Old 19th July 2005, 13:05   #31
EVO6's Avatar
Well someone mentioned about result with K&N ... I have a K&N for my Merc but havent installed it as yet as I want to install and take the car for a test run and thats exactly what we had planned for last sunday but it didnt work out ...
Will try to get the Vbox again when we have many enthusiast to do testing ...
EVO6 is offline   Reply With Quote
Old 19th July 2005, 13:07   #32
Thanked: 34 Times
Hi Pete,
Just one question from me:
How does the engine life span get affected because of the box? Will it increase/decrease the engine life span significantly?
Cheers,
deepakhon is offline   Reply With Quote
Old 19th July 2005, 13:14   #33
Thanked: 103,672 Times
@EVO6 - How an earth did your Mercedes manage a 8.1x second 0 - 100 kph run? How accurate was the timing? Any other modifications?
Old 19th July 2005, 13:18   #34
turboindia's Avatar
Originally Posted by Revvhead
I think what he's saying is that the tata owners are interested,
But his pricipals have certains principles that they stick to , i.e - putting out a quality , tested & reliable product and are not willing to damage their reputation, by having the tata engine go bust on them, after which the inger poiting will head towards pete & PSi
EXACTLY WHAT I MEANT CAUSE PSI WOULD DO A UNIT ONLY AFTER INTENSIVE TESTING
turboindia is offline   Reply With Quote
Old 19th July 2005, 13:25   #35
turboindia's Avatar
Originally Posted by deepakhon
Hi Pete,
Cheers,
According to PSI the life span of your engine will change only if you are really using the extra power all the time which is actually not possible in day to day life. Like if you have modified your engine for more power and are using the car on the track only running full throttle mode 99% of the time then you can get a reduced lifespan. We are talking about normal turbo diesel cars here that are mostly used for A to B transport and we feel you should not have any significant difference in the life span of the engine. Just a more happier, comfortable and smoother ride.
HAVE FUN
turboindia is offline   (1) Thanks Reply With Quote
Old 19th July 2005, 13:30   #36
EVO6's Avatar
GTO,
Thats exactly what i am telling you man ...
The car actually was flying ... No other mods ... Not even a K&N .. Was using Plus 1 setting ...
When we do our testing next will let u test drive mah baby then u will know ...
Old 19th July 2005, 13:59   #37
Absolutely mindboggling, EVO. You have yourself an RS killer! So, theoretically the C220 could manage a better time with the powerbox - being lighter and a 6 speed manual?
Diesels rock
Old 19th July 2005, 14:04   #38
turboindia's Avatar
Diesels rock
and you behind the wheel. Sure you'll better the E220. No doubt. Dying to try it I can see. What is your ODO reading now GTO?? Running in still??
Old 19th July 2005, 14:19   #39
EVO6's Avatar
GTO,
Definitely the C is going to be much faster ... We can try it when we do testing just let me know when .. infact you have a Gtech Pro meter rite? we can use that too when doing testing ...
As a matter a fact the MERC engines are already broken in when they get assembled in the car... Since Bajaj Tempo assembles the engine they break in all engines before delivery to DCIL ... I know this coz the owner of Tempo is a Good Friend ..
TI,
You shud shift base to Maharashtra .. U missing out on all the action ..
EVO
Old 19th July 2005, 14:27   #40
Rtech's Avatar
Thanked: 221 Times
wassdat! Bajaj Tempo assembles all the DCIL engines?
Old 19th July 2005, 14:33   #41
EVO6's Avatar
Dont be so shocked my friend.... They have been doing it since DCIL ever came into India ... Tempo got the contract since they were already using a Benz engine for their traveller ...
Old 19th July 2005, 14:49   #42
Conan's Avatar
Post
Also "Tempo" is a trademark registered to daimler crysler.
If i remember correctly, the tempo traveler uses a 3L merc diesel engine.
Can it be plonked in a car?
Conan is offline   Reply With Quote
Old 19th July 2005, 14:54   #43
Rtech's Avatar
Thanked: 221 Times
I know Tempo had a tie up with MB for their engines, but I had no clue they assembled the engines for the cars as well. I thought the engines were brought in as complete units?
Old 19th July 2005, 14:55   #44
mohit's Avatar
Thanked: 125 Times
DaimlerChrysler is the original owner of the Tempo brandname. Daimler Chrysler had signed a technical collaboration with Bajaj Tempo in 2003, to provide technology for common rail diesel engine. Bajaj Tempo is still an important supplier to DaimlerChrysler India, for the requirements of Mercedes engines in India.
The Source - Dance With Shadows
mohit is offline   Reply With Quote
Old 19th July 2005, 21:07   #45
Mpower's Avatar
Thanked: 1,687 Times
The engine that Tempo builds is the OM616 used in the Trax and Traveller.
Not sure if they are assembling the C220 engine, but in the future the same engine will be used in the Tempo and
Trax replacing the OM616 after its fully indigenized.
Tuning Box versus Remaps (Diesel tuning) Ravveendrra Modifications & Accessories 154 29th April 2018 22:45
Spider Diesel Tuning Box VS. Pete's Tuning Box - Spider Box feedback on pg 2 Endeavour333 Modifications & Accessories 130 11th September 2017 01:24
Swift with Pete's Digital Diesel Tuning Box. EDIT : Green Filter added BUSA Modifications & Accessories 323 23rd August 2013 08:57
The Dawn of Turbo Diesel Tuning in INDIA - Pete's Tuning Box turboindia Modifications & Accessories 108 17th April 2006 12:33
pete's tuning box for my diesel car karanbajaj Modifications & Accessories 2 13th April 2006 17:15
