Old 22nd October 2009, 00:40   #1
black12rr's Avatar
Thanked: 105 Times
Default where to get Digital voltmeter ?
where to get Digital voltmeter ? ,some thing cheap here itself ?
Just feed + and - and it should give 4 LED voltage read out .
like this - LINK
black12rr is offline   Reply With Quote
Old 22nd October 2009, 02:31   #2
If nothing works , you can get a digital multimeter (~rs 600) and make the casing of your choice with it
DIY ?
singh.amrit is offline   Reply With Quote
Old 22nd October 2009, 09:53   #3
Ricky_63's Avatar
Thanked: 228 Times
You can get a digital Volt Meter from Pete's - though a little expense IMHO
Old 22nd October 2009, 11:01   #4
gigy's Avatar
Thanked: 34 Times
you will similar ones in the accessory shops around town, i had seen a digital one for 900 in a local shop.
Old 22nd October 2009, 11:03   #5
greenhorn's Avatar
Thanked: 265 Times
actually you can get analog voltmeters pretty cheap. just that they wont be good looking!
Old 22nd October 2009, 11:12   #6
sgiitk's Avatar
Thanked: 1,186 Times
I think the best place will be either a hardware shop or en electronics components shop. Of course any smugglers paradise will be real cheap. The most common is 3-1/2 digits ie reading to 1999
Old 22nd October 2009, 11:25   #7
greenhorn's Avatar
Thanked: 265 Times
you should get hold of an LED panel voltmeter at SP road.
Old 22nd October 2009, 11:31   #8
gigy's Avatar
Thanked: 34 Times
i have a analog lying around my place. its the mahindra jeep voltmeter fixed in a single pod. mahindra in maruti didn't go along for long but was helpful in troubleshooting electrical problem.
Many of the lcd/led panel meters i have seen in electronics market don't read the voltage of circuit which is used to power the meter also. it needs a separate power source/battery, i don't know why.
Why only this is not digital ?? shirishindurkar Technical Stuff 9 10th January 2008 19:48
SET2 DIGITAL Rudra Sen Shifting gears 15 6th July 2007 08:59
Digital Speedo naveendhyani Technical Stuff 31 25th December 2006 01:15
Digital Tach and more... jesal Technical Stuff 1 23rd December 2006 15:50
Digital Projectors!!! Shan2nu Gadgets, Computers & Software 2 12th November 2006 02:22
