Old 10th January 2009, 13:10   #181
amit_mechengg's Avatar
Thanked: 1,556 Times
Though this is not my engine bay, a clear picture of alto engine bay looks like this
Old 10th January 2009, 13:15   #182
vikram_d's Avatar
Thanked: 940 Times
According to this picture it is a single coil ignition system. You can see the coil very clearly on the top right of the photograph. It is the black tube thing with the red wire cap on it. I have highlighted it in red.
It is a very simple DIY according to me.
Old 10th January 2009, 13:15   #183
UniqueMods's Avatar
Thanked: 50 Times
here the pic to a santro fro a 2008 santro.
wheres the ignition coil?
http://www.team-bhp.com/forum/techni...ml#post1046268 (K&N filters)
sushruths's should be the same.
Iam also looking to install a tacho in my santro but cant find a tacho with a 2 cylinder setting in mumbai.
anyone knows any specific place, please let me know.
UM
UniqueMods is offline   Reply With Quote
Old 10th January 2009, 13:34   #184
yes and i couldnt see any waste spark disposal or passing on spark to any other cylinder on an alto. so i think i will go the shop ask him to connect just the power cable and the coil and crank the engine. if the RPM is correct then i shall buy.
Old 10th January 2009, 13:38   #185
vikram_d's Avatar
Thanked: 940 Times
You should do that. It will work if the gauge has a selector switch for a three cylinder engine.
Like you said just connect the coil signal wire as per the wiring diagram, the power wire to the battery positive and ground wire to any body earth point and start your car. You should see the RPM on the gauge.
Old 10th January 2009, 13:41   #186
badboyscad's Avatar
Thanked: 172 Times
Originally Posted by vikram_d View Post
Can you post a clear picture of your car's engine bay. We should be able to make out if it is single coil or dual coil.
Here are some pics of an alto(0.8L)'s engine bay:
badboyscad is offline   Reply With Quote
Old 17th January 2009, 12:14   #187
finally i got an autogauge tacho with shift light and 7color display. and it was a simple installation. the tacho shows accurate RPM and it takes the signal from the negative terminal of the coil.
i have currently set the shift light at 3000 RPM. the bluish pink light with red illuminated needle looks awesome and now i am getting a nice feeling of the engine due to the RPM it shows.
Can someone tell me, what is the optimum RPM for alto to get maximum fuel efficiency?
One more thing i wanted to know is how do i shift without over revving? how do i judge the RPM at which i am overrevving?
Old 17th January 2009, 12:31   #188
Vid6639's Avatar
Thanked: 21,086 Times
Can you post some pics please.
Old 17th January 2009, 12:48   #189
yogisays0909's Avatar
Thanked: 189 Times
Default Pics of my Tacho
Here is a pic of tacho fixed in my Carb Esteem.
yogisays0909 is offline   Reply With Quote
Old 17th January 2009, 13:14   #190
yes i will click the pics in the eve and load them. during the day time the backlights are invisible.
Old 17th January 2009, 22:42   #191
yatinchoubal's Avatar
Nice snaps, yogesh. Wished to see, more light over the tacho, to see it more clearly.
But overall nice set up.
yatinchoubal is offline   Reply With Quote
Old 17th January 2009, 23:06   #192
Thanked: 189 Times
Alright here is clear pic
Old 18th January 2009, 23:23   #193
here are the pictures of my tacho. sorry about the pic quality. well someone here, i think sumeeth was complaining that the centre button on his tacho isnt working. the centre button is used to change the display color.
amit_mechengg is offline   (1) Thanks Reply With Quote
Old 18th January 2009, 23:25   #194
arpandiv's Avatar
Thanked: 27 Times
how much did the autogauge tacho cost?
arpandiv is offline   Reply With Quote
Old 18th January 2009, 23:31   #195
Fountainheader's Avatar
Amit,
The tacho looks good. Colors are fancy, do you plan other gauges too ? Voltmeter and stuff ?
Fountainheader is offline   Reply With Quote
Case for Tachometers on all Bikes and Scooters anjan_c2007 Motorbikes 27 10th April 2012 11:44
Post pictures of Tachometers here! streetracer_919 Modifications & Accessories 0 8th June 2009 12:02
Tachometers /Odometers/Fuel-tempGauges Rahulk76 Modifications & Accessories 1 10th March 2006 16:53
