Old 3rd August 2013, 15:41   #496
canonball's Avatar
Thanked: 189 Times
Default Re: Tachometers
Anyone have any idea where I could score a tach which can be fixed in a nano? Has to be one which works on 2 cylinder engines unlike what's commonly available for 4 cylinder engines
canonball is offline   Reply With Quote
Old 20th December 2013, 15:30   #497
arnabchak's Avatar
Thanked: 1,101 Times
I want to do either of the below for my Wagon R CNG:
1) Instal the Ritz Tachometer. Only reason-The backlight is amber and will correspond with the speedo backlight. The A Star tacho is red.
2) Auto gauge 2" tacho-May be basic. Only need the RPMs. Shift light is not compulsory. What should be the approx. cost and reliable place of purchase?
3) Good reliable installers in Mumbai/ Thane(I stay in Thane so Eastern Suburb Installation suggestions all the more welcome. Will it hamper the warranty in any way?
4) I wish to instal the tacho at the location of the Ritz Tacho. Can the wiring be concealed? Additionally, do we need to drill holes in the dash. That is something I would seriously like to avoid.
5) Mandatory- The back light is amber. Have kept even the HU backlight matching the speedo backlight.
arnabchak is offline   Reply With Quote
Old 23rd December 2013, 00:57   #498
Thanked: 14,609 Times
For points 1, 4 & 5, Here is the answers as below.
Please check the link (Post No. 70). Easiest and Best solution plus it is a DIY.
http://www.team-bhp.com/forum/long-t...g-miles-5.html
All the Best!
Anurag.
a4anurag is offline   (2) Thanks Reply With Quote
Old 23rd December 2013, 11:03   #499
arnabchak's Avatar
@a4anurag
Thanks for the post.
However, what should be the entire cost of the installation if I get the Ritz Tacho.
I may not be able to do a DIY but if it is professionally done, any good installers in Mumbai who could help.
Also, if I happen to go with the Auto Gauge 2" , what should the price be?
Old 23rd December 2013, 19:58   #500
paragsachania's Avatar
Thanked: 12,362 Times
Thanks Anurag for posting the link!
The Tacho (Ritz Petrol) should cost you only INR 1100/- max. I paid 1037 If I remember it right.
If you can find a reliable & friendly neighborhood garage and explain him how to do it, the job wont last more than an hour and labor should not go beyond 300-500.
Not sure about this, Never thought about one. With the Ritz Tacho that uses TTL (Transistor Logic), the Tacho signal are drawn electronically from the ECU. An aftermarket Tacho means you will have to draw signals from the Ignition coil (and configure that depending on number of cylinders in the Engine).
Personally, if you ask me, I would simply go for the Ritz Tacho. Looks neat, almost fits like OE on the Dash and works very well. The aftermarket Tacho will at least cost you 2000 INR or above depending on size and additional features like a shift light.
EDIT: Whether you need to drill any holes-
Although the Tachometer itself will not need any holes to hold it as it fits perfectly well on a flat surface using a good quality double sided 3M tape, you will need to make a very small hole (say 3-5mm) to pull the 4 wires required for the tacho from the Dash.
Otherwise you can still pull that in a smart manner from behind/center of the dash without drilling a hole but the wires will be exposed.
Trust me, the small hole that I am referring to for wires will anyways get neatly covered when you mount the Tacho above it pasting the tape.
paragsachania is offline   (1) Thanks Reply With Quote
Old 23rd December 2013, 20:10   #501
S2!!!'s Avatar
Thanked: 9,280 Times
@arnabchak
The last time I checked the tachometer in the Ritz can only be fitted on the dashboard, closer to the windscreen near the right A-pillar. If you install at any other place, you will have wires showing which will look a lil tacky IMO.
Autogauge basic tachometers will cost you in the range of Rs.1100-1300 + installation charges, which any electrician at Opera House can do for Rs.150-200. Whatever the case, do update the thread.
