Old 13th December 2009, 23:54   #1
neel385's Avatar
Thanked: 402 Times
Default Neck support for long drives
I drive an Indigo and frequently do trips which are 2 to 3 hrs long, and of course, there is the occasional road trip. I think that my driving posture is o.k. which is a relative thing, but I do keep the seat relatively straight/close to vertical and the seat is as far removed from the wheel so as to allow the wrists to break over the wheel with the arms straight.
In most of my long drives I have found that that the shoulders and the neck tend to feel strained after about 2 to 3 hrs of driving. In case of bad roads the time period is considerably reduced.
I have tried a variety of measures to alleviate the suffering which have included travelling pillows, the small neck support pillows which all the accessory shops seem to be selling these days, but to no avail.
Does anyone have any other remedy to this problem? Are there any proven seat mods that can be carried out to help?
neel385 is offline   Reply With Quote
Old 14th December 2009, 00:24   #2
Jaguar's Avatar
Thanked: 151 Times
Feels like a posture issue to me. You have mentioned that you keep the seat back close to vertical seat is as far removed from the wheel. Try altering them a bit and see if there is a difference. If not, you may need to consult a doctor and get yourself checked.
Jaguar is online now   Reply With Quote
Old 14th December 2009, 15:48   #3
Thanked: 103,618 Times
A friend had a similar problem, but long gone after he started neck exercises, stretching and yoga.
I hope you stop every two hours for a refreshment break (on highway drives)? Stepping out of the car to get some fresh air does wonders to blood circulation.
GTO is offline   (2) Thanks Reply With Quote
Old 14th December 2009, 16:56   #4
phamilyman's Avatar
Thanked: 3,526 Times
Yoga should solve these things. It is wonderous for body agility/flexibility.
For pure pain relief, you can quite happily n easily do Sujok. It'll let you drive in peace atleast
Old 14th December 2009, 17:01   #5
fiery enzyme's Avatar
Thanked: 23 Times
Try the neck pillow positioned in a way so you are resting your head on it and not your neck. This supports your head and reduces strain on your neck. I had the same problem and this helped me.
fiery enzyme is offline   Reply With Quote
Old 14th December 2009, 17:07   #6
neel385's Avatar
Thanked: 402 Times
Tried various seat positions...dosen't seem to really help. The doc part am not really sure..I have no problems pulling 9Gs.
This is one thing that I do not do as of now. Feel it really bites the average you get (km/hr not kmpl), but maybe that it is something that I need to do; wife will sure be thrilled!
I feel that it is more of a strain issue than a pain issue. Will try the Sujok thing, after I google it!
Old 15th December 2009, 01:58   #7
Jaguar's Avatar
Thanked: 151 Times
Oh saw your profile and the doc part is definitely ruled out. Maybe it is the lack of Gs that is causing the problem
Old 15th December 2009, 15:46   #8
Coincidentally I met the same friend last night. Brought the topic up, and he highly recommends physiotherapy if the problem is severe. Worked like a charm for him.
3 things more important than average km/h:
1. Safety : Your getting out and stretching will increase blood circulation and, thus, your attention / reflex action.
2. No pain : I'm pretty sure it'll help keep the neck discomfort at bay.
3. Smile on the wife's face
GTO is offline   (1) Thanks Reply With Quote
Old 16th December 2009, 23:37   #9
neel385's Avatar
Thanked: 402 Times
Point taken GTO!! Thanks all!!
Old 30th May 2010, 07:33   #10
freewheelburnin's Avatar
Thanked: 26 Times
Ditto to that!Even i had a neck problem.Physiotherapy for 2 or 3 week which included electric traction coupled with some exercises completely cured the problem.After that i used to get it like twice a year maximum.But now thankfully it has not re-occurred.Good posture helps.Even while sleeping at night use a pillow which suits the length of your neck and the position you sleep(sideways or on your back).Once the neck recovers bench press done under supervision using moderate weight helps.
freewheelburnin is online now   Reply With Quote
Old 30th May 2010, 09:06   #11
Thanked: 360 Times
I think it's a posture problem.
Steps:
First bring the seat as high and forward as it will go without your knee hitting the steering wheel.
Next recline your back to 15-30* so that your elbows are flexed to 30*
Tilt the steering to have adequate vision of the dash and the road.
Adjust the head rest to 10 cm behind the most prominent part of your skull
Your final position should be
Neck Flexed at 15*
Spine erect
Shoulders flexed at 75*
Elbows flexed at 30*
Wrists extended at 30*
Hips flexed at 60*
Knees flexed at 75*
Ankles comfortable on the pedels.
I routinely drive for 8-12 hours and take a break only once or twice if there are co-passengers and never if alone. Just keep your body relaxed and springy.
Neck exercises will help but in adjunct to a good posture.
wildsdi5530 is online now   (2) Thanks Reply With Quote
Old 30th May 2010, 22:53   #12
neel385's Avatar
Thanked: 402 Times
Steps:
Neck Flexed at 15*
Spine erect
Hips flexed at 60*
Knees flexed at 75*
Hey Wildsdi!! Thanks man!! But since I have an Indigo which does not have a height adjustable driver seat nor a tilt-able able steering, its no go for me!!
Old 21st March 2012, 23:33   #13
neel385's Avatar
Thanked: 402 Times
Default Re: Neck support for long drives
Finally found a way past my sufferings and it came from a physiotherapist I was consulting for some other issue.
The issue was that I was driving with the seat too erect i.e. close to 90* because of which there was strain on the shoulder muscles. Tilting the back rest by about 15* has solved the problem!!
neel385 is offline   (2) Thanks Reply With Quote
Old 21st March 2012, 23:45   #14
rajeev k's Avatar
Thanked: 1,750 Times
Do some minor neck movements while driving, concentrating fully on the latter. What kind of covers your seats are on. This is important as unscientifically stuffed locally made ones that are not ergonomic can cause a strain.
rajeev k is offline   Reply With Quote
Old 22nd March 2012, 07:34   #15
josepeter's Avatar
Thanked: 547 Times
Interesting thread and lots of good tips! I have done several 1000+ km drives lately and feel my neck hurting in the last few 100 Kms. The head rests on the Tata Safari is way up..i guess only 6 footers find use for it..
Just about to hit the road from Gangtok to Hyderabad in a few minutes..I'll try the angles suggested by wild. ( a bit too technical..)
josepeter is offline   Reply With Quote
Separate or Integrated Neck Restraints (Headrests) : Which is the safer choice? mints21 Road Safety 37 19th April 2016 10:25
USB/iPod support for a OEM HU w/o USB Support MadRash In-Car Entertainment 26 2nd August 2014 00:40
Maruti recalls Swift, Dzire & Ertiga: Fuel filler neck replacement volkman10 Technical Stuff 19 14th April 2014 11:00
HELP !!! (NTFS encrypted data causing a pain in the neck) motorheadinc Gadgets, Computers & Software 19 24th January 2008 10:59
Look who's breathing down your neck CGT / Zonda! Aditya The International Automotive Scene 5 30th October 2004 03:04
