Old 17th January 2010, 20:31   #1
VEA
Thanked: 32 Times
Default Which strut gives ultimate ride comfort
Its time for my tucson's strut change. I would like to get aftermarket struts that gives the best possible ride comfort (low speed) in the car. I dont mind how bad it handles. I see that lot of people here get koni's, but almost all of them go for the best handling ones. How good is koni FSDs in terms of ride comfort. I read here that it tends to be stiffer than stock set up. Is it true? Do I have any other options? My max budget is around Rs.50000 and scope limited to strut change only. Please suggest me something that gives me good damping and carpet ride quality
VEA is offline   Reply With Quote
Old 17th January 2010, 21:40   #2
nitrous's Avatar
Thanked: 285 Times
Stick to stock struts.
Use a comfort oriented tyre with the stock size.
Old 17th January 2010, 21:41   #3
mithun's Avatar
Thanked: 59 Times
Koni's are not meant for ride comfort, it's for handling.
How old is the vehicle ? How many KMS ?
Old 18th January 2010, 00:30   #4
VEA
Thanked: 32 Times
mithun,
its a 2005 make and done 100000 kms. the stocks have been replaced once. right now i have Michelin latitude 235/60/R16 tires on it. after replacing the stock hankook with Michelin the ride has improved a bit, but not to a comfortable extent. I've a little baby now and would like to make the ride a bit more comfy for her. Is there someone manufacturing comfort oriented struts?
Old 18th January 2010, 08:41   #5
crazydiablo's Avatar
Thanked: 21 Times
I dont think you will get FSDs for the Tuscon. The Konis for the SUVs are a completely different range. So I guess u have to stick to stock.
crazydiablo is offline   Reply With Quote
Hatch Back Vs Sedan ( Ride, handling, comfort, Power, Space, etc) muni Technical Stuff 116 6th April 2012 20:19
What affects ride comfort? Samurai Technical Stuff 39 29th September 2010 18:15
which car best on medium level bad road for ride comfort and fuel efficiency omvnbhatt Sedans 1 29th October 2006 10:07
Low Speed Ride Comfort ramkya1 Technical Stuff 1 25th November 2005 11:13
Performance and Ride comfort in one car? Samurai Sedans 84 12th April 2005 17:53
