Old 27th October 2009, 13:50   #16
Originally Posted by noidaboy View Post
You will place them from outside? I mean just stick them on the glass it self?
Tape might melt due to heat and dust another issue.
Not sure about method of placement. Any ideas?
idea1979 is offline   Reply With Quote
Old 27th October 2009, 16:46   #17
anantnehru's Avatar
Go for it. I had the same sort of install on my Sx4, no problems; though my strip had the laminated cover on it. But you're right, the curvature of the headlights makes for a tricky install; as even if one part of the strip is not stuck properly it can result in the entire strip coming loose.
anantnehru is offline   Reply With Quote
Old 28th October 2009, 17:51   #18
Ya. i will be doing it in day or two. May be i can also use silicon compund to hold it firmly.
Also i dont want to cut any wires while installing it.
Old 28th October 2009, 18:26   #19
sohail99's Avatar
Thanked: 200 Times
You can try Silicon based glue!
My dad had bought a glue gun and I find it really useful for mounting stuff!
Maybe it can help -Hot melt adhesive - Wikipedia, the free encyclopedia
sohail99 is offline   Reply With Quote
Old 30th October 2009, 16:03   #20
i do have glue gun. will try it out.
Old 30th October 2009, 17:53   #21
Nice stuff.
But try if you can place it 'inside' and not like a sticker.
That would look 'neat' IMO.
Also, here in mumbai we have ppl ripping off even maruti logos.
Some low life might just pull this led strip off, if stuck externally.
jigbarai is offline   Reply With Quote
Old 3rd November 2009, 18:26   #22
Originally Posted by jigbarai View Post
Nice stuff.
oh. thats a concern then. i need to conceal it properly.
Old 14th November 2009, 20:21   #23
Well here are final results. Managed to blow off one of fuse . However managed to install it without any cutting of wires.
Old 15th November 2009, 12:06   #24
Neil.Bhujbal's Avatar
Thanked: 59 Times
Woha ! Great job buddy. You have followed the headlamp curves neatly.What finally did u use to stick those strips ?
You sure these are called the LED lights ? Because LED's are generally small round bulb kind of things & cheap too.
Neil.Bhujbal is offline   Reply With Quote
Old 15th November 2009, 13:07   #25
badboyscad's Avatar
Thanked: 172 Times
These are SMD(surface mount device) LEDs.
badboyscad is offline   Reply With Quote
Old 15th November 2009, 15:16   #26
ghpk's Avatar
Thanked: 193 Times
Nice install "idea1979"
is it outside the Headlamp, or you've operated the Headlight assemble and managed to stick it inside it ?
Old 15th November 2009, 15:30   #27
kingofmyworld's Avatar
Thanked: 249 Times
Nice!, Looks cool on the spark
How many meters of this strip was needed to do this?
kingofmyworld is offline   Reply With Quote
Old 17th November 2009, 16:27   #28
Arrow
Thanks. These are LED mounted on surface. Since it is in trial mode, i have used transparent tape. Once comfortable, glue gun !
Outside headlamp.
Yeah. I can see many head turning
Exactly 1 M.
Old 17th November 2009, 17:06   #29
Can you post some day time pics, with LEDs NOT ON ? Need to see how it looks like.
Old 19th November 2009, 19:41   #30
Ya. it should not be a problem. However it is hardly noticeble unless you look very closely.
A-star or Spark? EDIT - Finalized Spark ritz830 Hatchbacks 67 18th July 2009 09:17
i10 or spark - EDIT: Bought Spark LT splitsecond Hatchbacks 135 28th May 2009 22:30
spark or palio for 3.3 lakhs? Edit - Finalized Spark ritz830 Hatchbacks 37 13th December 2008 16:12
Little Spark of Happiness has arrived - Chevrolet Spark LT JRD Test-Drives & Initial Ownership Reports 27 15th November 2008 13:44
