| LinkBack | Thread Tools | Search this Thread |
| | #481 |
| BHPian | Does a Chevy Spark have a single ignition coil or Dual ignition coil? check that out first. tacho's avaliable at milan subway and opera house are mainly for single ignition coil. UM |
| | #482 | |
| BHPian Join Date: Mar 2011 Location: Bombay
Thanked: 100 Times
| Quote:
Thanks | |
| | #483 |
| BHPian | Note from the Team-BHP Support Team : Using Team-BHP to promote vested and commercial interests is STRICTLY prohibited. Do refrain from marketing your goods / services on the board. Last edited by Technocrat : 10th March 2012 at 01:49. Reason: Please read the MOD note in your post, thanks |
| | #484 | |
| Newbie Join Date: Jan 2008 Location: Bangalore/Kottayam
Thanked: 9 Times
| Quote:
Rds Arun | |
| | #485 | |
| Senior - BHPian | Quote:
You can get the same at THROTTLE - Jayanagar 7th block. I don't rememeber the exact price, somewhere between 2K-2.5K INR | |
| | #486 |
| BHPian Join Date: Sep 2010 Location: Bangalore
Thanked: 97 Times
| Hi Is there a flattish low profile oval shaped tachometer in the market preferably with flat base and rounded top and sides? Like where the needle moves more in a horizontal arc than vertical? I dont want to lose the visibility of my bonnet when mounted on the dash of my Gypsy and the off center passenger side area of the dash is taken up by a rotating dash fan. Alternatively I could mount a round tachometer in the vertical face of the dash (and angled towards me) if diameter is about 5.5cm as there is a round space meant for analog clock that can be cut-out. Thanks --Rahul |
| | #487 |
| BHPian | Did you get your tacho done. You get those smaller tachos in Blore that you can fit inside the dash inplace of the clock. Ask GSFerrari from where he got that done. I think from RAC in Blore. I brought the gypsy from him and it has that. |
| | #488 | |
| BHPian | Quote:
![]() Above is the Ignition coil in Chevy Spark. Judging by the looks of it, which type could it be? Single or Dual? I suppose this has 2 coils, one for 2 cylinders. Also if I have a Tacho where should I connect the green wire on the ignition coil? Let me know if you want to see more detailed pictures of the coil. | |
| | #489 |
| BHPian Join Date: Jun 2012 Location: hyderabad
Thanked: 16 Times
| A friend recently bought a Tachometer from Australia and needs to fit it to a Ritz Ldi. Can somebody please explain where he can get this done in Hyderabad ? In case you are aware of a DIY, please share the steps that need to be followed. He tried with Xenex performance store(not sure of the exact name but it is the new store that has opened in Kavuri Hills) but they did not have a clue. |
| | #490 | |
| Distinguished - BHPian ![]() Join Date: Jul 2006 Location: Bangalore
Thanked: 715 Times
| Quote:
Didn't you get a connection drawing with the tachometer? The drawing will help in figuring out what connects where. Edit: I also have a small suspicion that connecting the tacho directly to the coil pack may lead to the tacho showing only half the actual RPM. Something similar happened with a lot of folks who connected aftermarket tachos' to the Swift G series petrol cars. In the Swift the tacho had to get feedback from the ECU for it work correctly. Last edited by vikram_d : 13th December 2012 at 11:37. | |
| | (1)
| | #491 |
| BHPian Join Date: Jan 2006 Location: delhi
| Is it possible to install Diesel Tachometer in Petrol car. I was trying to install Ritz tacho in Wagon R but ordered diesel tacho by mistake. It would be very useful if anyone can tell me about compatibility issues, else I will procure a new one. Diesel tacho part number 34200M83K10 Petrol tacho part number 34200M83K00 Regards |
| | #492 | |
| BHPian | Quote:
Which make are the tachs? Could you please post the source for its data sheet or some sort of technical info? Diesel tachs are usually hooked to the alternator, where as the petrol tachs show the speed based on spark counts. So if you can tap the alternator speed signal, technically you should be able to use a diesel tach on petrol car. Still please look for the data sheet and share it here. -Ilango | |
| | (1)
| | #493 |
| Hi, Thanks for your resonse. This is Ritz Diesel tachometer and manufacturer is Pricol. I tried to search for the spec sheet and circuit diagram but was not able to find this on Pricol website. Regards, |
| | #494 | |
| Quote:
Regards. | |
Similar Threads | ||||
| Case for Tachometers on all Bikes and Scooters | anjan_c2007 | Motorbikes | 27 | 10th April 2012 11:44 |
| Post pictures of Tachometers here! | streetracer_919 | Modifications & Accessories | 0 | 8th June 2009 12:02 |
| Tachometers /Odometers/Fuel-tempGauges | Rahulk76 | Modifications & Accessories | 1 | 10th March 2006 15:53 |
