Old 9th August 2009, 13:12   #1
DCEite's Avatar
Thanked: 607 Times
Question Stock replacement air filter for WagonR?
I am looking to replace the MGA air filter with a better and longer lasting one. Looking for marginal increase in FE and performance.
Any recommendations ? Price ?
DCEite is offline   Reply With Quote
Old 9th August 2009, 15:07   #2
nkapoor777's Avatar
Thanked: 91 Times
Last I enquired about an year back, K&N stock replacement filter was available for about Rs. 3,800. It was easily available at most places in Delhi. Don't know what the current price is?
nkapoor777 is offline   Reply With Quote
Old 9th August 2009, 15:07   #3
mnhegde's Avatar
Try K&N stock replacement filter. Its quite good. Difference can be noticed (Pickup wise and FE). I paid somewhere between 3500/- to 4000/- (1 year back) for the stock replacement filter.
mnhegde is offline   Reply With Quote
Old 9th August 2009, 15:21   #4
vdiatech's Avatar
yes, stock replacement K&N I would say. Should be between 3.8 and 4K , I think. If you know someone coming from USA or UK, ask them to bring one for you. Then it would cost you only 2K.
vdiatech is offline   Reply With Quote
Old 9th August 2009, 20:41   #5
gpa
gpa's Avatar
Thanked: 282 Times
DCEite,
A K&N replacement stock filter for the Wagon R will not make any perceptible difference to either performance or FE of your car. If the car is out of the warranty period, you can go in for a K&N replacement filter with a CAI which will give you a noticeable increase in performance.
Pricewise, the stock replacement filter from K&N will be cheaper than the replacement filter with CAI.
Hope this helps
Cheers,
gpa
Old 9th August 2009, 22:30   #6
vdiatech's Avatar
Also, a conical filter must be installed carefully so as to make sure, that the hot air from the engine is not sucked in. This is bound to happen, if you just remove the air box and replace with a conical.
I usually dont prefer such modifications, unless accompanied by heat shields.
It sure will sound good.
Old 10th August 2009, 20:22   #7
DCEite's Avatar
Thanked: 607 Times
I know that conical filter with cold air intake would be a much better bet for performance and FE.
However i was looking for a viable alternative to the MGA stock air filter, which can prove to be a worthwhile investment viz a viz cost difference (MGA costs around 210 and SRF arnd 3.5k) and marginal increase in FE (if any). And like vdiatech said, i too would not like such major modifications (even though my car is out of warranty).
Maybe i will give this stock filter a try.. afterall its not too expensive, and even if there isn't any noticeable change in performance/FE, i know it won't atleast drop the FE or do any harm .
Old 9th April 2010, 15:47   #8
thelightening's Avatar
Stock replacement filters can be fitted on a car without any modifications. I have K&N stock replacement air filter on my 2008 model wagonR. I feel my engine breath well now.. but there is no major difference.
I purchased it for 2750 from Autoshop, Koramangala, Bangalore.
thelightening is offline   Reply With Quote
Old 7th August 2010, 22:02   #9
dhuli's Avatar
Thanked: 47 Times
My WagonR Automatic (2005) has done around 50000km and I was adviced by Pratham Motors Bangalore to replace air filter and spark plugs. Like DCEite mentioned, a year back, I too am wondering what is the alternative to MGA. I have stopped checking FE these days as it is seems to range between 10.5 and 11.5 km/litre petrol with AC on most of the time. I am wondering if I go for the K&N stock air filter, will it give a smoother response? I am ready to go for a stock filter if it improves quality of drive.
If it is ok to post on this thread, what are the recommended brands for spark plugs I could try? I was told Bosch are good. If that is true, where does one get them in Bangalore? I use Bosch wipers (the replaceable rubber parts with the snap on frame). They are far superior to the MGA ones.
Thanks in advance.
dhuli is offline   Reply With Quote
Old 10th August 2010, 16:36   #10
Will it be advisable to change the stock filters in my WagonR (2003 model), will there be any difference in the performance and/or efficiency.
If yes, then can i get a contact for a reliable place to get the filters.
prashantroy is offline   Reply With Quote
Old 11th August 2010, 14:55   #11
You can give the new Crossworth Performance Air Filters a try .... But they will be pricey for sure.
Check in the Crossworth India web site about the parts.
VictorSinha is offline   Reply With Quote
Old 11th August 2010, 22:30   #12
dhuli's Avatar
Thanked: 47 Times
Thanks VictorSinha. I got some nice info on Cosworth from Sankar on Team-BHP. I will try and get this fitted in my WagonR. Have written to Cosworth for authorized rep in Bangalore.
Old 8th October 2010, 19:29   #13
dhuli's Avatar
Thanked: 47 Times
If you were looking at air filters and WagonR, I have shared my experiences on installing a a Cosworth Air filter for my WagonR in this thread - http://www.team-bhp.com/forum/modifi...ml#post2092069.
Old 21st May 2011, 13:10   #14
arjyamaj's Avatar
Thanked: 24 Times
Default Re: Stock replacement air filter for WagonR?
I spoke to the Cosworth people a few days back and they'd be happy to courier their parts for my car. I intend to order a stock replacement air filter for my Alto (MRP: 3300) and an exhaust tip (MRP 1950). Would anyone in Delhi/NCR like to order as well? We might get a company discount if we order in bulk (and certainly on the postage!).
I should be ordering around the first week of June. Let me know
arjyamaj is offline   Reply With Quote
Old 22nd May 2011, 03:52   #15
Thanked: 2,522 Times
What are the benefits of this exhaust tip?
Dry Ice is offline   Reply With Quote
Correct stock replacement Air filter part number for Sonata 2.0 CRDi rohitrk Modifications & Accessories 0 30th January 2009 12:17
Stock Replacement K&N filter for Octavia 1.9 D hitinv Technical Stuff 5 9th June 2008 12:41
Stock replacement Filter for Civic sanchits Modifications & Accessories 12 27th March 2008 08:30
