Old 19th December 2010, 21:39   #301
Ricky_63's Avatar
Thanked: 377 Times
Default Re: "The First" from the SPEEDSPORT stable !!
Originally Posted by speedsport View Post
@ricky: good to hear that its all worth while after all .
regarding fuel efficiency, if you drive off boost it WILL give you normal fuel efficiency. if you keep spooling the turbo up then it will give you less. now beat that-driving off boost
What's the point of spending all those greens if I have to stay off boost ? But I do drive off boost in traffic most of the time. I think have a chat with you know who & maybe find a solution to the high fuel consumption..afterall we are like this only
cheers & thanks mate
Old 20th December 2010, 09:39   #302
Thanked: 36 Times
@ricky : drive off the boost and you will get gas mileage !!!!! you want to eat rasgulla breakfast lunch and dinner and not put on weight ? LOL you know who to talk to then ....GOD.
speedsport is offline   Reply With Quote
Old 20th December 2010, 11:22   #303
Ricky_63's Avatar
Thanked: 377 Times
Originally Posted by nitrous View Post
For the brakes, I recommend the Hawk brake pads.
Quite a few Bhpians in Chennai use them.
Track day boys 'yzfrj' and 'hirevbg' love it.
Superb performance and good VFM too.
Check it out: Hawk Performance Brake Pads
Tried contacting them, the website does not seem to respond too well. Would you know what kind of price would they run at ? Was considering Mintex, Tarox & now as per your suggestion Hawk. How would they compare against each other ?
Old 20th December 2010, 16:00   #304
pramodkumar's Avatar
Thanked: 857 Times
Infractions: 0/1 (5)
Hey Ricky,
Why dont you get rear discs installed from phill? this way you will get good support in delhi it self and your comprehensive documentation will help me to modify rear discs for my lancer , What say huh?
Pramod
Old 20th December 2010, 16:28   #305
nitrous's Avatar
Thanked: 282 Times
Call PJ directly @ 09884121584
Old 20th December 2010, 17:32   #306
Ricky_63's Avatar
Thanked: 377 Times
Hey Ricky,
Pramod
I checked with Phil on that. They cost quite a lot & when uprated disc pads can suffice why spend more ? I am anyway broke by now !!
Thanks - will do right away !! No response on the phone either, just ringing !
Old 20th December 2010, 18:10   #307
Ricky_63's Avatar
Thanked: 377 Times
Finally got a call back. Have been suggested Hawk HPS (High Performance Street). Wanted to know if these are good enough, compared to Mintex. There is a large price differential between the two.
Tarox is out of the reckoning as they do not have pads for the Swift.
Any knowledgeable input is welcome.
Old 20th December 2010, 18:53   #308
planet_rocker's Avatar
Thanked: 366 Times
Sirji,
What about these (just the rotors)
http://www.team-bhp.com/forum/modifi...ml#post1266729 (Some stuff for my Swift VDi just arrived !)
& something to complement it like Hawks / EBC
planet_rocker is offline   Reply With Quote
Old 20th December 2010, 20:47   #309
Ricky_63's Avatar
Thanked: 377 Times
Originally Posted by planet_rocker View Post
Sirji,
The rotors can always be added later if the brake pads do not suffice !
Thanks for the suggestion though !
Old 21st December 2010, 21:22   #310
Ricky_63's Avatar
Thanked: 377 Times
BIG TIME starting trouble in the mornings. The battery is in top notch condition. I suspect the plug connections or maybe the plugs themselves.
Need to have it checked. It used to be a 1/2 self start car. Wonder what happened.
Any inputs ?
Old 21st December 2010, 22:04   #311
navpreet318's Avatar
Thanked: 826 Times
Could be anything.From a simple thing like bad plugs to a full blown piggyback issue.Can only be ascertained by the tuner himself.So when's the sleepover party at your house.Coz thats the only way Phil can check it in the morning. :P
navpreet318 is offline   Reply With Quote
Old 22nd December 2010, 06:28   #312
may be just compensation settings on the haltech for cold start
dragger is offline   Reply With Quote
Old 22nd December 2010, 11:03   #313
Ricky_63's Avatar
Thanked: 377 Times
I doubt very much that is a piggyback issue, coz once it starts it runs perfectly. C'mon don't give me nightmares ! As for the sleepover party - that would not be required, as this behaviour surfaces even during the afternoon.
I certainly hope so. Will need to have Phil take a good look at it. It is the most embarrasing thing, when your car does not start up in 10 - 15 cranks.
Old 22nd December 2010, 12:28   #314
pranavt's Avatar
Thanked: 272 Times
Try cranking with the throttle pressed around 7-10%
Old 22nd December 2010, 13:14   #315
Thanked: 366 Times
pranav - isn't that a procedure to crank in a carb engine incase of an overflow?
Can the FPR be at fault? or the Fuel pump?
'03 Toyota Camry V3 - The "New" Wild Horse in My Stable IQBAL VEERJI Test-Drives & Initial Ownership Reports 66 4th January 2012 23:14
