Old 30th September 2009, 14:35   #1
recshenoy's Avatar
Thanked: 104 Times
Cool High pressure car washer using air compressor
Hi All,
I have an air compressor at home. I was wondering if we can build a high pressure car wahser using this air compressor?
Any body has tried this? how much does the fitment costs?
Please advice
recshenoy is offline   Reply With Quote
Old 30th September 2009, 20:39   #2
hellstar's Avatar
Thanked: 17 Times
Originally Posted by recshenoy View Post
Hi All,
Please advice
@recshenoy , yes you can use the air compressor to high pressure car washer, you just need to get the correct tools , run a check in yellow pages for automobile service equipment.
I once saw a guy use the air compressor from a borewell pomp to run a high pressure washer, so you should be able to do it as well .
One curious question though , what do you use the air compressor at home for ?
hellstar is offline   Reply With Quote
Old 1st October 2009, 09:59   #3
recshenoy's Avatar
Thanked: 104 Times
Thumbs up Thanks hellstar.
Thanks hellstar.
One of my relatives has wave soldering machine which needs compressed air. He stays near my house so i thought, when compressor is free I can use that for cleaning my car
Currently little busy (rather lazy ) , will check the extra fitment needed next week.
I have seen people using compressor for spray painting. But its not pressurized. I am sure, similar fitment must be available for presssurized painting as well!
Buying & Using a Pressure Washer jp1 Modifications & Accessories 995 15th July 2018 11:48
Air-con compressor in a diesel car does not trip? TaurusAl Technical Stuff 86 27th August 2016 20:59
Convert Air compressor to a Pressure water washer? rajivanoj Technical Stuff 5 3rd February 2014 00:45
The 'Actual' Tyre Pressure : Is Atmospheric Pressure Counted? sr_1445 Technical Stuff 2 16th January 2014 11:05
Air Compressor for tyres alexrabbi Tyre & Alloy wheel Section 3 22nd September 2008 21:52
