Old 24th August 2009, 21:27   #1
Thanked: 2,470 Times
Default Zen Carb for a VW
Hi Guys,
A Strange set up and a stranger request for info from some technical experts on the Forum
Firstly the topic for discussion is the "Zen Carb" used in a 1600 Rear Wheel driven , Cylindrically opposed Twin Port-Two sided Aircooled engine VW Bus.
I have ditched the original 34 PICT -2 VW Carb (Pathetic FE~5 kmpl) and have gone in and modified the Intake Manifold so that i can fit in a better carburetter (ZEN) only for the reason of getting a better carburation and FE.
Firstly = Am i right in doing so ( I dont care about the originality- For me practicality is more important than the vehicle being a show piece), how can i better it?
Secondly = What are the the lop-sided effects / advantages of using this set-up .Presently the Bus is running fine without any issues, the Secondary butterfly is been disabled presently (Will this pose a problem)
The third problem that i am facing right now is the vehicle is running RICH (making me poorer) with a low FE.
Request guys with information to kindly contribute. Thanks in advance for all your help.
Old 25th August 2009, 12:23   #2
Psycho's Avatar
Thanked: 95 Times
Yes you can but it will require re-jetting to get it to work well. You could also look at the conti carb as another option.
Old 25th August 2009, 21:44   #3
Would the Conti Carb fit the flange base meant for the Zen carb?
If using the same Zen carb, what do i do with jetting, what sizes do you suggest.
the 90bhp+ carb zen speedsatya Modifications & Accessories 6 14th November 2009 11:00
99'ZEN carb to ZEN mpfi.... Balram Modifications & Accessories 17 10th December 2006 09:04
K&N Required For A Zen Carb. greddy Modifications & Accessories 11 1st November 2006 16:27
vibrations in zen 97 carb. heavy_foot Technical Stuff 11 30th May 2005 11:01
carb zen suspension options? heavy_foot Technical Stuff 14 15th May 2005 11:59
