Old 1st June 2011, 12:13   #676
Sridhar K's Avatar
Thanked: 188 Times
Default Re: Jopasu Car Duster - A mini review
Originally Posted by sureshkishore View Post
Has anyone tried cleaning the duster with compressed air, as you would with an air filter. Think it should work. From what I have read in the thread the duster works best when unwashed.
I do that frequently but my duster is hardly a few months old and hence would need to wait and see whether the technique is effective
Sridhar K is offline   Reply With Quote
Old 1st June 2011, 12:44   #677
akash_m's Avatar
Thanked: 85 Times
Rejoice Guys!
An exact 'Made in China' replica of Jopasu car duster is avilable in NCR for Rs 99/- only!
It has the same dust picking ability as the Jopasu duster. I picked up 3 at a time before they run out of stock..
akash_m is offline   Reply With Quote
Old 9th June 2011, 20:44   #678
kri$hna's Avatar
Thanked: 29 Times
Originally Posted by akash_m View Post
Rejoice Guys!
Only in NCR ? any idea if its available online for order towards hyd ?
kri$hna is offline   Reply With Quote
Old 10th June 2011, 17:01   #679
akash_m's Avatar
Thanked: 85 Times
I dont think it is avilable on the net.. I got it from Noida..
Old 21st June 2011, 14:42   #680
rohitm's Avatar
Thanked: 42 Times
I am planning to take the plunge ...rather plunge the Jopasu in a bucket of water. Based on the feedback on this thread so far i guess i will be sticking to plain tap water and will not be using any soap/shampoo. Will update the thread with results.
rohitm is offline   Reply With Quote
Old 21st June 2011, 14:44   #681
fine69's Avatar
Thanked: 717 Times
Just don't dry it under direct sunlight afterwards.
fine69 is offline   (1) Thanks Reply With Quote
Old 21st June 2011, 14:46   #682
Thanked: 82 Times
I bought the jopasu duster from ebay a couple of weeks back. The delivery time was excellent (2 days from date of placing order). The duster is very good at picking up dust from across the car - most times, a single wipe is enough. The only issue is that my hands start aching by the time I finish. I wish the handle was longer so that I could use both hands or that the angle of the handle was better so as to improve the ergonomics.
hajaar is offline   Reply With Quote
Old 21st June 2011, 21:00   #683
rock18's Avatar
Thanked: 54 Times
Excellent tip.
I read it a bit late.
My duster was getting so dirty that i decided to take the plunge.
Washed it with directly under the tap without any detergent and dried it in the sun.
Voila!!!! It stopped working
It just like a broomstick.
Any tips on getting it back to shape?
rock18 is offline   Reply With Quote
Old 22nd June 2011, 11:37   #684
fine69's Avatar
Thanked: 717 Times
If the handle was any longer I don't think that would cure the aching in your arm as the weight would only increase, however insignificant. And then comes the storage part also, longer means more space to store it, angle in the handle means it would take up all the more space, folding handle would mean more cost and high probability of the plastic handle breaking from the folding point, just my opinion.
Originally Posted by rock18 View Post
Excellent tip.
The strands of the duster originally have wax which has now been lost, so yes you are right when you say that its like a broomstick now. A DIY would only be possible if (1) we knew what kind of wax was on the strand (2) how much wax was on each strand and (3) figure out a way of applying the wax evenly on each and every strand.
You may continue to use it as it would still be removing the dust if not pick it up or else just buy a new one, don't think we can respawn it.
Old 12th July 2011, 16:44   #685
A new version of the duster is to be launched, it has better strands, heavier too. Not sure if its started to sell and exact price - supposed to be R 100 higher approximately. My old one is going strong!
hemantbsutar is offline   Reply With Quote
Old 14th July 2011, 12:06   #686
rohitm's Avatar
Thanked: 42 Times
I washed the Jopasu after 5 months of use. Cleaned it without any detergent under tap and also by plunging it in a bucket all with cold water.
Was careful not to dry it under sun. It took 3 days to dry out.
I seems to be working fine .
rohitm is offline   (1) Thanks Reply With Quote
Old 26th August 2011, 02:03   #687
AbhiJ's Avatar
Thanked: 326 Times
Soft Microfiber Chenille Car Cleaning Dusters - Orange + Green (2-Piece Pack) - Free Shipping - DealExtreme
Similar dusters on DealExtreme
AbhiJ is offline   Reply With Quote
Old 26th August 2011, 18:02   #688
S_U_N's Avatar
Thanked: 368 Times
Any reviews on the new version of the Jopasu duster which has white strands (the old one had gray strands)?
S_U_N is offline   Reply With Quote
Old 29th August 2011, 14:33   #689
I happened to talk to a user who is not on this forum, the new one is clearly better. It has more weight as the strands are thicker and more durable. Even the guys from UD(mkh and nirmal) told me the same. I am planning to change to the new one soon, the cost is 100 bucks more.
Old 31st August 2011, 12:01   #690
Thanked: 15 Times
Got the duster with the new white strands, yesterday, used it only once. Its good, removes dust without a trace. When I ordered for it, I did not expect it to be this good, wanted to try it for the sake of trying. Got it from ebay, delivery time was great too, 2 Days flat. The microfiber cloth for wet wipes are good too, soaks up a good amount of water. It does leave a very fine water stain if not wiped completely dry. Also was wondering how the white strands will look after a couple of months, considering that it should not be washed with water.
Have not used the old grey one, so cant help with the comparison.
Statement is offline   Reply With Quote
DIY: Cleaning & rejuvenating the Jopasu Car Duster bowser DIY - Do it yourself 16 8th September 2016 09:18
1st ever Mini meet in Calicut. Post here for all future Calicut mini meets.. MaserQ The Team-BHP Meet Section 16 23rd June 2016 12:33
Paid for Duster 110. GenNext Motors gave us a Duster 85 instead. EDIT : Solved (Pg 2) mohandasnikhil Indian Car Dealerships 74 7th November 2012 23:59
New Mini "Mini/ Minor" CARDEEP The International Automotive Scene 0 17th July 2010 10:46
