Old 19th January 2009, 03:28   #196
nikibusa's Avatar
Thanked: 16 Times
Yogesh..Finally i get to see the pics of your ride on the forum. Good to see you here. Now why dont you post the video of your exhaust? Start a new thread in mods and accesories and see what members have to say.
nikibusa is offline   Reply With Quote
Old 19th January 2009, 10:03   #197
yogisays0909's Avatar
Thanked: 189 Times
Niki, Pics and video of my ride are already under this thread.
http://www.team-bhp.com/forum/modifi...ed-esteem.html
yogisays0909 is online now   Reply With Quote
Old 19th January 2009, 10:31   #198
amit_mechengg's Avatar
Thanked: 1,556 Times
Originally Posted by arpandiv View Post
how much did the autogauge tacho cost?
Rs. 2300 plus wiring and fitting Rs.200 (kind of DIY)
Originally Posted by Fountainheader View Post
Amit,
The tacho looks good. Colors are fancy, do you plan other gauges too ? Voltmeter and stuff ?
in the snap the colors look vibrant,but in real they are not that bright. ya they are fancy, but look nice and sporty. no plans of other gauges. Mine is an ALTO
Old 23rd January 2009, 11:56   #199
Thumbs up The Tachometer Effect
checked the FE of my alto today after fitting the tacho. it was a whooping 16.7 against my earlier figures of max 15.8. This was all under city driving conditions.
after fitting the tacho i have developed a habit of shifting at max 2000 rpm without any power loss. with 5th gear my alto easily cruises at speeds of 60-65. for 80 KMPH the tacho reads 3000 rpm.
i have started interacting with my engine more and my car is happy with it and returning some compromising FE figures. cheers:
Old 23rd January 2009, 17:44   #200
Thad E Ginathom's Avatar
Thanked: 8,375 Times
...And I have just been ranting on other threads about how useless tachos are!
Well, I guess I have to climb down a rung and admit they can be a useful learning tool
<Blush>
Old 28th January 2009, 14:15   #201
sumeethaldankar's Avatar
Thanked: 1,154 Times
Hi Amit,yes i have the same tacho as you,but my color display button does not work.I am stuck with the red display at night anyways good for you.The colors are pretty good.Enjoy :-)
sumeethaldankar is online now   Reply With Quote
Old 28th January 2009, 14:21   #202
i guess u can open the tacho and check whether other LEDs are present and if not u can change the color.
personally i dint like the red color. the dial as well as the needle looks red. it looks " BLOODY" ha ha
Old 28th January 2009, 14:57   #203
vikram_d's Avatar
Thanked: 940 Times
Congrat Amit, you finally got it done. It looks neat.
@Thad - Better late than never. :-)
Old 28th January 2009, 15:01   #204
rider60's Avatar
Thanked: 47 Times
are bhai ab to batado diesel gaddi swift diesel mein tacho kaisa lagai??
atleast now some one help me to find and fit a tacho in my diesel swift ldi, i know autoguage makes diesel tachos and i need one on my swift diesel any one has any leads to fixing tachos on a diesel car????
been asking the same question for almost rather more than a year now, gurus where are you guys ???
rider60 is offline   Reply With Quote
Old 28th January 2009, 15:10   #205
@ Rider60,
can you do one thing. go to the MASS and ask them to hook a tacho which they have.its a analog one. it looks like multimeter(analog) which they use it for old non mpfi cars. check with them where from they tap the tacho reading. verify with them is that the correct reading. then i can help you with the wiring.
Old 28th January 2009, 15:24   #206
vikram_d's Avatar
Thanked: 940 Times
From what little I know and what I could find on the net there are three ways to connect a tachometer on a diesel.
1. Connect tacho to the RPM signal wire going to the ECU. This should work on the LDi and also will be the simplest to do.
2. Connect to the alternator. But this needs a custom made circuit for it to give accurate readings.
3. Use a magnetic proximity type sensor and get reading from the flywheel. But this will entail drilling a hole on the side of the bell housing for fitting the sensor. Also for this you will have to know how many teeth are present on the flywheel and calibrate the tacho according to that.
Seems like a diesel tacho is not as simple as a petrol one.
Old 28th January 2009, 16:15   #207
Angry
personally i dint like the red color. the dial as well as the needle looks red. it looks &quot; BLOODY&quot; ha ha
at night if get's too much red in my face , i simply cover it with a cloth.
Old 31st January 2009, 00:00   #208
rider60's Avatar
Thanked: 47 Times
thanks for the suggestions guys, i will try that at MASS my next visit, and definitely consult you guys once i have the tacho bought thanks for the reply at last.
Old 31st January 2009, 23:46   #209
Puzz's Avatar
@rider60, i visited some shops looking for some head units, if you are looking for tacho for SWIFT diesel visitthe store CHEQUERED FLAG in ministers road, he has a few really good options of tacho for diesel SWIFT.
Puzz is offline   Reply With Quote
Old 2nd February 2009, 00:00   #210
rider60's Avatar
Thanked: 47 Times
thanks i know the person there well already puzz, i tried that i it dint workout for me so still searching.
Case for Tachometers on all Bikes and Scooters anjan_c2007 Motorbikes 27 10th April 2012 11:44
Post pictures of Tachometers here! streetracer_919 Modifications & Accessories 0 8th June 2009 12:02
Tachometers /Odometers/Fuel-tempGauges Rahulk76 Modifications & Accessories 1 10th March 2006 16:53
