Old 29th December 2009, 20:19   #391
yogisays0909's Avatar
Thanked: 23 Times
Originally Posted by wildchild4lyfe View Post
anyone knows where i can get a shift light in mumbai?..i dont want the whole thing.
thanks!
I will get one for you , like what i have!
Hang on till Feb or March!
yogisays0909 is offline   Reply With Quote
Old 29th December 2009, 21:14   #392
Post
Hi
Any Idea if i can fix a Tachometer on my Indica Vista TDi Terra? I was told by the service fella that it was all an ICU system and therefore, not possible to fit and blah blah.. So. Let me know if this can really be done or not
boohooper is offline   Reply With Quote
Old 30th December 2009, 12:39   #393
wildchild4lyfe's Avatar
thanks bud!..just try to get a matte and not a chrome..
wildchild4lyfe is offline   Reply With Quote
Old 5th January 2010, 11:20   #394
nikhil1300's Avatar
hey guy want to convert my analog speedometer to digital for my gypsy can ay one help me with this or who can do it for me in bangalore
nikhil1300 is offline   Reply With Quote
Old 12th January 2010, 03:22   #395
Zenster's Avatar
Thanked: 70 Times
Originally Posted by kingofmyworld View Post
here is the pic of my previous tacho.
MODS : Changed the image format so that it will be visible on the post itself. Do the needful. Thanks
Hey Ram, Thanks a lot for this cool piece.
Other still guessing why i thank him. Thats because he sold the tachometer to me .
The Tachometer works great and looks even better (or may be its the other way around). However, the place i got it installed from got only the RPM Meter and the Voltage Indicator working. The Water Temp and the Oil Pressure is was not connected as it was a much more complex process.
I spoke to my MASS guys and they are ready to it if I can get a Wiring/Connection Diagram for this Tachometer. I searched the web quite a bit but was unable to find anything relevant. Can someone with expierance on these gauges please help me with this . I'll post the pics once i have it all working.
Zenster is offline   Reply With Quote
Old 15th January 2010, 19:34   #396
Default Tacho for the Vista TDi
I would like to know if it is possible to fit a Tacho for the Vista Tdi Terra. Has anyone fitted one on their Vista. Please do let me know. Also if i would be affecting the warranty of the vehicle if i did get one fitted.
Old 16th January 2010, 09:07   #397
yes it is very much posible.you do get tachos for diesels..and yes anywhere you fiddle around with the electricals or for that matter any aftermarket part that you put in would void the varranty..!
Old 16th January 2010, 09:12   #398
are you sure about the digital part??...you mean you want to convert your speedo like the one in the civic?..if yes then it would be insanely expensive as it wouldnt just be the speedo console and meters that you would have to change.
Old 16th January 2010, 11:11   #399
nikhil1300's Avatar
any other opstion to make the dashboard more goodlooking
Old 16th January 2010, 11:21   #400
well a custom dash is an option... a friend is doing it in his swift..ill post pics when its done..
i personally feel the gypsy should be kept like a gypsy..!
Old 16th January 2010, 12:40   #401
deepclutch's Avatar
Thanked: 34 Times
Post
Originally Posted by boohooper View Post
Hi
I have a Terra Quadrajet.Even I would like to fix one.But What I heard from TASS is ,without cutting wires and other complexity ,Tachometer cannot be fixed. Only other option is ,Whether it is possible to exchange the Terra's dashboard console to that of Aqua's(which contains Tachometer as well).But ,it is almost 99.99% not possible.
deepclutch is offline   Reply With Quote
Old 20th January 2010, 05:57   #402
Zenster's Avatar
Thanked: 70 Times
Finally have it all fixed and working, almost (Water Temp still pending)
Installed it in the Right Corner on the dash to avoid running to the Mechs after my daughter knocks off some connector
Idling (Cold Start)
Revved in Neutral
I so wish the Dull Green Backlight of the center console could be changed :(
Old 20th January 2010, 09:38   #403
UniqueMods's Avatar
Thanked: 40 Times
nice tacho. nice to see it all worked for you. install is good and clean.
where is the oil flow sensor attached ? to which part.
UM
UniqueMods is offline   Reply With Quote
Old 20th January 2010, 15:29   #404
gpa
gpa's Avatar
Thanked: 69 Times
Zenster,
From where did you pick up this piece? It looks really nice! Great to know that you've configued almost all the gauges to work!
Do let me know from where you picked it up in BLR, so i can get one too. Have been looking for a good tach for my Alto for months now.
Thanks in advance.
gpa
Old 20th January 2010, 15:44   #405
kingofmyworld's Avatar
Thanked: 81 Times
Originally Posted by gpa View Post
Zenster,
Thanks in advance.
gpa
He picked it from me. LOL,
@zenster, I miss this beauty a lot man! Unfortunately it doesn't work with a 3cylinder car :(
Connecting the oil gauge was a big process but it took a couple of minutes to connect the water temp gauge.
Anyways, Looks very good in your car man. Have fun.
kingofmyworld is offline   Reply With Quote
Case for Tachometers on all Bikes and Scooters anjan_c2007 Motorbikes 27 10th April 2012 11:44
Post pictures of Tachometers here! streetracer_919 Modifications & Accessories 0 8th June 2009 12:02
Tachometers /Odometers/Fuel-tempGauges Rahulk76 Modifications & Accessories 1 10th March 2006 15:53
