Old 23rd September 2009, 11:10   #121
greenhorn's Avatar
Thanked: 1,422 Times
ripper, so is your swift running a DTE ECU ?
I thought it had the PSI tuning box?
greenhorn is online now   Reply With Quote
Old 23rd September 2009, 11:17   #122
Awaiting Email Confirmation
Thanked: 19 Times
No, I was running the PSI box. Now using the Diesel Inside Remap. No tuning box. DTE was put there just for comparison
Old 25th September 2009, 14:24   #123
l_tejash's Avatar
I am also looking for Advans or similar range tires of size 205/55 R15 for my Swift. Any other suggestions?
I have heard that the Advans ware out very fast
l_tejash is offline   Reply With Quote
Old 25th September 2009, 15:12   #124
iraghava's Avatar
Thanked: 154 Times
Get the Michelin PP2's, they're your next best options.
Old 25th September 2009, 15:55   #125
chiragh_bir's Avatar
Thanked: 69 Times
good to see you Khusanth here ..
And congrats for your new Swift
won't be 205/55 R 15 overkill for swift ?? i think 195/55 are best suited !!
chiragh_bir is offline   Reply With Quote
Old 25th September 2009, 17:11   #126
Thanked: 19 Times
i think you meant 195/60, which is the closest you can get to stock OD
195/65 would be ideal, but i dont know of any good brands in that size
195/55 would make an even bigger speedo error than 195/60, which itself is slightly off
Old 25th September 2009, 17:18   #127
Thanked: 69 Times
here am not talking about speedo error but the tyre size which will be best suited for small cars like swift...
195/65 R 15 i won't recommend as the car is lowered and it might touch the fenders if it is loaded with passegers or heavy luggage
205 /55 will also affect fuel economy and also the vehicle's initial and top end !! and this size will make the steering wheel too heavy more than 195/55 !!
Old 25th September 2009, 20:46   #128
yzfrj's Avatar
Thanked: 118 Times
here am not talking about speedo error but the tyre size which will be best suited for small cars like swift... !!
Some people need Fuel Economy so they keep it 165/80/14 (Stock)
Some need a bit more comfort so they too keep it stock.
Some need a bit more grip they do 185/70/14
Some need looks + Grip the upsize to 15/16/17 even.
Ride goes out the window and you bottom out most of the time.
I personally feel 195/60/14 are enough for a Stock swift again 195 AD07 might be over kill for some. (EDIT: my next planned upgrade)
There is no easy or final answer.
It all depends on how you drive and what your priorities are.
yzfrj is offline   Reply With Quote
Old 26th September 2009, 11:58   #129
Thanked: 69 Times
sir please read my post carefully
am talking about 195/55 R 15 and not 14 inch !!
If 14 inch 185 /60 is the best bet !!
Old 27th September 2009, 10:25   #130
Fountainheader's Avatar
I guess we need to use these tyres before posting such statements.
I had 195/60/R15 Yokohama A-Drives for around 8k kms before I moved on to Michelin PP2 205/55/R15. The steering wheel at the start was a bit heavy, but after the "run-in" period of the tyres, its just perfect. Almost like it was with the A-Drives. But maybe compared to the stock 185/165 tyres, you might feel it a bit heavier.
And never cared to check FE before/after nor will do
Fountainheader is offline   Reply With Quote
Old 27th September 2009, 18:38   #131
Thanked: 69 Times
dude i have tested and only then i commented ..
and if you can , try fitting 195/60 back on your ride and you will know , its only that you got used to driving with 205/55 R 15...
and again i said IMHO 195/55 is best tyre for swift .. but you can fit anything you like no need to start a war man !!!
Old 27th September 2009, 22:48   #132
abhibh's Avatar
Thanked: 33 Times
Best upsize for swift in 15" 195/60-15 205/60-15
and in 16" 195/55-16 205/55-16
Old 27th September 2009, 23:04   #133
karankapoor's Avatar
Abhi i think 205/60/15 and 205/55/16 both will touch the inner wall on pot holes or with full load.
Ideal would be 195/60/16 and 205/50/16 but will say stick to 15" for comfort as compared to 16
karankapoor is offline   Reply With Quote
Old 28th September 2009, 09:03   #134
Thanked: 69 Times
guru ji .. try the sizes in a lowered swift and you will know !!
again i said "IMHO" if i buy swift and plonk 15 inch i will use 195/55 R 15 the same am using in my getz !!
Old 28th September 2009, 09:37   #135
akshay4587's Avatar
Thanked: 1,629 Times
Sir he is right
how many swifts have you driven with upsize tyres
there is a lot to consider rather than goin down on profile for no reason.
195\55R15 is a correct upsize for getz,so it doesnot mean its correct for swift too.
195\60R15 or 205\55 R15 but 205 would be a slight overkill
My ka Laal: Swift - Oye VDi, VDi Oye! - 12 months, 29.3k km UPDATE phamilyman Long-Term Ownership Reviews 89 7th May 2010 17:13
Why is Ritz VDi more expensive than the Swift VDi ? Tapan The Indian Car Scene 49 1st June 2009 18:19
Swift VDI or Getz GLX-6L Budget EDIT: Bought VDI agm Hatchbacks 29 11th April 2008 22:56
Maybach goes mad racing4cure The International Automotive Scene 7 15th December 2005 13:57
Things that drive you mad normally_crazy Shifting gears 3 22nd April 2004 04:29
