Old 9th August 2009, 22:47   #1
Thanked: 42 Times
Default Stiffer rear suspension for Marina?
All,
My cousin has a diesel Indigo Marina, and he uses it extensively to carry his scuba diving gear around. With the rear seats folded, he gets ample room to fit all the things he needs.
However, he is facing a problem with the rear suspension, when the car is fully loaded. The body sinks really low when loaded, and the rear suspension bottoms out with every pothole and speed breaker.
Hence he is on the lookout for a stiffer suspension setup. He is willing to replace the current shock-absorbers, but he is not sure what the replacement should be.
One of the suggestions he had received from a mechanic was to fit an additional bush at the top of the springs, but this would only solve the body sinking problem. The suspension will still bottom out. So he is not really keen on this.
Any suggestions? Thanks in advance!
P.S. I don't have much details on the model and make, but it is diesel, with 71k on the odo. Majority of his running is in Goa, but the vehicle is in Pune for another month or so.
sschivate is offline   Reply With Quote
Old 10th August 2009, 07:37   #2
greenhorn's Avatar
Thanked: 1,516 Times
http://www.team-bhp.com/forum/modifi...ica-turbo.html (Suspension for Tata Indica turbo)
most feasible option is to play around with the suspension spring constants and damper stiffnesses - you'll need someone who knows how to do that.
August 2014 Proposal: Stiffer fines, Penalty points for Traffic Offenders Soumyajit9 Street Experiences 134 11th March 2015 15:04
Stiffer Palio Speed Pujari Technical Stuff 5 27th April 2009 22:17
NHC Suspension at 62,000KM - Want a better alternative to the OEM Honda suspension anandpadhye Technical Stuff 15 13th September 2008 18:56
Stiffer Coils for my S10 16v100bhp Modifications & Accessories 15 30th December 2007 17:19
Rear Suspension Change for the Ikon 1.6 danlalan Technical Stuff 5 4th February 2007 21:22
