Old 28th November 2009, 15:08   #16
motophsyco's Avatar
Close ratio gearbox on a FI car for street use doesn't make much sense? Do put this car on a dyno to really see what you are making.
And as mag has suggested, do take good care of your car. I don't think your tuner has had many good feedbacks/reviews off lately so tread with extra caution. Hope you don't have to see the dark side too, EVER.
motophsyco is offline   Reply With Quote
Old 28th November 2009, 15:24   #17
shreyasma's Avatar
Congrats! Isnt that Satya's zen in the 8th pic?
shreyasma is offline   Reply With Quote
Old 28th November 2009, 16:17   #18
suhaas307's Avatar
Thanked: 6,948 Times
Congratulations man! All the best with the new blower. Give us your feedback and the costs involved That would be much appreciated.
P.S. Is your BOV on the louder side or have you gone in for a stealth one? And how's the clutch? Does it work well in stop-start traffic?
suhaas307 is offline   Reply With Quote
Old 28th November 2009, 16:54   #19
amith.2974's Avatar
Looking forward to the change in numbers.
amith.2974 is offline   Reply With Quote
Old 28th November 2009, 20:41   #20
YC.BALENO.CHD's Avatar
Thanked: 132 Times
Originally Posted by mercedised View Post
Adding a Turbocharger to a Baleno, to be honest i didnot like the concept because if anyone would have added a turbo in a SUV or MUV class car than it would really seemed to have a meaning, but Baleno. Anyways congrats for a neat JOB.
What ? Turbocharging an SUV or MUV makes more sense ?
YC.BALENO.CHD is online now   Reply With Quote
Old 28th November 2009, 20:46   #21
vdiatech's Avatar
irrespective of what people feel about turbo charging a Baleno, I feel you have done the right thing.
i just hope you feel the turbo kick in and your car pull you like a rocket (i miss that feeling!!) ! That feeling is worth all the money and effort you are putting into it. You can always surprise a same category car, if they are annoyingly tailgating you lol
Enjoy, drive safe and maintain well !!
vdiatech is offline   Reply With Quote
Old 28th November 2009, 21:24   #22
binz's Avatar
Thanked: 412 Times
Just got back from the garage, 2- day build won't happen and car will be back only on monday :(
That said 95% of the work is done,(sorry no pics since cam ran out of battery) the radiator needs to be mounted,bumper needs to be cut,meshed and mounted and some old exhaust rattles need to be sorted.
The car sounds really really smooth!
We also plonked in the injectors today and started the car,it was running pig rich.Decided not to run them since if there is any problem with the car in the first few weeks,I will not be able switch back to the stock ecu and run the injectors.They will go on in a couple of weeks though after I'm satisfied with the reliability.
Originally Posted by Ford Rocam View Post
Nice,
Just a small suggestion, since your exhaust manifold is very close to intake pipe,A.C condenser pipe & A.C condenser, it will be good to use Heat wrap with some insulating material so that extra heat generated by turbo will not take its toll on A.C functioning & rise in intake air temp.
At what RPM does turbo spool in? Considering Indian weather conditions an oil cooler is recommended for street setup since it will help to keep overall temp down there by increasing reliability of entire setup.
Thanks Jitu, right now just running a regular heat shield,the Oil cooler will be the next upgrade.
Originally Posted by needforspeed88 View Post
Keenly hooked on to this thread. Guess will get to learn a lot from this thread.Eagerly waiting for the full report. Keep us posted binz. It seems you have done all your research before the install. Hope its gonna be a killer setup.
Will keep everyone posted! I did do plenty of research before and even keshav was surprised! I hope its a killer setup too!
Please heed to Psycho's directions on its usage and maintenance . The mod team has had it with dark-side threads !
Its a gearbox of a suzuki cultus, and the ratios aren't as short as you would expect.Its a really well spaced gearbox though,much much better than a standard baleno box.Not to mention it is stronger and will handle the power better.
I have absolutely no issues with keshav. He knows what he is doing with the tune,and i haven't walked into this blindly either
Thanks! That is, I had it for an hour ..
Old 29th November 2009, 00:12   #23
Thanked: 282 Times
Thanks for the update binz. What boost levels you plan to run? Any plans of going forged?
needforspeed88 is offline   Reply With Quote
Old 29th November 2009, 00:21   #24
binz's Avatar
Thanked: 412 Times
Let the car get on the road first!
Old 29th November 2009, 01:36   #25
black12rr's Avatar
Thanked: 274 Times
Wonderful build , more pics are always appreciated .
The air intake can be put in front of battery instead of behind ? , is it breathing fine ?
black12rr is offline   Reply With Quote
Old 29th November 2009, 07:35   #26
kutlee's Avatar
Thanked: 202 Times
nice nice. that is a very long intake pipe running over the manifold? how's your spark plug? pictures of the gauge? rd + turbo should be a good combo. i think you will need bucket seats now.
kutlee is offline   Reply With Quote
Old 29th November 2009, 12:29   #27
aZa
aZa's Avatar
Thanked: 17 Times
congrats and all the best with the reliability! Will be following this thread
Old 29th November 2009, 13:13   #28
binz's Avatar
Thanked: 412 Times
The single picture i posted is neo_trace's car. Mine is slightly different ..
Currently running 7 rating plugs off a Skoda RS, this is just temporary till I buy my new plugs. They will either be NGK 9s or HKS M40s. this should be in within a week or two.
Pictures tomorrow,since the garage is closed today,will also try to get a video of the exhaust and the turbo spooling.
Check out the car next to mine
Thanks!
Old 29th November 2009, 15:06   #29
headers's Avatar
Thanked: 464 Times
interesting - am interested in the 0-100 timing. Should be under 8.xx
Old 29th November 2009, 16:17   #30
vdiatech's Avatar
the driver's skills also play a role in 0-100 i suppose
My Turbo R18 Honda Civic. EDIT: End of an era... Nikhilb2008 Modifications & Accessories 147 19th April 2018 11:03
Race Dynamics' Baleno Build-up: ITBs/Turbocharged - Re-dynoed @ 256 WHP! binz Modifications & Accessories 173 13th February 2017 22:56
The RR700 Prostreet Turbo. The Ultimate Bullet mod job EDIT - Now Super Charged ForcedInduction Motorbikes 98 19th December 2015 11:18
Civic with K&N Typhoon Kit. EDIT : Now TURBO-Charged m4ugr8 Modifications & Accessories 327 6th September 2012 12:12
