Old 13th June 2008, 17:56   #91
furioussphinx's Avatar
Guys, I have a 2001 zen Di. Is it a 3 cylinder or 4 cylinder?
furioussphinx is offline   Reply With Quote
Old 13th June 2008, 19:43   #92
manikjeet's Avatar
Thanked: 110 Times
you can check your RC its mention their also and its a 4 cylinder
manikjeet is offline   Reply With Quote
Old 13th June 2008, 21:11   #93
Thanked: 152 Times
Zen is always been a 4 cylinder. the 800 was 3 cyl. and the Alto is 3 cyl.
Cyrus43 is offline   Reply With Quote
Old 13th June 2008, 21:18   #94
Thanked: 253 Times
He's asking about Zen DI........ ..................
Old 13th June 2008, 22:36   #95
The RC card is unfortunately at home in India and am holidaying in Qatar now. Its a diesel folks, a 1.5L engine. So does this also have just 4 cylinders?
Edit : Just googled and found out that the Diesel 1527cc engine is a 4 cyl.
So now got to go shopping for the tachometer
Old 14th June 2008, 08:01   #96
Thanked: 253 Times
Which type are you buying? Where will it sense from?
Old 14th June 2008, 15:54   #97
I want to buy those big ones with the shift light. Mostly Autogauge. I have no clue where it will sense from.
Old 15th June 2008, 20:15   #98
gd1418's Avatar
Thanked: 656 Times
From the alternator of course... The stock RPM meters of big diesels like Safari, Scorpio etc., sense it from the alternator unit..
Old 15th June 2008, 21:31   #99
Thanked: 253 Times
Exactly, as gd has said!
Please don't pick up one meant for distributor type engines.
Old 17th June 2008, 12:12   #100
Foster's Avatar
the big shift lights etc is gonna cost you some where around 12k +fitting charge(cant leave that out)
Foster is offline   Reply With Quote
Old 18th June 2008, 03:23   #101
Ok this is frustrating! The whole of Doha doesnt stock even one Autometer/Autogage Tachometer! Wah! All fakes! That too at around 3000INR. The only Autometer stuff I saw were 2 gauges (2.5") - oil temp and voltmeter.
Guys, how much does a pillar pod with a votlmeter, oil temp cost? Does the water temp gauge help? Has it got anything to do with coolant, etc?
Old 21st June 2008, 17:33   #102
sumeethaldankar's Avatar
Thanked: 1,154 Times
Hi guys,
I had a lousy experince while getting a tachometer fitted for my m-800.I went to a shop at Milan subway to look for a tacho,found one i liked at
Jai Car acessories shop.It cost 1600 bucks + 300 for the tacho holder.I think it was a auto meter one.After the fitting i checked the tacho it worked fine,paid the guy and drove off and decided to rip the car to see the needle climb up.What happened next took me by surpise as the needle did a 360 turn all way round and rested at > 10000 rpm
I simply took a U-turn and went back to guy and showed him the problem
After careful observation it seemed that the needle placement had broken and it was moving around freely.
Now comes the lousy part.The shop attendant agrees to replace the unit with a new one but the shop owner gets the impression that the guy who did the fitting broke the tacho and refuses to get the new tacho installed by the mechanic.He inisits that i go to a certain garage near Raheja college and get the tacho fitted.I argued that this should have been told to me earlier but he refuses to listen and hands me back my money and asks the mechanic to unintsall the broken tacho from the car.
I guess i had no choice and had to give in.
Well i was glad that i got my money back but this episode left two holes
on my driver side A pillar as that is where i had asked to install the tacho.
I guess both the shokeeper and me suffered some loss and the funny thing is nobody really knows who was at fault... the tacho or the mechanic.
sumeethaldankar is offline   Reply With Quote
Old 21st June 2008, 17:49   #103
noidaboy's Avatar
Thanked: 260 Times
Guys, i have a type r tacho in my car since a while now, i wanted to cross check with the 800 owners on the forum using a tacho,that what is the rev limit for it? according to mine tacho im able to touch(redline) 3500-3800 while driving? is that the limit for the 800 or is my tacho incorrect?
I also crossed checked thru the ones available at A.S.S according to their meter its the same
Just curious to know.
noidaboy is offline   Reply With Quote
Old 9th July 2008, 04:29   #104
hot_rod's Avatar
Ya dude my friend also has one and the max it does in 800 is around 4k
am desperately searching one for my zen will go to milan subway hope viper will get me a good one.
hot_rod is offline   Reply With Quote
Old 9th July 2008, 12:29   #105
viper's Avatar
Thanked: 9 Times
Originally Posted by noidaboy;
Guys, i have a type r tacho in my car since a while now, i wanted to cross check with the 800 owners on the forum using a tacho,that what is the rev limit for it? according to mine tacho im able to touch(redline) 3500-3800 while driving? [B
is that the limit for the 800[/b] or is my tacho incorrect?
I don't think that is correct. A stock Maruti 800 easily revs to about 6500 Rpm ( Carb & MPFI both) am sure of that. A modded one should do more
Viper
viper is offline   Reply With Quote
Case for Tachometers on all Bikes and Scooters anjan_c2007 Motorbikes 27 10th April 2012 11:44
Post pictures of Tachometers here! streetracer_919 Modifications & Accessories 0 8th June 2009 12:02
Tachometers /Odometers/Fuel-tempGauges Rahulk76 Modifications & Accessories 1 10th March 2006 16:53
