Old 19th July 2009, 22:20   #1
althaaf's Avatar
Thanked: 59 Times
Thumbs up Pulsar 220 projector headlights on car!
hi friends,
Am here with a new (may be stupid) doubt. i was in search of an after market projector headlight set up for my hyundai santro. as you all know, its really impossible to find one. whenever i tried to contact any car modifiers, they are telling very high price. so now am thinking of a DIY project. am an amateur in this field. so my 1st doubt is,
can i use pulsar 220 projector kit for my car? is it readly fittable?
is it costly? will it make things useless? can i fit bi-xenon or dual beam light?
i know i had asked a really silly question, but i really need help.
i dont know why nobody discussed about it till now. i tried google also, but no use. anyway friends, help.
althaaf is offline   Reply With Quote
Old 19th July 2009, 22:51   #2
smokin's Avatar
Thanked: 13 Times
first of all need to ask you..which santro you have ? i means the model
secondly you have the projectors or you need to buy them ?
bi-xenons are really expensive !
you can make the double beam projectors in all santro models but the finishing is really costly .
one more thing if you going with the visibility part of the projectors then mind it to use the original bulbs with them ( i mean that if the projectors hold h7 the use only h7) otherwise you will ruin the whole thing
smokin is offline   Reply With Quote
Old 19th July 2009, 23:03   #3
theMAG's Avatar
Thanked: 1,574 Times
Projectors are typically for a single(fixed) HID beam - low. By that definition, if you want HIDs for low and high beam, you will need two separate projectors. Either that, or a single projector will need to swivel up/down for high-low beam, which is a very non-standard setup - and you would probably be amongst the first to experiment/implement such a setup if you chose this option.
As far as the feasibility of the Pulsar projector goes, projectors are typically vehicle agnostic. Having said that, you might just want to experiment once to check the spread/throw of this projector before you take the plunge.
Old 20th July 2009, 15:57   #4
UniqueMods's Avatar
Thanked: 50 Times
Kindly go through the following link
http://www.team-bhp.com/forum/modifi...-page-3-a.html (Project SANTRO Projectors - Successful - Pics on Page 3)
also search on Google, there are couple more, but i will get a infraction, if i post them here.
UM
UniqueMods is offline   Reply With Quote
Old 20th July 2009, 17:06   #5
althaaf's Avatar
Thanked: 59 Times
mine is the old model santro with bug eye headlight!
i will be buying the projectors after getting green signal from team bhp guru's. you know, am a student and dont want to waste money on buying projectors which might be useless. so friends, please give me ideas
ok, so u r telling that i should go for low beam in projector, but the problem is where will i fit a second projector or any other thing for high beam? i dont think it will have enough space. am attaching a pic of front view, can you tell me how the fitting can be done? like, if i fit a low beam projector, what should i do for high beam? if i have to fit a second projector, where will i do that?
Old 20th July 2009, 20:31   #6
abhinav.gupta88's Avatar
Thanked: 310 Times
The thing you are asking has already been done by Smokin.
But since he is commercially involved, he cannot post a picture on this thread.
However you can check it in his avatar where he has put the picture of double beam projectors with angel eyes and led indicators done on a santro.
Old 20th July 2009, 21:30   #7
JayD's Avatar
Thanked: 2,008 Times
The beam of the P220 will not be too effective on a car. It is quite good on a bike. It is more pointed than projectors on cars. So unless there is some way to adjust the throw pattern of the projectors, it would be a waste of money. try getting projectors off cars like the sonata/mondeo etc from any scrapyard.
Old 20th July 2009, 22:21   #8
althaaf's Avatar
Thanked: 59 Times
Thumbs up
thanks for that point. so you are telling, it will be waste of money to fitpulsar 220 projectors. do you know if the problem is due to projector lens itself or due to the way it is fixed in the bike?
seen that, but that pic makes me feel that projector set up does not suit santro(no offense please) what do you think about making it fit in the fog lamp assembly?
Corolla Mods - Eibach Springs, Xenon HIDs and Angel Eye Projector Headlights novice Modifications & Accessories 14 2nd July 2011 03:46
Pulsar 220 (new) or the Apache RTR 180 - EDIT - Bought Pulsar 220 M abhayshanu Motorbikes 203 1st March 2011 14:27
DIY - Projector Headlights for Accent 3seriesCoupe DIY - Do it yourself 84 26th February 2010 13:21
