Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here!
Thread Tools
Old 19th June 2005, 10:13   #1 (permalink)
Question Which Petrol Engine For Safari ??
Hi, I Have A Diesel Safari 99, I Am Not Satisfied With The Power Of Safari Diesel Engine.
I Wish To Replace It With A Powerful Petrol Engine.
Will Contessa 1.8 Isuzu Petrol Engine Be Fine ??
Or Else Which Petrol Engine Will Be Suitable???
Amit
shahmotors is offline   Reply With Quote
Old 19th June 2005, 11:14   #2 (permalink)
i personally think that the isz 1.8 petrol engine will be a tad underpowered for the safari.. why dont you source the 2.0 petrol engine that tata make for the petrol safari
__________________
push it to the limit
sanket12 is offline   Reply With Quote
Old 19th June 2005, 11:17   #3 (permalink)
well, thats a good suggestion, but will be too expensive, i do not want to spend too much on it . do we have any other options ??
amit
Old 19th June 2005, 11:24   #4 (permalink)
amit bhai i dont know how usefull this post will be but then why dont you try & get a 2.8 pajero engine not only is it powerfull its also diesel & spares wont be a problem..
__________________
Old 19th June 2005, 12:16   #5 (permalink)
chiragh_bir's Avatar
why don't u try CRDel engine of Scorpio
chiragh_bir is offline   Reply With Quote
Old 19th June 2005, 12:27   #6 (permalink)
did u check out chor bazar and cst road in kurla for engines...i guess thats the best place to look for imported and used engines?
heavy_foot is offline   Reply With Quote
Old 19th June 2005, 12:35   #7 (permalink)
Montoya's Avatar
Well Shahmotors i dont think its easy to change a diesel engine into petrol or vice versa as it will involve loads of other changes as well.. you will have to change the valves, adjust chassy set the suspension and alot more.. The Petrol engine of the Safari itself is underpowered and it takes almost 17secs to reach 100 wheras the New Scorpio CRDe is faster then its petrol sibling as well as faster then all Safaris and also Innova. The New Safari engine is also not fuel efficient and gives 7kpl and that much sacrifcie in FE for no power is not worth.
IMHO stick to this engine and work on getting 100% out of it. Use filter, muffler, chip( i feel its not possible) since engine is Direct Ignition and not a Turbo Intercooled one but why do TATA write Turbo intercooler besides it?
Montoya is offline   Reply With Quote
Old 19th June 2005, 12:50   #8 (permalink)
The Safari's engine is turbocharged, I dont know about the intercooler bit.
__________________
It is no measure of health to be well adjusted to a profoundly sick society.
- J Krishnamurti
Steeroid is offline   Reply With Quote
Old 19th June 2005, 15:42   #9 (permalink)
aadix's Avatar
all models from mid 2000 have an intercooler also.
__________________
"live to ride,ride to eliminate"
aadix is offline   Reply With Quote
Old 19th June 2005, 21:39   #10 (permalink)
Amit bhai,
Tata safari have a 1948 cc indirect injection turbo intercooled (483 DL series) .
as sanket suggested go for a pajero 2.8 engine (118 hp and 29.8 kgm of torque) or a toyota qualis and fix a aftermarket turbo .
this will give u around 100-110hp the availabiility of spares wont be a problem .
another option is nissan Commonrail engine 2184 cc 136 hp and 32 kgm of torque the engine is very refined too ..
i dont know the modifications needed in mounting these engines.
anyways i would recomend a diesel engine for safari .
Vin Diesel is offline   Reply With Quote
Old 20th June 2005, 00:49   #11 (permalink)
thanx guys for all the sugestion, i think i will try for the pajero engine, further i think qualis engine would be a good option,
is qualis engine turbocharged?? if not how sucessful is aftermarket turbo kit??
amit
Old 20th June 2005, 18:25   #12 (permalink)
veyron1's Avatar
well, the qualis has a indirect injection, 2.5 litre, 73 bhp engine that produces 151 nm of torque. and no, there aren't any specific aftermarket turbo kits for the qualis engine- you'll have to source one from turbonetics, or as such- or you'll have to experiment with the safari's/ scorpio's turbo. in my humble opinion, the safari's IDI 1948 cc, turbocharged, intercooled, 90 bhp in-line four is way better- plus, it has 187 nm of torque. i own a safari 4x4 myself, and i have found it to be slightly underpowered only in the city- the car gets into a rythm on its own on the highway....
actually, aadix, all the models of the safari, have intercoolers, right upto the nov. 1997 model.
my suggestion is, that you wait a li'l bit, and go in for the safari crd-i, or the engine from the crdi variant. the plus point being that most probably, you won't have to change your gearbox, as the bell-housing might be of the same dimensions; in all your other options, you will have to do heavy fabrication- the mounts of the pajero 2.8 and the x-trail are very different from that of the safari- and also, the gearboxes will have to be changed, which will be an expensive proposition( the costs might run close to 2 lacs+).
and more importantly, the crd-i engine from tata will carry a warranty, and the dealer will change the engine no. in your r/c book, making the whole process legal and worthwhile... and reliability won't be a problem either..
__________________
DAD
veyron1 is offline   Reply With Quote
Old 20th June 2005, 21:07   #13 (permalink)
Psycho's Avatar
Try the Isuzu Trooper +92 3 liter 4 cylinder turbo diesel engine you could get it for a steal in mumbai... the engine produces 156 bhp... and gives about 25 MPG of diesel...
__________________
Psycho
Modding != idea + <ctrl-c> + <ctrl-v>
Modding = idea + <ctrl-c> + <ctrl-v> + Finagle's Law of Dynamic Negatives
Old 21st June 2005, 00:16   #14 (permalink)
Sounds good. How much is a 'steal', approximately?
__________________
- J Krishnamurti
Old 24th June 2005, 23:53   #15 (permalink)
Veelubai's Avatar
The best choice is the 135ps Tata Sari petrol engine.Though it will be a costly affair it would be the ideal fit
Veelubai is offline   Reply With Quote
Thread Tools
Diesel engine oil in petrol engine geeash Technical Stuff 17 26th August 2009 21:23
Safari TCIC 2.0 Engine swap with 3.0L DICOR Engine gd1418 Modifications & Accessories 34 6th July 2009 16:12
What to choose safari petrol or Safari diesel 2.2L 007 Bond SUVs, MUVs & 4x4s 22 31st August 2007 22:56
Maruti Esteem petrol engine to Diesel Engine mituadas Modifications & Accessories 24 23rd May 2007 13:42
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608
