Old 8th February 2010, 11:59   #46
noidaboy's Avatar
Thanked: 260 Times
Here are some more pictures for you guys.
And Some mechanic's as A.S.S know how to do such things, But they cannot do it because its not allowed, A.S.S cannot do any aftermarket installations until approved by the company.
Trust me some mechanic's on the road side are good as well.Its just that they dont have a uniform and a company logo on their backs.
noidaboy is offline   Reply With Quote
Old 8th February 2010, 13:02   #47
inreverse's Avatar
I checked out some Bi-Xenon stuff on e-bay. It appears that most of it is marketed out from Shanghai, China. Don't know if the chinese make is reliable as it comes in real cheap, standard Bi-Xenon with CCFL (Angel Eyes)
The one below is for around $145 (Rs. 6670 Approx without shipping charges) with ebay Buyer Gaurantee...
Chinese Make
This one is from USA for $175 (Rs. 8050/- Approx without shipping charges)
US Make
inreverse is offline   Reply With Quote
Old 8th February 2010, 16:37   #48
Hi NoidaBoy.
Good stuff, this is really nice.
What is the distance range as compared with stock head lamps?
Drive safe, enjoy.
Cheers...!
sameern.85 is offline   Reply With Quote
Old 8th February 2010, 17:38   #49
Thanked: 13 Times
Looks like you painted the reflectors black. In that case you will not be able to use the standard bulbs again. This comes with a D2S bulb correct?
Also, can you PM me the guy from who you sourced this.
suneet_ag is offline   Reply With Quote
Old 9th February 2010, 01:40   #50
noidaboy's Avatar
Thanked: 260 Times
Originally Posted by sameern.85 View Post
Hi NoidaBoy.
Drive safe, enjoy.
Cheers...!
Thanks, As for the comparison. Its decent,The high beam is good, But the low beam has too much of cut out. That can be moded easily
No this comes with H1 hid
Old 10th February 2010, 00:18   #51
ph03n!x's Avatar
Thanked: 120 Times
Originally Posted by noidaboy View Post
Has the problem sorted out? Waiting for the pix.
No buddy, didnt have the time to touch it till now. I finally managed to be out at night AND have a camera to take a decent pic - here it is:
This is the low beam - I have adjusted the height adjuster to the lowest (3 in Getz) to get a clearer image of how the beam's throw is.
As you can see, the shutter does not seem to be in a straight line, and the beam's alignment / focus is haphazard. Not sure how to get his fixed :(
High beam is a bliss - no problems there.
ph03n!x is offline   Reply With Quote
Old 10th February 2010, 00:50   #52
KSM-Vtec's Avatar
Thanked: 440 Times
great work i must say!!!!!
KSM-Vtec is offline   Reply With Quote
Old 10th February 2010, 08:38   #53
motomaverick's Avatar
Thanked: 868 Times
wow! crystal clear white light. Yeah the beams are not converging at one point, is it the fitting issue?
Old 10th February 2010, 08:58   #54
smokin's Avatar
Thanked: 13 Times
Attachment 284991
this problem arises in few car headlights not all though !!! the main problem is the positioning of the bulbs
it can be rectified but need to do some alteration in your car headlights ,if you are ready to do ...
smokin is offline   Reply With Quote
Old 10th February 2010, 10:28   #55
wildchild4lyfe's Avatar
hey is it possible to change the colours of the rings?
wildchild4lyfe is offline   Reply With Quote
Old 10th February 2010, 22:39   #56
k_shanz's Avatar
Thanked: 64 Times
Thats awesome. Thats really looks great!
k_shanz is offline   Reply With Quote
Old 11th February 2010, 01:01   #57
ph03n!x's Avatar
Thanked: 120 Times
Thanks Smokin. What should I do?
This DIY is only a stop gap, so I am ready to alter stuff. I want to see how much I like it and can live with it - I was told these Chinese things do not last all that long, so want to make sure I am / will be happy before I put in 25k+ for a custom headlight kit (I dream of one with eye brows, separate HID for low and high, et all..!)
The kit comes with options of red, blue, white, etc. Changing the bezel (ring) alone will be a hassle - you have to open headlight assembly again.
I was told the CFL ring will not last for long. Moreover the ring is still on even when the HID is turned on - which means the CFL will be burning away to glory whenever the headlights are on! Is it the same with all such kits?
Old 11th February 2010, 15:36   #58
i think the rings would be connected to the parking lights.if you want them off then i think you could have a cut off switch.
Old 11th February 2010, 22:51   #59
noidaboy's Avatar
Thanked: 260 Times
Yes, the ring can be easily changed.
@ ph03n!x
And as for the focus, have you manually adjust the reflector? It looks fine anways
Old 12th February 2010, 00:59   #60
ph03n!x's Avatar
Thanked: 120 Times
I haven't tried adjusting much - I have gotten used to the beam's inverted "V" now.
@smokin - any tips?
Projector headlamp setup for my SX4 prince85 Modifications & Accessories 10 3rd January 2014 20:28
Projector setup for Fiesta, that's already has HID? fiesta_21 Modifications & Accessories 17 3rd December 2011 11:47
Projector setup on Swift & Some DIY also.... low_bass_makker DIY - Do it yourself 34 1st December 2009 02:04
Projector setup for Esteem type-III viky_s Modifications & Accessories 12 3rd August 2009 12:06
