2009, 18:18   #4
Thanked: 21 Times
Yeah I will talk to Electra, need to know the drop.
Are the springs the same for swift and baleno?
Old 6th July 2009, 20:13   #5
Thanked: 21 Times
Pedders lowering springs lower around 50mm. Price around 16.8K for a set of four.
Old 6th July 2009, 21:31   #6
Mpower's Avatar
Thanked: 1,687 Times
You need to make sure if the spring is meant for the strut or a coil over.
The Peddar one is probably for a coil over (small dia spring) and will not fit on a Koni Strut.
Old 6th July 2009, 22:16   #7
Thanked: 21 Times
Good point there, but if these springs are available separately wont they be for stock replacement?
Old 7th July 2009, 21:48   #8
Mpower's Avatar
Not always. The rally guys will use one coilover body and use different springs (stiffness) based on the track which they will buy separately.
Old 7th July 2009, 21:55   #9
binz's Avatar
Thanked: 412 Times
Hey mohit, pretty sure there are peddars available with a 10mm drop. Check with electra, or get in touch with blue baleno boy
Old 8th July 2009, 02:47   #10
v1p3r's Avatar
Thanked: 27 Times
Erm, I don't know much about PeddErs, but I do know they don't make coilovers for the Baleno. I used to have a set of 40mm Kings, but they're long gone. No point lowering unless you're going 40mm minimum. The Baleno will not touch anywhere that a stock car wouldn't touch, especially once you have a custom exhaust. I know this for a fact because I once ran a 100mm - 4 inch drop and I never once grounded the car anywhere.
The part you're looking for is front - 2342 and rear - 2343.
Old 8th July 2009, 10:35   #11
Thanked: 21 Times
Binoy, i checked with Electra, either pedders comes with std height spring (their heavy duty range) or 50mm lowering springs (sports ryder range).
V1p3R: How was the Kings springs? how was the ride, durability?
100mm drop! Here am worried about a 30mm drop!
Old 8th July 2009, 11:21   #12
kutlee's Avatar
Thanked: 202 Times
100mm drop seems too low. That why may be he takes half the time to cover the distance and double the time to get over bumps.
kutlee is offline   Reply With Quote
Old 8th July 2009, 12:08   #13
Thanked: 21 Times
On further thought, how did you lower 100mm? DMS lowers only 50mm right? So What springs and what struts?
Old 8th July 2009, 18:07   #14
nitrous's Avatar
Thanked: 285 Times
Pedders Heavy duty springs lower by 10mm. I have these and they're soft for my tracking needs.
Pedders Lowering springs drop quite a bit. Please enquire at Pedders HQ for the exact drop and spring rate. Do some research on the spring rates for your car before putting down 17k.
Old 8th July 2009, 19:42   #15
Thanked: 21 Times
Just what I needed. they are supposed to be std height springs. I will settle for these as these are for street use.
H&R Lowering springs from Germany for my Maruti AStar! Sankar Modifications & Accessories 34 7th August 2014 11:08
Lowering the OHC and other suspension queries manveet Modifications & Accessories 38 8th April 2011 13:16
SKODA VRS lowering springs any problems Frank Zappa Technical Stuff 1 25th June 2010 16:32
lowering coilovers & suspension kit dharmana Modifications & Accessories 2 29th November 2009 14:37
Lowering suspension(ground clearance or ride height) for the SX4 dharmana Modifications & Accessories 27 29th April 2008 22:34
