Old 16th November 2010, 18:31   #46
rk_sans's Avatar
Thanked: 784 Times
Originally Posted by ownerofazkaban View Post
I got this 12342XPS2, H4 60/55W Philips X-tremePower (Made in Germany)
MRP: 1200/-, purchase price 1120/- (including VAT)
Is this original ?
It has Japanese writing on it and also has Philips electronics , Kolkata as Marketing contact/Importer
That's should be fine. Where did you buy it ?
rk_sans is offline   Reply With Quote
Old 16th November 2010, 18:55   #47
sathyaprakash's Avatar
Thanked: 44 Times
I have one question does Philips X-tremePower H4 comes in 90/100? I am currently using Narva from Germany which is sightly white 90/100 in ANHC & i am using Hella cutout with ceramic holders but after using it for more than three months i think the white light is not sufficient & planning to change my bulbs any suggestions other than Philips Rally 90/100 as i already used it, before changing to Narva for the taste of white light
sathyaprakash is offline   Reply With Quote
Old 16th November 2010, 23:47   #48
Thanked: 38 Times
Infractions: 0/1 (5)
Lathangi Ford. initial impressions (in city) is, its definitely better.
ownerofazkaban is offline   Reply With Quote
Old 7th August 2012, 16:56   #49
Thanked: 57 Times
Default Re: Review : Philips Xtreme power bulbs for my M800
Hey,
Need to remove confusion between adding relays or not while using Philips Rally 100/90 for my M800.
When I purchased it and asked the sales person if I would require relay with this bulbs, he said it is not required. I confirmed this with other 3 shops also with everone telling the same thing.
However, as per this thread i feel that a relay would be required.
TBHPians, kindly clarify if relays would be required or not?
rahulk2510 is offline   Reply With Quote
Old 7th August 2012, 18:56   #50
Jaggu's Avatar
Thanked: 8,693 Times
Originally Posted by rahulk2510 View Post
Hey,
Stock is 55/60, so if you are upgrading from that to 90/100, you need to upgrade the wiring. This is to avoid any additional load on the switch gear and wiring, which are originally not designed for the additional load that 90/100 puts.
Old 8th August 2012, 15:08   #51
Thanked: 57 Times
So if I am clear, i would need to change wiring only and can do wothout adding a relay in my M800.
Sorry to ask such naive questions!
Thanks a lot.
Philips Rally Bulbs Headlamps jkdas Modifications & Accessories 32 8th May 2018 18:58
Philips Xtreme H4 60/55W headlamps - price subhashnm Modifications & Accessories 120 30th March 2018 18:34
Philips Vision Plus / X-Treme Power bulbs in Chennai for Avenger VSG12777 Motorbikes 41 24th June 2015 21:05
Philips Vision Plus H4 Bulbs madbullram Technical Stuff 269 16th December 2010 07:56
philips blue vision h4 bulbs 65/55w dadudeonfire Shifting gears 5 31st October 2005 18:24