S2!!! is offline   Reply With Quote
Old 24th December 2013, 16:37   #502
arnabchak's Avatar
Dear S2
Thanks for the same!!
Will update once am done.
Any reference in Opera House?
Old 7th January 2014, 03:29   #503
Dear S2
Any updates? Still searching or fixed the Tacho?
Anurag.
Old 7th January 2014, 11:23   #504
arnabchak's Avatar
HI Anurag
Havent gone ahead with the fix yet.
Will probably do it in the next couple of weeks.
The tacho will more or less be the Ritz Tacho.
Old 10th April 2014, 21:37   #505
Lowrider's Avatar
Hi Amit, Can you throwsome light on how to install an autogauage tacho to a diesel swift please if you have carried out the same?
Lowrider is offline   Reply With Quote
Old 11th April 2014, 13:00   #506
arnabchak's Avatar
HI Anurag
HAving checked with a couple of FNGs and also with the MS ASC, to install the tacho on the CNG changing the ECM may be needed.
Else, they can draw the power from the PS and this may cause some problems to the PS set up in th long run.
How valid is this?
The installtion may not be very expensive but then a probable PS failure is something that cant be afforded.
Old 11th April 2014, 13:10   #507
How valid is this?
Tacho has inputs:
1. Tacho signal
2. Backlight
3. Tachometer Power Supply
4. Ground
In my WagonR, for 2 and 3 I have made use of Power wire from 12v accessory socket and Music system respectively. In simple words, you will have lot of options to draw 12v supply inside the car.
For Ground, you have multiple options anyways.
It,s the Tacho Signal (if you are using Ritz Tacho) that you need to worry here as it requires input from the ECM (and not the ignition coil like the usual Tachos).
NOTE: There is no need to fiddle with the PS wiring to power up the tacho. Its completely invalid.
Old 11th April 2014, 13:16   #508
absynthguzzler's Avatar
Thanked: 224 Times
How valid is this?
1. 12 volts from ignition wire
2. Backlight from cluster lights wire
3. RPM from standard rpm pin outlet on harness
4. Ground wire to any bare metal point.
I dont see need for tapping into PS and what not. CNG setup doesnt play a role too.
absynthguzzler is offline   (1) Thanks Reply With Quote
Old 8th November 2015, 23:41   #509
Geo_Ipe's Avatar
Thanked: 376 Times
Can I fit a Ritz tachometer in my Santro Xing?
I live in Vellore, where we don't have accessory shops stocking tachometers, nor do we have private garages with experienced mechanics. If the answer to my query is 'yes', I can procure the meter from Maruti and get it fitted at Hyundai!
It has been a long term wish to retro fit a tacho on my Xing!
Geo_Ipe is offline   Reply With Quote
Old 24th November 2015, 17:28   #510
sushrutha's Avatar
Thanked: 325 Times
Very recently I fitted a Defi Tachometer in my MPFI Zen (jelly bean).
Connected the RPM signal wire to the -ve terminal of Ignition coil and rest all connections as per the manual.
Had Zen been with Dual ignition coil, RPM signal needs to be tapped from ECU wires, but that's not the case with Zen MPFI as it has Single fire Ignition coil.
This tachometer has options to set 2 levels of Peak RPM (1st level green light & 2nd level red shift lights with beeper)
Cylinder settings from 1 -2 -3 -4 -5 -6 -7- 8
Dim light settings etc
1st Level Peak RPM light
2nd Level Peak RPM lights (Beeps continously when red light glows)
Case for Tachometers on all Bikes and Scooters anjan_c2007 Motorbikes 27 10th April 2012 11:44
Post pictures of Tachometers here! streetracer_919 Modifications & Accessories 0 8th June 2009 12:02
Tachometers /Odometers/Fuel-tempGauges Rahulk76 Modifications & Accessories 1 10th March 2006 16:53
