Old 10th November 2009, 14:50   #1
Thumbs down Bolero - Question Regarding Change in the Seating Arrangement
Hi Guys,
I drive a bolero 2004 GLX 4WD and here is a question.
I want to take out the rear jump seats and disect the center passerger seat such that I would be able to Lift (over the wheelwells) + recline into a 180 degrees.
Idea being - Convert the back upon demand into a safe sleeping quarters for 2.
Has anyone done this ? - Any opinions and advices are most appreciated. Thanks and regards.
..jp..
Last edited by Jaggu : 10th November 2009 at 15:23. Reason: Fixing formating, Thanks
jp_in_hyd is offline   Reply With Quote
Old 20th November 2009, 12:29   #2
MileCruncher's Avatar
Thanked: 356 Times
I think this should be absolutely doable. Just speak to Automotive fellows. But I think before trying the arrangement just make sure that you can get a bed made from a seat guy.
MileCruncher is offline   Reply With Quote
Old 20th November 2009, 13:02   #3
vinod_nookala's Avatar
Thanked: 411 Times
No i doubt if Automotive guys can help on this. They dont do modification jobs. Plus all this with them is expensive and is a slow job if and only if at all they would do this!
Please go to the seat making guys, they will do the necessary modifications. I have lost touch with hyderabad, get in touch with Jeep thrills guys/ bharat reddy guys they will guide you to the right person
vinod_nookala is offline   Reply With Quote
Old 20th November 2009, 13:03   #4
shankar.balan's Avatar
Thanked: 5,325 Times
A good upholstery chap should be able to help. There will be a bit of cutting and pasting especially the seat frame which is welded to the floor etc but in my opinion it can be done.
Seating Luxury & Massage Chairs venkatrx Shifting gears 38 15th July 2016 13:13
How to increase the Seating Comfort of a Motorcycle? mithun Motorbikes 18 10th April 2013 14:13
high seating position vs low arunk Technical Stuff 75 18th July 2010 20:00
Seating Position / Option while offroading on inclines (at roll angles >30 degrees) Tejas@perioimpl 4x4 Technical 2 19th January 2010 14:56
high seating position wanted filcord SUVs, MUVs & 4x4s 31 24th September 2006 11:41
