Old 17th August 2005, 21:32   #1
islero's Avatar
Default Islero's Accord
Hey guys my latest piece of work. Donor car is an Accord 2.4 as you can see.
I have always thought the Indian Accord had great modification potential, and that it would look fantastic if modded right. I wasnt old enough nor could I afford to mod it, so I just did it virtually!!
Spent a lot of time modifying this one, and it was no mean feat to say the least. Anyways, enjoy!
Original:
Islero version:
Please tell me what you guys think about it.
Cheers,
Islero
islero is offline   Reply With Quote
Old 17th August 2005, 21:35   #2
turbo_lover's Avatar
now thats what am talking about !
just eliminate the rear door ..looks like its just been chopped off ..
remove the rear quarter glass and remove the door line..make it a coupe ..
cheers
turbo_lover is offline   Reply With Quote
Old 17th August 2005, 22:21   #3
sparco's Avatar
hey colur is great car looks awesome... but where are the tyres????
rims look kind off sporty dont match the accord needs something neat that will match a luxary car.... you need to remove the doors juss like the zen carbon & steel and front long doors will also....
keep up the workkk
sparco is offline   Reply With Quote
Old 17th August 2005, 23:52   #4
autopsyche's Avatar
Thanked: 15 Times
QUICK! remove the rear door and add a B pillar in front of the rear glass then itll be like perfect.... The car is looking super duper hot even as it is. Maybe ill use this pic to get someone to agree to let me do this to their accord if you permit me to use it that is heh.
Arush
autopsyche is offline   Reply With Quote
Old 18th August 2005, 00:45   #5
revtech's Avatar
Thanked: 35 Times
hey islero
thats great but would look a lot more better if your take that rear door out.great job dude
hehahha arush i wont be surprised if you actually do thiss to an accord and knowing you youll do one hell of a job !!
Rev
revtech is offline   Reply With Quote
Old 18th August 2005, 01:15   #6
twister's Avatar
Thanked: 11 Times
hey islero.......nice work dude.lookin` hot.but there is one thing that i am not getting clear i.e the outer surface of ur doors is very curvilinear where as the actual surface is quite flat as compared to them.so if u close that door of this car(if real),wont it form boil like shape on the sides??
ne ways......... its nice.a car worth million looks.a pure head turner
cheerz
twister is offline   Reply With Quote
Old 18th August 2005, 08:31   #7
islero's Avatar
Ok guys since all of you have requested, I have now made Version 2.0 of it, a coupe..........
I was looking at the car and suddenly thought "OMG I havent done anything to the side skirts" so here they are, all new sporty sideskirts......
And a new mesh grille...........
Islero Accord Coupe:
So what do you guys think of it now, eh?
Cheers,
Islero
Old 18th August 2005, 08:53   #8
Stratos's Avatar
Thanked: 1,217 Times
Nice work. You should always try to put parts (for example: Skirts in the second modified pic) which are of very good picture quality. In the second pic you can actualyl see the Noise in the skirt. You can superficially do it using the smudge tool also!!
Stratos is offline   Reply With Quote
Old 18th August 2005, 09:29   #9
revtech's Avatar
Thanked: 35 Times
now the rear bumper looks ordinary compared to the front and the sides make it a bit lower. but anyway
great JOb !!!
Rev
p.s the skirts look great !!
Old 18th August 2005, 12:00   #10
sridhar24's Avatar
Thanked: 16 Times
Hey islero thats a great job, but those tyres are just not visible on the car.
sridhar24 is offline   Reply With Quote
Old 18th August 2005, 12:24   #11
islero's Avatar
Yeah actually you can see some noise, but thats not because of the picture size of the skirt donor, but because of some serious skewing and transforming I did to it!!
Old 18th August 2005, 13:34   #12
autopsyche's Avatar
Thanked: 15 Times
Excellent! and hey can u turn around the side skirts? the fat part should be towards the rear coz u dont have the rear door anymore... and also change the rims to a set which are not that negative offset as this one, if not that then u should push the tires out a bit and flare the fenders and rear panel then the rims will look positioned in proportion to the car.
Cheers~
Arush
Old 18th August 2005, 19:31   #13
islero's Avatar
Ok heres the latest version.
Autopsyche I couldnt do everyhting in your long list of suggestions man, but I did manage to straighten the rear wheel out, and I also blended in the sideskirt better, although I couldnt reverse it, because no amount of skewing seemed to be enough to make it look quite right....I also straightened out a few other minor details ( like a mesh on the far side grille which wasnt there before).
Anyways, here it is now.....
Cheers,
Islero
Old 18th August 2005, 21:56   #14
hey islero
am sure you have successfully designed the next ART Accord ..
Old 18th August 2005, 22:56   #15
RJK
RJK's Avatar
Thanked: 16 Times
The rear wheel is just not looking right. Doesn't gel properly. Other than that, nice attempt.
RJK is offline   Reply With Quote
Maruti Swift- Islero Style islero Modifications & Accessories 16 6th August 2006 12:23
Islero's Alto islero Modifications & Accessories 28 29th April 2006 02:14
Islero's Car Sketches islero Shifting gears 22 12th April 2006 07:08
Subaru Impreza STI Estate by Islero islero Modifications & Accessories 10 18th May 2005 21:47
Hello everyone-Islero islero Introduce yourself 10 1st January 2005 18:53
