Old 11th June 2010, 21:25   #421
hello everybody. im looking at buying this autogauge tacho meter- Product Detail
please tell me what you feel about it.
i am fixing this for my accent viva petrol(1.6l dohc)
few questions:
1) will this rpm fit on my car dashboard? it is 5"
2) for a petrol engine the rpm meter should measure upto 11k right?
3) will all the gauges be able to work?including the shift light?
4) will it have a backlight? i have searched everywhere but nowhere does it mention about the back light
this is my first accessory i am buying. looking forward to your responses. also if any of you have seen this gauge in any store in bangalore. then please do let me know. thanks in advance.
anuj1237 is offline   Reply With Quote
Old 27th August 2010, 10:57   #422
yogisays0909's Avatar
Thanked: 189 Times
Default Wana sell this
How much can i expect for these two things together.
3 1/4' tacho and external shift light.
yogisays0909 is offline   Reply With Quote
Old 27th August 2010, 12:43   #423
UniqueMods's Avatar
Thanked: 50 Times
"How much can i expect ?" - your are selling.
New cost 3000 + 1500 at milan subway, mumbai for autogauge, and cheaper for Chinese brands.
set your price accordingly if you're selling them.
UM
UniqueMods is offline   Reply With Quote
Old 27th August 2010, 19:55   #424
Thanked: 189 Times
UM
Yes i wana sell them, got triple pod gauges.
Its Auto Gauge and in excellent condition. Will shell them off for 3.3K
Old 9th November 2010, 13:16   #425
josejoseph's Avatar
Thanked: 319 Times
Default Tachometer for M800
Hello All,
I bought Sunpro CP 2012 tacho for my 2001 model 5 speed M800.
Can some one advice me on connecting it? I'm also not sure about setting the cylinder configuration to 3 and shift light?
Attached are the pictures.
Thanks,
Jose.
josejoseph is offline   Reply With Quote
Old 9th November 2010, 14:34   #426
UniqueMods's Avatar
Thanked: 50 Times
i have the same sunpro model but set on 2 cylinder setting for a (dual ignition coil) santro erlx. work perfectly.
wiring-
red is to +ve 12v power source
black is -ve ground
white is back light - connect it to the instrumental back light source. so it will come on only when you turn on the dimmer or headlight.
green is the rpm signal wire. connect it to the +ve of you 800 ignition coil in the engine bay.
the manual that came with the tacho has the settings of the engine type selector. in case you don't have the manual let me know, will put up a scanned copy.
how much did you pay for this?
and get the installation from a car electrician. this is a advanced DIY.
UM
Old 9th November 2010, 16:22   #427
josejoseph's Avatar
Thanked: 319 Times
UniqueMods, I bought the tacho from eBay and did not get the user manual. Hence, please send me the scanned copy.
When I googled, I found that the green wire has to be connected to the (-)ive of the ignition coil. But you have mentioned it to connect to the (+)ive of the coil. Can you please confirm?
I paid around $60 including shipping. This is an unused new item. Am not sure if the price is high. One reason I went for this is because I found it difficult to find tachos with 3-cylinder settings. Most of the tachos which I zeroed in had 4, 6, 8-cylinder config.
Thanks,
Jose.
Old 9th November 2010, 23:06   #428
josejoseph's Avatar
Thanked: 319 Times
Okay, here is the update. I temporarily connected the tacho on a test mode. I connected the red wire to the battery +ive, black to the -ive and green wire to the -ive of the ignition coil. After cranking the car, the needle moved to 1100. Is this correct rpm for a 5-speed M800?
Now, I'll have to figure out a place to fix the tacho permanently in the dash. The tacho is of 3.3/8", hence it will be difficult to find a good position.
There is one more wire white in color which lights the tacho. I have to connect this to the dimmer or headlight switch. How will I trace this wire in the car? Pointers please.
Jose.
Old 10th November 2010, 13:46   #429
UniqueMods's Avatar
Thanked: 50 Times
I will scan and upload the manual, but will need to hunt for that tacho box, pretty sure i can find it.
The +ve or -ve connection on the coil, should also be in the manual.
I paid 35$ a year back from Ebay to a friend coming to India.
The white wire is hooked up to the wiring harness inside the cabin behind the instrument console. cant help in where exactly its connected.
UM
Old 10th November 2010, 13:52   #430
BANDHAV's Avatar
Thanked: 278 Times
Can the stock tachometer of Ritz VXI/ZXI model be fitted to Base Lxi model?
BANDHAV is offline   Reply With Quote
Old 10th November 2010, 16:04   #431
UniqueMods's Avatar
Thanked: 50 Times
Depends if M.a.s.s are ready to do this installation.
i believe Ritz takes the rpm signal for the ecu, and if this cable is not provided from the ecu, you should be able to connect it to the coil.
Your best option is the accessory department of M.a.s.s.
UM
Old 11th November 2010, 06:13   #432
josejoseph's Avatar
Thanked: 319 Times
UM
UniqueMods, please scan the manual when you find it.
Re. the +ive or -ive connectivity, in my case the green wire is connected to the -ive of the ignition coil.
I'm not sure if the price is high, but like I said I went for this tacho as I did not find any thing else to my liking for 3-cylinder engines.
I spoke to my mechanic in MASS and he's ready to fix it. Will get it done next week.
Can any one tell me which is the ideal RPM for a 5-speed M800? What is the correct RPM to shift gears to get better mileage figures?
Thanks,
Jose.
josejoseph is offline   (1) Thanks Reply With Quote
Old 14th November 2010, 17:44   #433
UniqueMods's Avatar
Thanked: 50 Times
sunpro cp2012 manual.
UM
UniqueMods is offline   (1) Thanks Reply With Quote
Old 15th November 2010, 09:09   #434
josejoseph's Avatar
Thanked: 319 Times
UniqueMods, thanks so much buddy!
I'm getting the tacho fixed this week. Will post pics then.
Jose.
Old 23rd November 2010, 09:04   #435
josejoseph's Avatar
Thanked: 319 Times
Hi All, finally the tacho is fixed. Attached are the images. M.A.S.S. charged me Rs. 150/- for fixing this.
Jose.
Case for Tachometers on all Bikes and Scooters anjan_c2007 Motorbikes 27 10th April 2012 11:44
Post pictures of Tachometers here! streetracer_919 Modifications & Accessories 0 8th June 2009 12:02
Tachometers /Odometers/Fuel-tempGauges Rahulk76 Modifications & Accessories 1 10th March 2006 16:53
