Old 23rd May 2011, 16:44   #451
jagrocks7's Avatar
Thanked: 7 Times
Default Re: Tachometers
Originally Posted by shridhar.s.i View Post
Hey i have sent a PM to you, meanwhile can you post some pics of Tacho..eager to see them
Here you go. Pictures of the Auto Gauge 5 inch Tacho (Slim & Smoked Model), It also has 3 background color options.
jagrocks7 is offline   Reply With Quote
Old 23rd May 2011, 17:01   #452
black12rr's Avatar
Thanked: 274 Times
Originally Posted by jagrocks7 View Post
I just got a 5inch Autogauge Tacho installed in my Swift, PM me for more details..
Your setup looks great .
could you post details here itself so that others also take benefit of it .
I am also looking for a 5inch tacho.
Could you post price,location where this you picked up from ?
thanks.
black12rr is offline   Reply With Quote
Old 23rd May 2011, 17:16   #453
jagrocks7's Avatar
Thanked: 7 Times
thanks.
I paid somewhere around Rs.8000/- for the 5inch Tacho, Purchased and Installed by EVO, Cambridge Layout.
Old 3rd June 2011, 15:53   #454
Nash24's Avatar
Thanked: 13 Times
HI All,
So is there no Tachometer which can be fitted on the Swift LDI?
Nash24 is offline   Reply With Quote
Old 28th June 2011, 11:50   #455
sushrutha's Avatar
Thanked: 325 Times
An urgent help.
I recently brought an Autogauge 2 in 1 digital Voltmeter+RPM meter.
Need to install this in my CIVIC. When connected, Voltmeter works fine.
Though I already have a stock RPM meter in a CIVIC, but I want this Autoguage unit to be installed seperately which looks cool too (Digital RPM ;-) )
Has anybody installed an addon tachometer in CIVIC ?
Now from the gauge where do I have to clip the RPM wire into ? Where in distributor ? Or does the RPM singal come from ECU ? How easy is it to install an RPM meter.
Can be done in this way, BUTTTT.........
I don't want to open my dashboard and tap the wire which is for RPM meter in the dashboard.
This is how the Gauge looks
Old 28th June 2011, 13:34   #456
archat68's Avatar
Thanked: 290 Times
^^ Find out the RPM signal output from ECU and connect with that. Or open up the console and hook a wire in parallel with the existing Tachometer.
archat68 is offline   Reply With Quote
Old 28th June 2011, 15:36   #457
sushrutha's Avatar
Thanked: 325 Times
As mentioned earlier,
I don't want to open my dashboard .
Does anybody has the R18 Civic ECU wiring diagram. Don't know which pin# to tap for the Tacho.
Old 28th June 2011, 16:11   #458
archat68's Avatar
Thanked: 290 Times
^^ See this post:
WideBand into FlashPro.. - 8th Generation Honda Civic Forum
Old 28th June 2011, 16:41   #459
sushrutha's Avatar
Thanked: 325 Times
That's for the CIVIC Si.
Is it same for the R18 Civic which we have here in India ?
Old 19th July 2011, 17:02   #460
Nash24's Avatar
Thanked: 13 Times
Hey all,
Is it possible to fit the Ritz VDI tacho meter on the Ritz LDI.
Require this info urgently, has any one tried this.
Old 20th July 2011, 10:39   #461
Nash24's Avatar
Thanked: 13 Times
Hey Folks,
Info required, has no one tried putting the RITZ VDI tacho on the RITZ LDI.
Is this possible?
Old 20th July 2011, 22:00   #462
Thanked: 61 Times
Originally Posted by Nash24 View Post
Hey Folks,
Is this possible?
When I bought my car I was also thinking of going for a LDi and fit Tacho from VDi, this should not be a problem. But I do not know the cost of the Tacho and labour charges involves. I would suggest get a ScanGauge II instead for Ritz LDi. You'll get much more than a tacho.. Think about this!
gaddiwale is offline   Reply With Quote
Old 20th July 2011, 22:11   #463
Nash24's Avatar
Thanked: 13 Times
Thanks mate, this is a life saver for me, how much does this cost? 160 AUD right? any place in india where i can i get it cheaper?
How sure are you i can fit the VDI tacho on the LDI? I really dont mind the cost of this tacho, even if it is 5k I'm ready for it
Can you please explain how have you fitted the scan guage 2, where is the wire connected to.
Old 20th July 2011, 22:35   #464
Thanked: 61 Times
Hey Folks,
Is this possible?
I got it thru' ebay, shipper was Wooders from Australia. Forgot the price you can check my ScanGaugeII thread.
Old 20th July 2011, 22:55   #465
archat68's Avatar
Thanked: 290 Times
You can buy it from Amazon too. Although you will need a Aramex Shop and Ship type account. Buy the Scangauge E for 95$ from Amazon.
Amazon.com: ScanGaugeE Compact Multifunction Trip Computer with Customizable Real-Time Fuel Economy Digital Gauges: Automotive
You will need to pay 10$ for shipping to India through Aramex Shop and Ship. If you are lucky Customs duty will be Nil else it will be 15%.
Shop and Ship :: Home
You will connect it to the OBDII socket.
Oh wait - there is a better and cheaper alternative.
UltraGauge Automotive Information Center and OBDII Scan Tool
Buy this - much cheaper but almost similar in functionality to SGII.
You can buy used SGII from ebay USA too:
Case for Tachometers on all Bikes and Scooters anjan_c2007 Motorbikes 27 10th April 2012 11:44
Post pictures of Tachometers here! streetracer_919 Modifications & Accessories 0 8th June 2009 12:02
Tachometers /Odometers/Fuel-tempGauges Rahulk76 Modifications & Accessories 1 10th March 2006 16:53
