Old 20th July 2009, 11:51   #286
gpa
gpa's Avatar
Thanked: 282 Times
Originally Posted by ghostrider View Post
Finally, MUL reverted saying it couldn't be done. Which is BS, because it CAN be done... the only problem is that they're probably the only ones capable of doing it, but they won't.
ghostrider,
This is really sad and atrocious in terms of attitude from MUL.
The guys at your MASS need to be given a pat on their back for the hard work they put in. The tacho install in the Swift (D) is not as easy like say on an Alto like amit poited out a few posts back.
Is there anything that you can do to resolve this?
Cheers,
gpa
Old 20th July 2009, 12:03   #287
drvhplyevraftr's Avatar
Thanked: 16 Times
Guys,
Can you please help me with the question in the following post?
http://www.team-bhp.com/forum/1388260-post256.html (Tachometers)
Thank you.
drvhplyevraftr is online now   Reply With Quote
Old 20th July 2009, 12:18   #288
trrk's Avatar
Thanked: 13 Times
I hope you get another chance to get a tachometer installed. The Ritz Diesel one has an external one.
I wish someone with knowledge of the electrical / electronic system related to this helps you. Unfortunately I don't even know the basics.
trrk is offline   Reply With Quote
Old 20th July 2009, 12:21   #289
ghostrider's Avatar
Thanked: 307 Times
Originally Posted by drvhplyevraftr View Post
Guys,
I am having a 2005 Getz GVS petrol that does not have an tacho on it. Is it possible to fit a tacho without any complications?. Anyone has done it?. How much will a tacho with shift light cost?. I dont want anything that is big and too fancy. Please let me know. Thank you.
Should be pretty straightforward. What you need is a tacho for a petrol 4-cyl car. The only question is does the Getz have a single ignition coil or a dual-coil system? That will affect the tacho installation and reading.
An Autogauge coil with a shift light will cost between 1500 and 2500, depending on the size you buy. The person you buy it from should be able to install it for you without any hassles.
ghostrider is offline   Reply With Quote
Old 20th July 2009, 12:23   #290
ghostrider's Avatar
Thanked: 307 Times
Originally Posted by trrk View Post
Thanks, anyway.
MASS did offer to fit the instrument console from the VDi for 8 grand, which I politely declined. That pissed me off a little bit though... if they can hook up the in-dash tacho signal source from the VDi cluster to the ECU, I'm SURE they can do it for another tacho.... but anyway... it's a moot point now I guess. :(
Old 20th July 2009, 13:23   #291
amit_mechengg's Avatar
Thanked: 1,556 Times
do you have the cable with connector behind your dash which is common between LDI and VDI ? is mass just going to put the VDI console and hook that cable in the console slot?
if this is the case its easy for you. catch hold of a very good electrician and ask him to pin the signal wire into the connector of the console. you will have to try to get the correct signal wire. there might be few wires. leaving apart the red and black wire you can try other. i think there will be yellow/orange wire.
Old 20th July 2009, 13:28   #292
ghostrider's Avatar
Thanked: 307 Times
I'm not sure, to be honest. Are you sure this wire exists? Because if so, then they can just hook my Autogauge tacho into this wire...
To the best of my knowledge this doesn't exist... can you confirm? I'd be VERY grateful.
Old 20th July 2009, 13:34   #293
i am not sure this wire exists. this is what i am asking you. if MASS can change the console and wire that tacho i can say that there is a signal source. this is why they are saying they can do it. generally what happens is in mass manufacturing the wire harness kit is same for different versions of same model.
that means in ldi the wire harness with N number of connector and sockets might be almost same as VDi. you will have to compare both with MASS or in swift parts manual.
if it is same then there should be one connector left hanging behind your dash and one will be connected to the speedo. from the second connector you will have to take a signal cable out.
a bit of investigation is required though, i wish you all the best and pray that you get the tacho fitted.
Old 20th July 2009, 13:47   #294
trrk's Avatar
Thanked: 13 Times
The electrical circuit diagram if obtained will help in identifying the wire. The workshop service manual would have it.
Old 20th July 2009, 14:45   #295
srikant's Avatar
Thanked: 9 Times
Can i fit an after market tacho with shift light to Swift petrol LXI? What might be the price incurred ? and what measures have to be taken before buying one? and whom can i get the fitting done from?
srikant is offline   Reply With Quote
Old 20th July 2009, 23:55   #296
ghostrider's Avatar
Thanked: 307 Times
I'll see what I can do. I plan on going to Vitesse and asking them how they would plan on fitting the VDi cluster to an LDi. If I'd given them the go ahead to do this, they would have to get the rpm signal source from somewhere, right??? WHERE??
Old 23rd July 2009, 20:48   #297
freakrz's Avatar
Thanked: 50 Times
here is the install of my tachometer in swift Lxi,its done by M.A.S in Vizag ,they are very helpful in doing it. Plugged it to the ECM. Works Pretty Good.
freakrz is offline   Reply With Quote
Old 23rd July 2009, 21:30   #298
Thanked: 253 Times
Just as long as you can live with a grossly over-rated meter!
Eleven Kilos, (for a six and a half K (?) engine)!!
Old 24th July 2009, 01:19   #299
freakrz's Avatar
Thanked: 50 Times
as long as it serves the basic purpose of a tacho,it shouldn't matter...!
Old 24th July 2009, 13:26   #300
gpa
gpa's Avatar
Thanked: 282 Times
That's a nice tacho freakrz Is that an auto guage meter?
Also, its suprising that you this done at your friendly neighbourhood MASS.
Cheers,
gpa
Case for Tachometers on all Bikes and Scooters anjan_c2007 Motorbikes 27 10th April 2012 11:44
Post pictures of Tachometers here! streetracer_919 Modifications & Accessories 0 8th June 2009 12:02
Tachometers /Odometers/Fuel-tempGauges Rahulk76 Modifications & Accessories 1 10th March 2006 16:53
