Old 7th August 2009, 12:52   #1
Default Locking steering column
I have a doubt about the steering locks.
In Santro, with the standard car we can lock the steering wheel. Couple of times, it got locked in Petrol stations and I was not able to steer the car.
How different is that from the steering locks that we hear in these forums ?? Will that deter ( or delay) thief from stealing the car (if the steering is locked with the standard key) ??
gopichinna is offline   Reply With Quote
Old 7th August 2009, 16:27   #2
Thanked: 103,716 Times
You obviously don't mean while driving, do you? If it got locked, while stationary at the pump, that's how it is supposed to work. However, your Santro steering should never lock when the ignition key is in place.
The other type of steering lock that we refer to, is also known as the "grip lock" (don't ask me why). It is basically a long iron rod that locks the clutch / brake pedal at one end, and the steering at another.
Example:
Old 7th August 2009, 16:29   #3
bblost's Avatar
Thanked: 6,980 Times
I have always had a doubt about these locks.
They are made of hardened steel, but what about the steering wheel.
Old 7th August 2009, 16:32   #4
prince_pervez's Avatar
Thanked: 34 Times
Ohh that can be taken care off if the blow is hard enough
Again that will shake up atleast some sensors which would make the autocop wake up the neighbourhood.
prince_pervez is offline   Reply With Quote
Old 8th August 2009, 17:19   #5
No, it didn't lock while driving. It got locked when I took the keys while I stopped the car. When I tried to start the car, I was not able to start the car and steer the car. Initially, I thought that it was a malfunction, as I was not aware of that functionality. Later, learnt that it was a kind of steering lock.
If even Santro has that, then all higher end should have them by default. Then why people in this forum want to buy a separate steering lock..
Old 10th August 2009, 15:44   #6
bblost's Avatar
1. All cars have it, so all car theives know how to break it.
2. The same key as the rest of the car. This becomes especially critical in UV's like the Bolero. Thieves steal the fuel door, use it to forge a key and gain access.
3. People like carrying an extra key with them.
Front wheel .steering column ticking sound.. Need urgent help!! DRC Technical Stuff 34 27th April 2015 11:31
thudding noise in steering column of 980kms driven dzire vdi mountainblood Technical Stuff 12 28th May 2008 11:25
Steering column collapse Lukeskywalker Technical Stuff 12 13th July 2007 20:33
Collapsible steering column for ALTO dsinz Technical Stuff 2 13th September 2006 17:42
