Old 26th November 2010, 11:02   #226
Ricky_63's Avatar
Thanked: 394 Times
Originally Posted by navpreet318 View Post
I hope it'll a gearbox with gears cut under some multinational automobile company's quality control.
One of the best places would be Ludhiana,Jalandhar with some companies making engine components for some very respectable sports cars and bikes manufacturers.
Hope that the stock gearbox holds, not yet getting into more expense as of now. Let's see how it goes, still waiting for the clutch to come.
Old 26th November 2010, 13:09   #227
noidaboy's Avatar
Thanked: 260 Times
The ECU is awaited now, wiring it is makes it one puzzle by the looks, its got a million wires at least.
noidaboy is offline   Reply With Quote
Old 26th November 2010, 13:37   #228
pranavt's Avatar
Thanked: 274 Times
Wiring it should be relatively easy if you have the pinouts of the stock harness. The onboard 1.5 bar MAP sensor is a real bonus and the rest of the components are just electrical sensors that require a bit of elbow grease and heatshrink tubing to get perfect. Good luck with the same.
Old 26th November 2010, 15:30   #229
nitrous's Avatar
Thanked: 285 Times
Regarding gearbox, avoid giving jolts to it (launching at boost, power shifts, etc.) and it should last.
Known to give headaches to tuners.
This will take a while and should be done carefully.
Old 26th November 2010, 15:33   #230
crazydiablo's Avatar
Thanked: 21 Times
Dont worry about the g13b gearbox atleast for now. The worst gearbox is in the baleno. If you can get a engine damper that will help reduce the rocking forces on the gearbox.
crazydiablo is offline   Reply With Quote
Old 26th November 2010, 16:04   #231
Ricky_63's Avatar
Thanked: 394 Times
Sanyam, you should have said whoosh whoosh instead of pissssss pisssssss Ya ya the ECU is ofcourse Phil's favourite most part when it comes to setting up an engine
Thanks for the inputs - hope it helps Phil sort it out :-)
No powershifts ?? That is one thing I love to do, but thanks for the warning I shall try & refrain myself
Engine damper ?? Ok is that not what Amey is using in his Lancer ??
Thanks for the idea.
Old 26th November 2010, 19:48   #232
Amey's Avatar
Thanked: 189 Times
If you are talking about the blue bar you see in my engine bay,then no its not the engine damper, its the strut brace.
An engine damper is like a small shock absorber which fits in between the strut mount top and the engine head to avoid the flexing of the engine when it revvs hard.
Amey is offline   Reply With Quote
Old 26th November 2010, 21:51   #233
Ricky_63's Avatar
Thanked: 394 Times
C'mon I am not "that" technically challenged I know the blue thingy is a strut brace !
But I sure did not know about the concept of the engine damper. Thanks for the information.
Though I do not know if I need that as yet.
Thanks & Cheers
Old 26th November 2010, 23:38   #234
Amey's Avatar
Thanked: 189 Times
Thanks & Cheers
My Apologies
Well,whether its needed or not is a completely relative decision but installing it will definitely help in the long run.
Thats what I feel.
Old 27th November 2010, 03:03   #235
noidaboy's Avatar
Thanked: 260 Times
No No, I didnt write that, i just clicked what was written on it
Old 27th November 2010, 09:24   #236
Thanked: 21 Times
Engine damper:
http://image.nengun.com/catalogue/or...que_damper.jpg
its a small insurance defintiely.
Old 27th November 2010, 11:48   #237
Ricky_63's Avatar
Thanked: 394 Times
My Apologies
Thats what I feel.
Ok, now I understand the concept. Guess it'd also lessen strain on engine mounts, because of lesser lateral movement. Right ? And you don't need to apologise buddy
That did seem like Phil's writing, now I no it is !! LOL
Engine damper:
Old 29th November 2010, 21:10   #238
Ricky_63's Avatar
Thanked: 394 Times
Sigh no sign of the clutch, no response from Phil !! Busy with preparing for the Redline 2. I guess....patience..is a virtue !! LOL
Old 30th November 2010, 02:09   #239
m4ugr8's Avatar
Thanked: 123 Times
The clutch came-in almost two days ago, dont know but I think its on the car already. Last two days Phil had been wiring up and setting the ECU, nitrous rightly said this was a true headache but everything is sorted now.
Car was fired up tonight, I just came back from Speedsport so giving you live update. As of now Phil is still at the workshop fine tuning the car, expect a phone call tomorrow
Initial impression was good, We did not go full throttle or full boost as things were still being set.
m4ugr8 is offline   Reply With Quote
Old 30th November 2010, 10:00   #240
Amey's Avatar
Thanked: 189 Times
Awesome! Nice to know that this project is proceeding at a very good rate. Great work guys
'03 Toyota Camry V3 - The "New" Wild Horse in My Stable IQBAL VEERJI Test-Drives & Initial Ownership Reports 66 4th January 2012 23:14
