View Poll Results: The best airfilters around..
K&N Air Filters 141 58.51%
Pipercross Air Filters 23 9.54%
Greencotton Air Filters 57 23.65%
Othes 20 8.30%
Voters: 241. You may not vote on this poll
Old 13th August 2009, 10:25   #106
agbenny's Avatar
Thanked: 113 Times
Voted for K&N, since I do not have any experience with others. I know its not the right way to do, But I am happy with K&N in my present Aveo, after changing it gave me much difference in ride. Overall I am happy about it.
I have also explained this to the one to whom I am selling it now.
But for Scorpio mHawk, Will green cotton be better? Any ideas /experiences - please through it here, Thanks.
BTW - Anyone knows how frequently we should wash the Filters? How to find out the right time for cleaning the filter?
Thanks,
agbenny is offline   Reply With Quote
Old 13th August 2009, 14:09   #107
vdiatech's Avatar
Hello, are you using the replacement filter or the conical ( CAI etc ) ?
vdiatech is offline   Reply With Quote
Old 17th August 2009, 12:32   #108
jkdas's Avatar
Thanked: 1,435 Times
Originally Posted by gemithomas View Post
Any Idea on where i can get green cottons in trivandrum. Also i've heard GC is better than K&N for Palio. ANy idea?
Thanks.
You can contact Jerrish or even Peter directly. He had send a mechanic from Cochin to fix GC Wind for my Xing.
Old 17th August 2009, 14:58   #109
BHPians,
Any advice on which filter to be used on a OHC 1.5 exi.
Questions to all
1. Do i opt for a K&N stock replacement filter / Conical filters or Green cotton stock /
conical filter
2. Can i have prices and part numbers for both models, if handy
Also OHC owners, pls share your experiences with any of the above filters, as i see there are very less reviews of filters fitted on a OHC
Speedzone is offline   Reply With Quote
Old 17th August 2009, 15:29   #110
KSM-Vtec's Avatar
Thanked: 440 Times
I have the K&N Conical. Its good, i like the sound and the fact that it smoothens the revs. dont think it makes any significant difference in the performance and FE(in city). FE on the highway improves a bit.
Originally Posted by Speedzone View Post
BHPians,
Questions to all
conical filter
KSM-Vtec is offline   Reply With Quote
Old 20th August 2009, 10:34   #111
Thanks for your suggestion KSM-Vtec, but i'm not looking at a conical filter at this point of time, wanna do the mods step by step. As of now stock filter fits in to my budget.
BTW what is the mileage(City and Highway) you are getting with the conical filter on your OHC
Old 17th September 2009, 11:55   #112
Mr_Bean's Avatar
Thanked: 136 Times
Default pipercross for baleno
anyone used the pipercross conical filter for the baleno's, i am planning to get one for mine.
Appreciate your feedback..
Mr_Bean is offline   Reply With Quote
Old 17th September 2009, 17:45   #113
KSM-Vtec's Avatar
Thanked: 440 Times
City with 100%AC - 10kmpl
Highway with 100%AC - 14kmpl
Old 22nd September 2009, 19:25   #114
Thanked: 25 Times
Default Air Filters - K&N vs Greencotton vs Pipercross
hey , i have a 2006 Getz....i have just installed a Simota conical filter.....but am worried about the filter sucking in hot air from the engine bay...also the danger of water splashing onto the filter.....i was thinking of fabricating a heat shield or an induction box.....plzz advice me if it is a good idea and if yes how to go about??...also which material?
below r the pics....as u can see i have fastened the filter with an elctrical wire also plz comment on the placement of the filter.
Note from the Team-BHP Support Team : Please take the time to use proper punctuation as per Team-BHP rules. Avoid...typing...like...this. Thanks.
Last edited by Technocrat : 22nd September 2009 at 19:41. Reason: Please read the note in post, thanks
fastraj is offline   Reply With Quote
Old 22nd September 2009, 19:37   #115
Akshay1234's Avatar
Thanked: 7,210 Times
see my gallery. youll see a pic of the conival filter i have and how its fastened. do it like that. also there is no better position than this without making changes to the engine bay components. dont worry about water.
Old 22nd September 2009, 19:52   #116
ElantraGT's Avatar
@fastraj - Dont worry about weater splashing on these filters, these are designed to take that burden. The way akshay has fitted this filter is neat. A custom clamp will do the trick, you can weld the other end of the clamp to the base (create a custom metal base) of the filter. I would advise you to take a color printout of Akshays filter fitment to your mechanic. its tough to explain the setting to them. Hope this helps.
ElantraGT is offline   Reply With Quote
Old 22nd September 2009, 19:58   #117
Rudra Sen's Avatar
Thanked: 4,287 Times
Mods note: Thread merged.
Old 22nd September 2009, 21:39   #118
gigy's Avatar
Thanked: 41 Times
You do know what happens to engine due water going into it. all are air filters not water filters. During car wash do cover it up with a plastic bag and do remember to remove it before starting.
Do secure the filter properly and also see if its possible to place it any other way such that battery fumes dont keep entering it all time. kits for filters take care of these.
Old 24th September 2009, 01:06   #119
rohan_fonseca's Avatar
The rubber from the Air intake hose to the air filter rubber is not a good hold. Add a short SS pipe in between. Also replace the wire with a Clamp.
rohan_fonseca is offline   Reply With Quote
Old 24th September 2009, 09:46   #120
sgiitk's Avatar
Thanked: 3,864 Times
Infractions: 0/1 (4)
After reading the Spicer Report and given our dusty conditions K & N is a definite no-no.
Feedback on Pipercross Viper Intakes Invinsible Modifications & Accessories 12 8th March 2009 14:21
K&N filters V/S Proton filters mail4ajo Modifications & Accessories 1 25th April 2006 00:34
(K&N) Cotton Gauze Air filters help/freeflow == more dirt ? zenx Modifications & Accessories 21 9th February 2006 11:34
